Hello, I have some questions about the @APBreakTest procedure in Rats program.
Forgive me if it's a stupid question:
Is this procedure only apply on linear models? Say if I want to test the parameters change in a model, it has to be tested on a linear model?
Can i use it to test GARCH model parameters changes?
What should put for independent variable and what for regressors?
Really appreciated if anyone could help.
Cheers
Need help for Andrews and Ploberger test
Re: Need help for Andrews and Ploberger test
You can't apply @APBreakTest to anything other than a linear regression. However, there's a related (and actually simpler) calculation that can be applied to the derivatives of the log likelihood elements that are computed by GARCH (or by MAXIMIZE). See
http://www.estima.com/forum/viewtopic.php?f=7&t=893
