when i run my code, it always say
NO CONVERGENCE IN 42 ITERATIONS
LAST CRITERION WAS 0.0000000
SUBITERATIONS LIMIT EXCEEDED. ESTIMATION POSSIBLY HAS STALLED OR MACHINE ROUNDOFF IS MAKING FURTHER PROGRESS DIFFICULT.
TRY HIGHER SUBITERATIONS LIMIT, TIGHTER CVCRIT, DIFFERENT SETTING FOR EXACTLINE OR ALPHA ON NLPAR.
how can i solve this problem?
i use the trace option
NO CONVERGENCE
Re: NO CONVERGENCE
You can do some preliminary iterations prior to actual optimization and obtain "better" initial guesses. Adding the following line into your maximization specification should work as it is commonly suggested:
(...pmethod=simplex,piters=5...)
