I hope that this email finds you well. I would like to save the conditional variances from the multivariate GARCH using maximize (in the attached file). I will be much grateful if you could provide your insights in this regard.
Many thanks for everything,
Faek
Saving conditional variances
Re: Saving conditional variances
Those are already saved in the H. You can pull those out with something like
set h11 gstart gend = h(t)(1,1)
and similarly for the other components.
Thank you so much for the prompt reply and the valuable help- It is much appreciated!
