Are those series which are ordinarily modeled with GARCH? Your DBOX and TB1 are showing very, very weak GARCH effects. By contrast, DSTPR has a borderline unstable GARCH process. A DCC model really isn't appropriate for series with such completely different variance dynamics.ChongoA wrote:Good Day Tom,
I am indeed a beginner in DCC-GARCH and need encougement. I modelled a Univariate AR(1) mean models for each series, DCC model for the variance with the following codes and results.
equation(constant) spq dstpr 1 equation(constant) bozq dboz 1 equation(constant) tbq tb1 1 group ar1 spq tbq bozq garch(p=1,q=1,model=ar1,mv=dcc,pmethod=simplex,piter=10,iter=200)
\***** The problem is that I am not sure of the interpretation of the above output, then I do not have the code for Ljungbox test and Bollerslev test, conditional Correlation coefficients. Is there any diagnostic tests for the model above? please help. Sorry for asking too muck I seem not to find answers, been searching for long. Thank you in advance.Code: Select all
MV-GARCH, DCC - Estimation by BFGS Convergence in 80 Iterations. Final criterion was 0.0000000 <= 0.0000100 Monthly Data From 2001:05 To 2014:12 Usable Observations 164 Log Likelihood -80.9807 Variable Coeff Std Error T-Stat Signif ************************************************************************************ 1. Constant 0.010569822 0.002321832 4.55236 0.00000530 2. DSTPR{1} 0.155954869 0.090163092 1.72970 0.08368435 3. Constant 0.439474660 0.058276811 7.54116 0.00000000 4. TB1{1} 0.002277418 0.019985327 0.11395 0.90927387 5. Constant 0.440757291 0.057072721 7.72273 0.00000000 6. DBOZ{1} 0.001996035 0.018854322 0.10587 0.91568855 7. C(1) -0.000022434 0.000015127 -1.48307 0.13805620 8. C(2) 2.529424553 0.347706134 7.27460 0.00000000 9. C(3) 2.561119132 0.345578953 7.41110 0.00000000 10. A(1) 0.411814867 0.143348995 2.87281 0.00406835 11. A(2) 0.377140497 0.135923249 2.77466 0.00552598 12. A(3) 0.375281034 0.135099724 2.77781 0.00547270 13. B(1) 0.761236715 0.062887849 12.10467 0.00000000 14. B(2) 0.004423171 0.019107584 0.23149 0.81693594 15. B(3) 0.004072750 0.019120777 0.21300 0.83132595 16. DCC(1) 0.393664956 0.045142969 8.72040 0.00000000 17. DCC(2) 0.592641482 0.045281987 13.08780 0.00000000
juustone
I´m just quickly returning on my previous subject on multivariate Q-test.
I got now following result:
Multivariate Q(24)= 367.13853
Significance Level as Chi-Squared(96)= 2.45577e-033
Seems that the results are extremely high (Q24) and low (chi). Correct me, if I´m wrong: the model used helps to remove large part of autocorrelation? But I´m still quite insecure about the unusually high results.
In the picture I previously sent (and now again). The first and third (Q24) row show the residuals of series, second and fourth row show the squared residuals of each series. So if I´m using both CCC- and DCC-GARCH -models, I have to calculate Q-stat for both of them (like done in example pic, I suppose) ? How I can calculate squared residuals ?
And again, thanks for your patience dear Tom!
- picture 1.png (66.08 KiB) Viewed 226841 times
You would have to post your program and data set---I'm not sure why you are showing four different MV Q statistics. That result doesn't look promising, though that's a LOT of lags for a test in a GARCH model.juustone wrote:I´m just quickly returning on my previous subject on multivariate Q-test.
@MVARCHTEST is used to test for residual ARCH in a multivariate setting---tests on autocorrelation of squares is for univariate models.
juustone
Here´s the data. I´m using rats 8.2.
The results I posted in previous message was MV-Q between Russia and Kazakhstan.
- countries.xlsx
- (204.8 KiB) Downloaded 10251 times
I need the program, too.
ChongoA
Thank you once again so if DCC is not appropriate which model is?
BEKK would be better, but why do you think any multivariate GARCH model is appropriate when two of the series don't seem to have GARCH properties?ChongoA wrote:Dear Tom,
ChongoA
Thank you Sir,
I am required to run M-GARCH model. I have run BEKK and it looks like this.
How does it look like? Any technical interpretation, does it fit well. I am depending much on the RATs Handbook for ARCH/GARCH I got yesterday. Thank you for your help.
