GARCHDECO—Dynamic Equicorrelation (DECO)
Posted: Wed Feb 10, 2010 12:21 pm
GARCHDECO.RPF uses one of the standard RATS example data files for demonstrating the DECO model of Engle and Kelly(2012), "Dynamic Equicorrelation", JBES, vol 30, no 2, 212-228. (Not a great choice for the technique, since the Canadian exchange rate has a low correlation with the others—this should be applied to a set of variables which have relatively similar pairwise cross correlations).
Detailed description
g10xrate.xls
Data file
(1.2 MiB) Downloaded 2102 times
Re: dynamic equicorrelation
Posted: Wed Nov 21, 2012 8:24 am
by xray
Is it possible to form the minimum variance and global minimum variance portfolios as done in the DECO paper (http://papers.ssrn.com/sol3/papers.cfm? ... id=1354525) using matrix algebra in RATS?
Thanks!
Posted: Wed Nov 28, 2012 12:35 pm
xray wrote:Hi,
Thanks!
Their process would take a lot of programming. Calculating the portfolios is simple given the covariance matrices. However, in order to avoid biasing the results, they run rolling estimates, but in order to avoid the cost of running too many optimization problems, they re-estimate only once in 22 periods, and do a sequence of 22 one-step predictions, using the last set of estimates. They also cut out the description of how to forecast the "rho" out-of-sample from an earlier working paper. It isn't analytical and they gave two different expressions, so it's not clear which they recommend.
Posted: Thu Nov 29, 2012 5:31 am
by xray
TomDoan wrote:
The version of this just posted now computes the covariance matrices as the SERIES[SYMMETRIC] called HH.
Is it possible to display this in the matrix form
HH =
hh11............hh1,8
hh1,8...........hh8,8
The print and display commands don't seem to work
Posted: Thu Nov 29, 2012 9:24 am
There is one HH matrix per time period. You can do
DISPLAY HH(100)
to get the HH matrix at T=100, and the same for any other data point.
Posted: Sat Apr 04, 2020 10:26 am
by hungufm
Please help me find the average correlation coefficient in DECO model s the following paper:
(https://www.sciencedirect.com/science/a ... 7119310416)
As the sample codes shown, I did not see this figure.
Your help would be appreciated,
Ngo
Posted: Sun Apr 05, 2020 10:54 pm
Wouldn't that just the the RHO series that's being computed by the program?
Posted: Wed Apr 15, 2020 9:48 am
by hungufm
In rats, I run regression model for example, then i want to gain residual data of the model. I mean I have to print the residual into excel file. What should I do?
Return my case, could you show me how can I print RHO series into excel or rats file?
Thanks in advance,
Posted: Tue Aug 13, 2024 8:55 am
RHO is a SERIES so you can do with it anything that you could do with any other SERIES. In particular, you can use COPY to create an Excel file.
