Transition or migration matrices in RatS
Aqu_nb
Re: Transition or migration matrices in RatS
sorry the matrix looks like:
0.39581 0.07705 0.01245 0.00205 0.00085 0.00013 0.01165
0.04980 0.32419 0.09470 0.01749 0.00290 0.00045 0.01046
0.00463 0.05876 0.32108 0.08518 0.01558 0.00227 0.01250
0.00092 0.01041 0.09079 0.28290 0.08201 0.01024 0.02273
0.00034 0.00204 0.02927 0.14299 0.22622 0.05427 0.04488
0.00002 0.00017 0.00232 0.02726 0.08753 0.29964 0.08306
and the rows and colums does not add to 1 or 100 %?
The rows are adding to 1/2 rather than 1 which is very puzzling. It looks like you need to send the program and data file to support@estima.com so we can try to run it and see what's going on. That should work.
Aqu_nb
Sorry the matrix looks like:Aqu_nb wrote:Yes it works. But the problem now is that the rows or colums does not sum 1 (100%). The ouput looks like following:TomDoan wrote:display transit
will do that.
1 2 3 4 5 6 Default
1 0.39581 0.07705 0.01245 0.00205 0.00085 0.00013 0.01165
2 0.04980 0.32419 0.09470 0.01749 0.00290 0.00045 0.01046
3 0.00463 0.05876 0.32108 0.08518 0.01558 0.00227 0.01250
4 0.00092 0.01041 0.09079 0.28290 0.08201 0.01024 0.02273
5 0.00034 0.00204 0.02927 0.14299 0.22622 0.05427 0.04488
6 0.00002 0.00017 0.00232 0.02726 0.08753 0.29964 0.08306
What do you think the problem can be?
Thanx again:-)
Aqu_nb
Sorry I did not saw your mail it was on page 2. I will send the program and the data to support@estima.com .TomDoan wrote:The rows are adding to 1/2 rather than 1 which is very puzzling. It looks like you need to send the program and data file to support@estima.com so we can try to run it and see what's going on. That should work.
Aqu_nb
Ok now I have send a mail with the data (attached) and the program to support@estima.com.TomDoan wrote:The rows are adding to 1/2 rather than 1 which is very puzzling. It looks like you need to send the program and data file to support@estima.com so we can try to run it and see what's going on. That should work.
Aqu_nb
I actually think that I have the transition matrices correct. Now I need to calculate whether the estimated probabilities of recession and expantion matrices are significantly different from the unconditional matrix. In oeder to do so I will need some standard errors. How do I calculate the standard errors.
Regards
Atef
Regards
Atef
There's a separate nclass x nclass covariance matrix for the elements of each row. The row estimates are independent of each other.Aqu_nb wrote:Dear Tom,
Regards
Atef
dec vect[symm] rowcv(nclass)
do c=1,nclass
dim rowcv(c)(nclass,nclass)
ewise rowcv(c)(i,j)=(transit(c,i)*(i==j)-transit(c,i)*transit(c,j))*rowscales(c)
end do cCode: Select all
compute test1=%qforminv(rowcv1(1)+rowcv2(1),%xrow(transit2,1)-%xrow(transit1,1))
cdf chisqr test1 nclass-1
