Checking memory used by RATS
jonasdovern
Unread post by jonasdovern »
I coundn't find (or better: remember) the command which allows to check how much memory RATS currently uses. (I am running a Gibbs sampler which would run without error with a small number of iterations, but which crashes RATS when increasing the number of iterations. I would like to check if memory problems are the problem...)
moderator
Site Admin
Re: Checking memory used by RATS
Unread post by moderator »
You can do:
SHOW MEMORY
However, if the program is actually crashing (i.e. shutting down spontaneously), it is highly unlikely that it would be do running out of memory.
Tom Maycock
jonasdovern
Thanks. I'll check how the used memory evolves. The program is not actually shutting down - but rather stops working and displays (according to my translation, I have a German system): "Application does not react anymore".
