Mix of zero and sign restrictions
KOBE24
I just had a look at some paper using a mix of short-run restrictions and sign restrictions to recover structural shocks (see, for example, Peersman, 2010: please find the link below).
http://www.feb.ugent.be/fineco/gert/doc ... er2010.pdf
My feeling is that one shouls first estimate the VAR as usual, and then exploiting the short-run matrix A. But then how do you combine the drawing section for sign restrictions?
Every suggestion would be greatly appreciated!
Thanks a lot!
Thanks a lot!
Re: Mix of zero and sign restrictions
The combination of short-run zero restrictions plus sign restrictions is covered in the March 2009 newsletter.
http://www.estima.com/newslett/March2009RATSLetter.pdf
KOBE24
thanks a lot for your suggestion!
I will study the newsletter and then try and implement the code I need.
Regards
Regards
