reading data
luxu1983
reading data
Post by luxu1983 »
dear
when can i graph the series that is undated(not regular freguency day per period), how can i set the x-axis be time axis ? :D
thank you very much
Re: reading data
Post by TomDoan »
A graph will have a time sequence on the x-axis. It will only label it with dates if there's a calendar in use. What are you hoping to do? Sometimes you can get more flexible labelling by using the SCATTER instruction which has the XLABELS option. Note, however, that that assumes regular intervals.
luxu1983
Re: reading data
Post by luxu1983 »
dear sir
because my data is udated i do not know how import the "time sequence"
i import my data in this way
Cal(Irregular)
COMPUTE GSTART=1, GEND =10
all gend
Open Data data.xls
data(format=xls,org=cols)
now i want graph the series including the time sequence on the x-axis
my data is like this in excel
time xx
4/29/2005 7.103486523
5/09/2005 7.079100145
5/10/2005 7.083303951
5/11/2005 7.07335446
5/12/2005 7.055079857
5/13/2005 7.058362545
5/16/2005 7.047438957
5/17/2005 7.051102092
5/18/2005 7.054164643
5/19/2005 7.054596452
5/20/2005 7.050798788
5/23/2005 7.024684617
Re: reading data
Post by TomDoan »
luxu1983 wrote:dear sir
Cal(Irregular)
all gend
Open Data data.xls
time xx
If you read that as:
Cal(Irregular)
all gend
Open Data data.xls
data(format=xls,org=cols) / xxx
you'll get the first 10 entries (through 5/19) in order.
With big gaps like that, you can't sensibly label a graph with dates. If you think it would help, you can use shading or grid lines (SHADING and GRID options) to distinguish months. But you would have to know which entries are in each month. You can use Excel functions to break the dates up to give separate year and month series.
luxu1983
Re: reading data
Post by luxu1983 »
dear
Are there another methods to read the data including the time sequence even if the gaps existing?
thank you very much
Re: reading data
Post by TomDoan »
No. If you need the dates broken down for data with gaps, you need to add series to the data file for them. If you already have the dates coded as Excel dates, the Excel year, month and day functions handle that quite easily.
