Gali QJE 1992
Posted: Mon Apr 02, 2018 7:56 pm
The attachments are replications for Gali(1992), "How Well Does the IS-LM Model Fit Postwar U.S.", Quarterly Journal of Economics, vol 107, no. 2, pp 709-738. This does a VAR with long and short run restrictions, estimated by maximum likelihood using CVMODEL. It makes extensive use of the @ShortAndLong procedure to parameterize a set of short and long run loadings in the factorization (the "B" part of the model), with the final identification coming from "A" restrictions.
GaliQJE1992.zip
This zip file includes all the files below
(10.38 KiB) Downloaded 1128 times
galiqje1992.rat
Data file
(14.75 KiB) Downloaded 1245 times
islmdata.src
Common file for data transformations
(805 Bytes) Downloaded 1082 times
islmvarsetup.src
Common file for setting up SVAR
(2.65 KiB) Downloaded 1100 times
islmunitroot.rpf
does unit root tests and other basic statistics
(956 Bytes) Downloaded 1269 times
islmsvar.rpf
estimates several SVAR's with short-and-long run restrictions
(1.79 KiB) Downloaded 1245 times
islmvarirf.rpf
does Monte Carlo integration on a SVAR estimated with CVMODEL
(3.27 KiB) Downloaded 1196 times
islmhistory.rpf
does the historical decomposition for one of the SVAR's.
(1.21 KiB) Downloaded 1203 times
