name of the series matrix
Akawa
Unread post by Akawa »
I have a simple question: What is the name of my data matrix, that is, those loaded with the command "data". I would like to know the number of columns/series loaded in Rats but don't know the argument in place of "A"
compute col =  %cols(?)
Re: name of the series matrix
There's no "matrix" underlying the series---each series is separately organized (since different series can have different lengths and usable ranges). If you need to know how many series there are at any given time, you could do
compute nseries=%size(%slike("*"))
(%SLIKE(string) returns a list of all series matching a given pattern, where "*" matches anything). If you need to actually create a working matrix out of series, use the MAKE instruction.
