I tried to run the code on the data provided in the package by your outfit and I found syntax errors. Please find the codes and embedded syntax errors attached.
Tom, I would be very glad if could help in fixing the syntax errors.
Gorgorm
Elder and Serletis(2010) RATS code from Estima
gorgorm
- Elder_Serletis_oil_prices_Real_GDP_codes.txt
- (19.69 KiB) Downloaded 1263 times
Re: Elder and Serletis(2010) RATS code from Estima
The original post describes a workaround for the fact that version 8.0 doesn't have the %MODELLAGMATRIX function.
You might want to ask your department to update the software. There are quite a few recently written programs (particularly for GARCH models and VAR's) that won't work with 8.0 and have no real workarounds.
gorgorm
Thanks Tom,
I would ask the department to buy an upgrade.
