I don't understand why but with two diferent version of rats, I haven't the same results.
In Rats 8.0:
boxjenk(constant,ar=1, ma=1,maxl,diffs=1,regressor) pib 1960:01 * resexo
# trend trend2
Box-Jenkins - Estimation by ML Gauss-Newton
Convergence in 20 Iterations. Final criterion was 0.0000017 <= 0.0000100
Dependent Variable PIB
Annual Data From 1960:01 To 2014:01
Usable Observations 54
Degrees of Freedom 49
Skipped/Missing (from 55) 1
Centered R^2 0.9995619
R-Bar^2 0.9995261
Uncentered R^2 0.9999962
Mean of Dependent Variable 9.7166476565
Std Error of Dependent Variable 0.9181274693
Standard Error of Estimate 0.0199869509
Sum of Squared Residuals 0.0195744320
Log Likelihood 135.9647
Durbin-Watson Statistic 1.8798
Q(13-2) 9.5167
Significance Level of Q 0.5743072
1. CONSTANT 7.819026571 0.073574757 106.27322 0.00000000
2. AR{1} 0.917717716 0.055341065 16.58294 0.00000000
3. MA{1} 0.397724272 0.135593868 2.93320 0.00509005
4. TREND 0.087847768 0.005618158 15.63640 0.00000000
5. TREND2 -0.000569857 0.000094838 -6.00872 0.00000023
And in Rats 9.1:
boxjenk(constant,ar=1, ma=1,maxl,diffs=1,regressors) pib 1960:01 * resexo
# trend trend2
NO CONVERGENCE IN 69 ITERATIONS
LAST CRITERION WAS 0.0000000
SUBITERATIONS LIMIT EXCEEDED.
Usable Observations 55
Degrees of Freedom 50
Centered R^2 0.9984907
R-Bar^2 0.9983699
Uncentered R^2 0.9999862
Mean of Dependent Variable 9.6855946343
Std Error of Dependent Variable 0.9382876296
Standard Error of Estimate 0.0378827609
Sum of Squared Residuals 0.0717551788
Log Likelihood 104.6087
Durbin-Watson Statistic 0.5631
Q(13-2) 76.6459
Significance Level of Q 0.0000000
1. CONSTANT 7.784659094 0.030028584 259.24163 0.00000000
2. AR{1} -0.754375420 0.035138862 -21.46841 0.00000000
3. MA{1} 0.324101626 0.043120686 7.51615 0.00000000
4. TREND 0.090274713 0.002567841 35.15588 0.00000000
5. TREND2 -0.000598410 0.000045431 -13.17190 0.00000000
I have check many times, I used exaclty the same data. But usable Observations and degrees of fredom are diferents.
Box-Jenkins rats 8.0 and 9.1
Re: Box-Jenkins rats 8.0 and 9.1
You would have to show me the data set. However, DIFFS=1 combined with trends is an odd combination for an ARIMA model.
