The attachments are replications for Gali(1992), "How Well Does the IS-LM Model Fit Postwar U.S.", Quarterly Journal of Economics, vol 107, no. 2, pp 709-738. This does a VAR with long and short run restrictions, estimated by maximum likelihood using CVMODEL. It makes extensive use of the @ShortAndLong procedure to parameterize a set of short and long run loadings in the factorization (the "B" part of the model), with the final identification coming from "A" restrictions.
Gali QJE 1992
Gali QJE 1992
Reason: Updated MCGraphIRF procedure and file which used it
Last bumped by TomDoan on Mon Apr 02, 2018 7:56 pm.
