how to read the return data
upani
Unread post by upani »
Dear All,
I would like to read my data using the following code.
DATA(FORMAT=XLSX,ORG=COLUMNS) 2005:01:07 2021:10:01 MCX COMEX SPOT
set rmcx  = 100.0*log(mcx/mcx{1})
set rcomex = 100.0*log(comex/comex{1})
set rspot    = 100.0*log(spot/spot{1})
After calculating the return series, how drop the first observation. As Rats is giving me the following error.
## REG20. GARCH Cannot Be Used with Gaps/Missing Values.
Please guide me on how to rectify the error in my code.
I have attached the data set for your reference.
With sincere regards,
Upananda
silvermcx.xlsx
(43.48 KiB) Downloaded 1058 times
Re: how to read the return data
You have embedded missing values in your data:
2010:12:31 NA NA NA
2016:12:30 NA NA NA
Given that you are using weekly data anyway, you should probably put in the nearest trading day for those entries.
upani
Dear Sir,
Thanks a lot for your reply.
Upananda