Convergence in 113 Iterations. Final criterion was 0.0000067 <= 0.0000100
Log Likelihood -668.1428
1. Constant 0.03727185 0.00520390 7.16229 0.00000000
2. DSTPR{1} -0.26898769 0.03922757 -6.85711 0.00000000
3. Constant 1.02587988 0.10250179 10.00841 0.00000000
4. TB1{1} -0.01395865 0.03537958 -0.39454 0.69318264
5. Constant 0.58008073 0.10659810 5.44175 0.00000005
6. DBOZ{1} 0.08819554 0.03563103 2.47525 0.01331448
7. C(1,1) 0.03851185 0.00904723 4.25676 0.00002074
8. C(2,1) 0.24700218 0.40154564 0.61513 0.53846983
9. C(2,2) 1.42674325 0.21193262 6.73206 0.00000000
10. C(3,1) 0.26129975 0.32103474 0.81393 0.41568515
11. C(3,2) 1.29048769 0.13354110 9.66360 0.00000000
12. C(3,3) -0.00000114 0.23224824 -4.89322e-006 0.99999610
13. A(1,1) -1.75801393 0.15467734 -11.36568 0.00000000
14. A(1,2) 15.44773786 2.27757033 6.78255 0.00000000
15. A(1,3) -32.48792831 3.69727168 -8.78700 0.00000000
16. A(2,1) 0.00068156 0.00622645 0.10946 0.91283665
17. A(2,2) 1.90535887 0.17084280 11.15270 0.00000000
18. A(2,3) -0.01268327 0.10678046 -0.11878 0.90545048
19. A(3,1) -0.02149820 0.00459926 -4.67427 0.00000295
20. A(3,2) 0.37636796 0.06337034 5.93918 0.00000000
21. A(3,3) 1.72900945 0.11754717 14.70907 0.00000000
22. B(1,1) 0.37874937 0.06365474 5.95006 0.00000000
23. B(1,2) 2.24261950 1.13792680 1.97079 0.04874742
24. B(1,3) 1.60536555 1.80834798 0.88775 0.37467387
25. B(2,1) -0.00601468 0.00235550 -2.55346 0.01066586
26. B(2,2) 0.38554068 0.05982087 6.44492 0.00000000
27. B(2,3) 0.11328014 0.05853471 1.93526 0.05295786
28. B(3,1) 0.01664974 0.00337134 4.93861 0.00000079
29. B(3,2) -0.18480410 0.04188651 -4.41202 0.00001024
30. B(3,3) -0.25748393 0.04485473 -5.74040 0.00000001
juustone
TomDoan wrote:I need the program, too.
system(model=varmodel)
variables lrus lkaz
lags 1 2
estimate(resids=resids) * 2007
compute basesigma=%sigma
@mvqstat(lags=24)
#resids
... so the same as in the example in user´s guide (8) on page 305 and here https://estima.com/ratshelp/index.html? ... edure.html
Those are the residuals from the OLS VAR. The asymptotics for the MV-Q statistic assume homoscedastic residuals. Since you have strongly GARCHed data, that assumption fails and fails badly. If you get results like that from the diagnostic multivariate test, you should be concerned, but not from the residuals before you take into account the GARCH process.
juustone
Thank you!
Can you give any hints how can I now proceed with diagnostics ?
The GARCHMV.RPF program shows standard diagnostics and the GARCH e-course has many examples with interpretation of the results.
I don't know what those other MV Q tests were that you posted earlier, but those looked OK if they were the diagnostics on the jointly standardized residuals.
Not surprisingly, it doesn't look very good as a GARCH model. Have you done the first step of trying to analyze these using univariate GARCH models? Your results are showing all the signs of data that are dominated more by structural breaks than by a GARCH process.ChongoA wrote:Thank you Sir,
How does it look like? Any technical interpretation, does it fit well. I am depending much on the RATs Handbook for ARCH/GARCH I got yesterday. Thank you for your help.Code: Select all
MV-GARCH, BEKK - Estimation by BFGS Convergence in 113 Iterations. Final criterion was 0.0000067 <= 0.0000100 Monthly Data From 2001:05 To 2014:12 Usable Observations 164 Log Likelihood -668.1428 Variable Coeff Std Error T-Stat Signif ************************************************************************************* 1. Constant 0.03727185 0.00520390 7.16229 0.00000000 2. DSTPR{1} -0.26898769 0.03922757 -6.85711 0.00000000 3. Constant 1.02587988 0.10250179 10.00841 0.00000000 4. TB1{1} -0.01395865 0.03537958 -0.39454 0.69318264 5. Constant 0.58008073 0.10659810 5.44175 0.00000005 6. DBOZ{1} 0.08819554 0.03563103 2.47525 0.01331448 7. C(1,1) 0.03851185 0.00904723 4.25676 0.00002074 8. C(2,1) 0.24700218 0.40154564 0.61513 0.53846983 9. C(2,2) 1.42674325 