compute c=%varlagsums
compute s1=%mqform(%sigma,tr(inv(c)))
compute s2=%decomp(s1)
compute g=c*s2
impulse(model=irf_b,results=impblk,noprint,decomp=g) * nsteps *
Attached is a RATS procedure I wrote for BQ with band. I insert the above lines within "do draws" block. May anyone take a look to judge whether it's correct? If not, may you kindly modify it?
* impulse responses with band by Blanchard-Quah decomposition
* through Monte Carlo integration
***** data input and transformation *****
calendar 1959:1
allocate 2002:1
open data gdp_rnd.xls
data(format=xls,organization=columns) / rgdp rrnd
set dlrgdp = (log(rgdp)-log(rgdp{1}))*100
set dlrrnd = (log(rrnd)-log(rrnd{1}))*100
***** VAR setup *****
compute neqn = 2
compute nvar = 2
compute nlags = 2
compute nstep = 12
compute ndraws = 2500
system(model=irf_bq)
variables dlrrnd dlrgdp
lags 1 to nlags
kfset xxx
deterministic constant
estimate(outsigma=vmat,noftests,noprint)
***** graph impulse responses *****
declare rect sxx svt swish betaols betadraw
declare symm sigmad
compute sxx =%decomp(xxx)
compute svt =%decomp(inv(%nobs*vmat))
compute betaols=%modelgetcoeffs(irf_bq)
compute ncoef =%rows(sxx)
compute wishdof=%nobs-ncoef
declare rect ranc(ncoef,nvar)
declare vect[rect] responses(ndraws)
infobox(action=define,progress,lower=1,upper=ndraws) 'Monte Carlo Integration'
do draws = 1,ndraws
if %clock(draws,2)==1 {
compute sigmad =%ranwisharti(svt,wishdof)
compute swish =%decomp(sigmad)
compute ranc =%ran(1.0)
compute betau =sxx*ranc*tr(swish)
else
compute %modelsetcoeffs(irf_bq,betadraw)
compute s1=%mqform(sigmad,tr(inv(c)))
compute g=c*s2
impulse(noprint,model=irf_bq,decomp=g,results=impulses) * nstep *
* Store the impulse responses
dim responses(draws)(nvar*nvar,nstep)
ewise responses(draws)(i,j)=impulses((i-1)/nvar+1,%clock(i,nvar))(j)
infobox(current=draws)
end do draws
