estimate and estimate(model=....
The model is specified follow,
linreg(define=longeqn) y
# constant x
system(model=m2)
variables x y z
lags 1 to 2
det d_x1 constant
ect longeqn
estimate ;*<<----------OK
estimate(model=m2) 1 100 ;*<<----------- NOT OK; (insteaded the ect model is estimated, the var model did.)
i need to use the second instruction, since i have different model in a loop. I am not sure if this is a winrats bug, but i need a solution. Please help. thanks.
# constant x
system(model=m2)
variables x y z
lags 1 to 2
det d_x1 constant
ect longeqn
Re: estimate and estimate(model=....
The ECT doesn't "follow" the MODEL data type, so you can only have model using ECT at a time. How are you using the two models? It only matters if you're using ESTIMATE on both, and the OLS model can be estimated with SUR(MODEL=...) instead.
system(model=m1)
ect longeqn1
system(model=m2)
ect longeqn2
(some orther code)
estimate(model=m1);<<--generating VAR(m1) result,not VAR with ect result.
;if i type "estimate" without model name, it give me VAR(m2). But I need the result of
VAR(m1)'s ect result.
any suggestion?
ect longeqn1
system(model=m2)
ect longeqn2
(some orther code)
any suggestion?
Is there any reason you can't do
system(model=m1)
estimate
system(model=m2)
estimateRe: estimate and estimate(model=....
reason is simple,check out the following function:
function mdl
type model mdl
estimate(model=mdl)
now whether I call this function with either ect type or not , the result is not ect result.
function mdl
type model mdl
estimate(model=mdl)
You'll have to post the whole program; I can't really give you a workaround without it.
