Discrepancy between Simple IRFs and Monte Carlo IRFs
Re: Discrepancy between Simple IRFs and Monte Carlo IRFs
You'll have to post your whole program. (You can do an attachment). You're not showing the procedure call that does the Monte Carlo, so I can't tell why that would fail.
jfwarren
Sorry, here it is
compute nvar = 3
compute nlags = 1
compute nsteps = 100
compute ndraws = 500
system(model=threevar)
var d2lrgdp dprivs dgovs
lags 1 to nlags
det
estimate(noprint,resids=resids)
compute vsigma=%sigma
@Varlagselect(lags=8,crit=aic)
# d2lrgdp dprivs dgovs
@Varlagselect(lags=8,crit=hq)
@Varlagselect(lags=8,crit=sbc)
dec rect lr(3,3) sr(3,3)
input lr
. 0 0
input sr
. 0 .
dec vect[strings] shocklabels varlabels
compute shocklabels=||"Output","Private Savings","Public Savings"||
compute varlabels=||"Real GDP","Private Savings Rate","Public Savings Rate"||
@ShortAndLong(lr=lr,sr=sr,masum=inv(%varlagsums)) %sigma f
compute fd=%xdiag(f)
ewise f(i,j)=f(i,j)/fd(j)
****Point Estimate*****
@varirf(model=threevar,steps=nsteps,factor=f,page=byshock,accum=||1,2,3||,$
shocks=shocklabels,varlabels=varlabels)
****Monte Carlo Simulation****
procedure SRLRDoDraws
option model model threevar
option integer draws 500
option integer steps 100
option vect[int] accum ||1,2,3||
option rect lr
option rect sr
local integer nvar
local rect fxx fwish fsigmad factor
local integer wishdof
local rect betaols betau betadraw
local vect ix
local symm sigmad
local integer i j draw
if .not.%defined(model) {
disp "###SRLRDoDraws(MODEL=model name,other options)"
return
compute nvar=%modelsize(model)
* Standard setup for drawing from an OLS VAR
compute fxx =%decomp(%xx)
compute fwish =%decomp(inv(%nobs*%sigma))
compute wishdof=%nobs-%nreg
compute betaols=%modelgetcoeffs(model)
local rect[series] impulses(nvar,nvar)
* These are global variables
declare vect[rect] %%responses(draws)
infobox(action=define,progress,lower=1,upper=draws) "Monte Carlo Integration"
do draw=1,draws
if %clock(draw,2)==1 {
compute sigmad =%ranwisharti(fwish,wishdof)
compute fsigmad =%decomp(sigmad)
compute betau =%ranmvkron(fsigmad,fxx)
else
compute %modelsetcoeffs(model,betadraw)
* Compute the short-and-long-run factor using the recalculated lag
* sums of the model.
@ShortAndLong(lr=lr,sr=sr,masum=inv(%modellagsums(model))) sigmad factor
impulse(noprint,model=model,factor=factor,results=impulses,steps=steps)
* Accumulate the responses as requested
do i=1,%rows(accum)
do j=1,nvar
acc impulses(accum(i),j) 1 steps
* Store the impulse responses
dim %%responses(draw)(nvar*nvar,steps)
infobox(current=draw)
end do draw
infobox(action=remove)
* Restore the original coefficients
compute %modelsetcoeffs(model,betaols)
end SRLRDoDraws
@SRLRDoDraws(accum=||1,2,3||,steps=nsteps,model=threevar,lr=lr,sr=sr)
*@MCGraphIRF(model=threevar,shocklabels=shocklabels,varlabels=varlabels,page=byshock)
@MCProcessIRF(model=threevar,percentiles=||.16,.84||,center=median,lower=lower,upper=upper,irf=irf)
copy(format=xls,org=columns) / irf lower upper
When I said, take the SRLRDoDraws out of the Bjornland-Leitemo and not change it, I meant exactly. Do not change the values at top---that's what the option fields when you do @SRLRDODRAWS take care of. (Your call seems to be correct). Take what you have now and replace it with what I have below.
option model model
option integer draws 10000
option integer steps 40
option rect lr
option rect sr
local integer nvar
local vect ix
local symm sigmad
return
do draw=1,draws
else
* The rescaling done in the next two lines is specific to this paper
compute fd=%xdiag(factor)
ewise factor(i,j)=factor(i,j)/fd(j)
if %defined(accum) {
do i=1,%rows(accum)
do j=1,nvar
end do draw
end SRLRDoDraws-
jfwarren
Is it possible (and reasonable) to standardise a shock to be a unit shock. I've read a couple of other threads on this and the Handbook for Vector Autoregressions but can't find any examples relevant to the Blanchard-Quah factorisation and when I implement "factor=%impulse(%nvar)" it ignores the long run restriction which is not what I want.
Is there a procedure for this like the Mcvardodrawsunit.src?
What does "unit shock" mean in this situation? You're doing a structural model where all shocks probably hit all variables contemporaneously.
Because this is a linear model, you can always rescale the columns of the factor to achieve different size shocks. You just have to decide what impacts you want. The @MCVARDODRAWSUNIT procedure is for simple unit shocks to each variable.
