I have used the below code setting as suggested in your previous post,
system(model=dLnVAR)
variables dLnVariables
estimate(print)
But the VAR only has a constant in each equation like the one below, is it correct?
1. Constant -0.008946016 0.017575405 -0.50901 0.61092421
Anozman
Codes and output for a VECT model
Re: Codes and output for a VECT model
What else would there be if lags are zero?anozman wrote:Hi Tom,
estimate(print)
Anozman
