recursive responses from Linear VAR
Since I found unexpected signs for some of the responses obtained from the modified version of the Primiceri code, I would like to compare the responses computed from recursively estimated linear VAR model with the one obtained from Primiceri code.
Is there any available code for this?
Re: recursive responses from Linear VAR
I'm not sure what you're trying to shut down in the Primiceri model. Stochastic volatility? Time variation? Both?ege_man wrote:Dear Tom,
I am still working on the Primiceri code and I will post as soon as I finish it.
I wrote the following code to produce recursive variance decomposition for price (p) and industrial production (ip) to see the evolution of the variance explained by the variables over time. The code is running properly but it produce more than 250 tables for each sample. But I just want to pick the decomposition of the last two variables for only 12th horizon over the sample period. Is it possible to create tables or bar charts using results instruction in Errors procedure? In the current the results obtained from the last VAR model are saved in vardec vector.
ps. I am using RATS version 8.3.
compute lags=2;*Number of lags
compute nstep=12 ;*Number of response steps
open data 2015_fuel_diff.xls
calendar(m) 1992
data(format=xls,org=columns) 1992:2 2013:10
table
compute [vect[strings]] implabel=|| "oil","er", "fuel", "p", "ip"||
do j=1,251
smpl 1992:02 1992:12+j
system(model=fuel)
variables oil er dis pri ip
lags 1 to lags
det constant ffr{1} ipus{1}
estimate(resids=varresids, noprint) 1992:02 1992:12+j
errors(model=fuel, steps=nstep, results=vardec, window="variance decomposition", noprint)
table
Sure, you can pull information about the FEVD out of the VARDEC matrix---that's what the RESULTS option is for.
Thanks. But the current version gives FEVD for only the last VAR. Could you please guide me how to modify the code above?
You'll have to put something inside the loop to put the information that you want somewhere else. Presumably, you would want to fill elements of a VECT[SERIES] with the values that you want.
Here is the modified version of the code using user guide examples. As you see I create two matrices primat and ipmat including the 12th horizon FEVD for each sample. I would really appreciate if you show me how to convert these matrices into series changing over time.
compute nstep=16
calendar(m) 1992
do time=1992:5,2013:10
system(model=fuel)
lags 1 to lags
errors(model=fuel, steps=nstep, results=vardec, noprint)
com i11 = vardec(5,1)(12), i12 = vardec(5,2)(12) , i13 = vardec(5,3)(12) , i14 = vardec(5,4)(12), i15= vardec(5,5)(12)
com [rect[real]] ipmat = ||i11, i12, i13, i14, i15||
dis 'variance decomposition of IP'
dis ipmat
com i11pri = vardec(4,1)(12), i12pri = vardec(4,2)(12) , i13pri = vardec(4,3)(12) , i14pri = vardec(4,4)(12), i15pri= vardec(4,5)(12)
com [rect[real]] primat = ||i11pri, i12pri, i13pri, i14pri, i15pri||
dis 'variance decomposition of PRI'
dis primat
end do time
system(model=fuel)
lags 1 to lags
should be outside the loop, not inside.
As I said, you want to set up a VECT[SERIES] and put the information into element TIME of the members of that. (You could also do a SERIES[VECT], but that's probably not as convenient).
lags 1 to lags
