MCGRAPHIRF—graphing end for error bands for IRF's
@MCGRAPHIRF organizes graphs for the output from various procedures which draw impulse response functions.
Detailed description
Among examples which use this are:
  1. BOOTVAR.RPF (boot strapping a VAR)
  2. MONTEEXOGVAR.RPF (Monte Carlo integration for a shock to an exogenous variable)
  3. MONTESUR.RPF (Gibbs sampling for a near-VAR)
  4. MONTESVAR.RPF (Gibbs sampling for an overidentified SVAR)
  5. MONTEVAR.RPF (standard Monte Carlo integration for an OLS VAR)
By separating the tasks of generating the impulse responses (done by a variety of methods) and organizing the graphs (done by @MCGRAPHIRF), we can provide greater flexibility in the graphics.
If you want the calculations of the confidence bands without the graphs, use @MCPROCESSIRF.
PTillmann-436
Re: MCGRAPHIRF (graphing end for IRF's)
Unread post by PTillmann-436 »
How can I get the median responses out of the mcgraphirf procedure in order to ACCUMULATE them?
Thank you so much.
Use @MCPROCESSIRF for that. However, you really want to accumulate before computing medians—medians don't have any linearity properties.
zw83189
Unread post by zw83189 »
Hello Tom,
I am using RATS version 9.0 and used @mcgraphirf to generate impulse response. On my y-axis (dependent variable axis) the scale is showing 7 decimal places already. However these numbers are all zero so I would like to increase the number of decimal places. Is there a way to do that?
It might not have much meaning in interpreting such shock, but I just want to get an axis that has significant figure on the scale instead of all zeros.
Many thanks!!!
Re: MCGRAPHIRF—graphing end for error bands for IRF's
@MCGRAPHIRF doesn't have an option for changing the representation of the numbers on the axis. You can always use @MCPROCESSIRF to process the information and do the graphs differently. Are you doing some type of restricted model? In a regular VAR, the responses should never be true zero past the impact.
zw83189
I used a VARX model and shock the exogenous variables and examine the response of endogenous variables. In this case, it is normal to have zero response value after shock?
If the exogenous variable hits all the endogenous variables, no (as long as the lags are non-zero).
Last bumped by TomDoan on Mon Jan 06, 2025 3:55 pm.