0.21193262 6.73206 0.00000000 10. C(3,1) 0.26129975 0.32103474 0.81393 0.41568515 11. C(3,2) 1.29048769 0.13354110 9.66360 0.00000000 12. C(3,3) -0.00000114 0.23224824 -4.89322e-006 0.99999610 13. A(1,1) -1.75801393 0.15467734 -11.36568 0.00000000 14. A(1,2) 15.44773786 2.27757033 6.78255 0.00000000 15. A(1,3) -32.48792831 3.69727168 -8.78700 0.00000000 16. A(2,1) 0.00068156 0.00622645 0.10946 0.91283665 17. A(2,2) 1.90535887 0.17084280 11.15270 0.00000000 18. A(2,3) -0.01268327 0.10678046 -0.11878 0.90545048 19. A(3,1) -0.02149820 0.00459926 -4.67427 0.00000295 20. A(3,2) 0.37636796 0.06337034 5.93918 0.00000000 21. A(3,3) 1.72900945 0.11754717 14.70907 0.00000000 22. B(1,1) 0.37874937 0.06365474 5.95006 0.00000000 23. B(1,2) 2.24261950 1.13792680 1.97079 0.04874742 24. B(1,3) 1.60536555 1.80834798 0.88775 0.37467387 25. B(2,1) -0.00601468 0.00235550 -2.55346 0.01066586 26. B(2,2) 0.38554068 0.05982087 6.44492 0.00000000 27. B(2,3) 0.11328014 0.05853471 1.93526 0.05295786 28. B(3,1) 0.01664974 0.00337134 4.93861 0.00000079 29. B(3,2) -0.18480410 0.04188651 -4.41202 0.00001024 30. B(3,3) -0.25748393 0.04485473 -5.74040 0.00000001
juustone
Thomas, please accept my apologies for naïve questions.
I was just mixed with different procedures. The example paper I was given and which methods I should replicate in my assignment (only with different data) is quite unclear. It´s said only that first and third row pairs represents residuals of each series while second and fourth row shows the squared residuals of each series (attachment).
I know followed the GARCHMV.RPF example:
Input
Out. there was errors while setting z1 and z2
According to results, used model do not remove the series autocorrelations quite well? Is it same as you got ? And how many lags should be used ?
Thanks again! You have helped me a lot!
Input
group garchm ruseq geoeq
garch(model=garchm,p=1,q=1,pmethod=simplex,piters=10,$
mvhseries=hhs)
garch(p=1,q=1,pmethod=simplex,piters=10,$
hmatrices=hh,rvectors=rd) / lrus lgeo
set z1 = rd(t) (1)/sqrt(hh(t)(1,1))
set z2 = rd(t) (2)/sqrt(hh(t)(2,2))
@bdindtests(number=40) z1
@bdindtests(number=40) z2
dec vect[series] zu(%nvar)
do time=%regstart(),%regend()
compute %pt(zu,time,%solve(%decomp(hh(time)),rd(time)))
end do time
@mvqstat(lags=8)
# zu Code: Select all
MV-GARCH - Estimation by BFGS
Convergence in 61 Iterations. Final criterion was 0.0000000 <= 0.0000100
Daily(5) Data From 2007:03:15 To 2015:04:28
Usable Observations 2119
Log Likelihood -8799.2584
1. Mean(1) 0.061132290 0.032328962 1.89094 0.05863169
2. Mean(2) -0.054176701 0.042469043 -1.27568 0.20207039
3. C(1,1) 0.062626774 0.012656080 4.94835 0.00000075
4. C(2,1) 0.048134039 0.108171860 0.44498 0.65633605
5. C(2,2) 0.080188190 0.017092868 4.69132 0.00000271
6. A(1,1) 0.090363693 0.011203688 8.06553 0.00000000
7. A(2,1) 0.000801563 0.000613797 1.30591 0.19158325
8. A(2,2) 0.074671250 0.008336419 8.95723 0.00000000
9. B(1,1) 0.893161150 0.012220517 73.08702 0.00000000
10. B(2,1) -1.000001932 0.000373692 -2676.00305 0.00000000
11. B(2,2) 0.921209025 0.007972403 115.54973 0.00000000
Error was evaluating entry 2121
Independence Tests for Series Z1
Test Statistic P-Value
Ljung-Box Q(40) 39.725318 0.4825
McLeod-Li(40) 15.332518 0.9999
Turning Points -2.027414 0.0426
Difference Sign -1.805652 0.0710
Rank Test -0.733048 0.4635
Independence Tests for Series Z2
Ljung-Box Q(40) 54.71083 0.0605
McLeod-Li(40) 100.57191 0.0000
Turning Points 2.66313 0.0077
Difference Sign 3.08465 0.0020
Rank Test -3.09000 0.0020
Multivariate Q(8)= 39.10582
Significance Level as Chi-Squared(32)= 0.18091
- Qstat.JPG (50.6 KiB) Viewed 226759 times
I'm really confused about what you're posting. What is Table 10? Your program is for Russia and Georgia, so why are you posting the results for Russia vs large aggregates of other nations?
Your data for Russia and Georgia show almost no relationship between the two---the periods of high volatility are basically disjoint.
