Is there a way to redirect all output to a UNIT=COPY?
macro
I have a lengthy script that runs in batch mode, and I'm trying to get RATS to save the text output (output only, not the output and the compiled code) in a separate text file. Some instructions, like DISPLAY or REPORT, support a UNIT=COPY option that lets me flexibly redirect output to this file. However, other instructions, like PRINT, FORECAST, etc. don't support this option. Is there a way around this?
COPY does provide for somewhat flexible output, but for printing series, I'm limited to FORMAT=FREE, among others, that doesn't replicate the convenient output of the PRINT instruction. If I use another format, I can't append the mix of text, series, and other output that I have to the file.
I can roll my own versions of FORECAST, PRINT, etc. that support this, but this is such a basic feature (redirecting output, and only output, to a text file), and rolling my own is significantly costly, that I'm hoping there's a simpler way to achieve this.
Re: Is there a way to redirect all output to a UNIT=COPY?
Either CHANGE OUTPUT unitname or OPEN OUTPUT filename
https://estima.com/ratshelp/changeinstruction.html
macro
Thank you; I think this is mostly what I was looking for. Once I've changed the output to a separate file, how do I change the output back to the default .out file? I'm running scripts in batch mode. For example, after this code
If I add
Then -results.txt- is overwritten. Do I need to define another output unit to switch back to? If I define the default -myscript.out- as an output unit, it'll get overwritten, which isn't what I want. The -append- option to open prevents this, but is there a canonical way to simply switch back to the default output file?
open outfile "results.txt"
change output outfile
linreg lgdpk
# lgdpk{1 to 4} lpotgdpk{1 to 4}
print / lgdpk lpotgdpk
close outfile
There's no defined unit for the initial batch output file. My suggestion if you want to switch between two output files is to start the program with
open outfile1 myscript.out
change output outfile1
then
open outfile2 "results.txt"
change output outfile2
then
