DSGE - Bayesian Estimation
The attached files estimate a DSGE using Metropolis-Hastings with a uniform prior on the four coefficients. Note that the model has already been solved out into a backwards looking form and so could be done directly with DLM, though that would require changing the form a bit. DSGE can also be used to convert a model like this (written as formulas) into a standard state space form.
Sargent77Bayes.prg
(4.79 KiB) Downloaded 1239 times
cagan_data.prn
(663 Bytes) Downloaded 1261 times
