I tried to alter the montesur.prg to take into account of alternative factorization, and incorporated the resulting changes into the format of MCVARDoDraws.src and MCgraphirf.src. Everything seems fine but the error band given by the option center=input, impulses = impulses, and the option stddev is quite narrow. Is it a problem with my coding?
compute frac=%wfractiles(work,%%weights,request)
* Choose the central value
if center==1
compute resp(j)(k)=%avg(work.*%%weights)/%avg(%%weights)
else
if center==2
compute resp(j)(k)=frac(npercent+1)
else
compute resp(j)(k)=impulses(yshow(i),j)(k)
if %defined(stddev) {
compute sigma=sqrt((%normsqr(work.*%%weights)/(%sum(%%weights)^2))-(resp(j)(k)^2/draws))
Thank you so much.
Montesur
MC128
Montesur
- MCSURGraphIRF.src
- (10.75 KiB) Downloaded 1137 times
- ABSURDraws.src
- (4.99 KiB) Downloaded 1110 times
