I want to get the Impulse response function after running CATS analysis and export the model to RATS. I read all the forum threads under CATS but could not figure out how to do it. I worked on MONTEVECM.rpf as per the pointers but could not understand how to integrate extracted CATS model to do IRFs. Here is a modified version of MONTEVECM. RPF, which has a CATS command line added to generate the output (I am using different input/output windows). Here is a sequence of actions I have taken:
(1) Run as usual MOTEVECM (using @johmle) to see if I am getting all the results (PART 1 of output) in OUTPUT_CATS_MONTEVECM.
(2) PART 2 IN THE OUTPUT
Run *** CATS ANALYSIS
source c:\cats2\cats.src
@CATS(DETTREND=CIMEAN, lags= 6, r=1)
# ftbs3 ftb12 fcm7
(3) Used menu command in CATS: MISC/Export RATS Model, which produced the CATS model in the output window
(4) After step 3 above, I used the menu command in CATS to Shell to RATS
(5) After step 4, I proceed to "way1" and "way 2" given in CATS_MONTEVECM.rpf
(6) Both ways produced errors given in the output.
Please help me set up the code to generate IRF from the CATS output. I appreciate your help.
How to Export RATS Model & do IRF
victor
- OUTPUT_CATS_MONTEVECM.RPF
- Output from CATS_MONTEVECM.RPF
- (11.79 KiB) Downloaded 4069 times
- CATS_MONTEVECM.RPF
- CATS command added to MONTEVECM.RPF
- (1.6 KiB) Downloaded 4124 times
