GLS with AR(k) errors
I want to estimate a linear equation by GLS with AR(k) errors:
y(t) = a + b x(t) + e(t),
where e(t) is an AR(k) series
Are there program codes available? Thanks.
Re: GLS with AR(k) errors
Use BOXJENK with the GLS option (under "Options for REGARIMA Models").
If one of the regressors is lagged y, y(t-1), is it still OK? Thanks.
No. You can't freely estimate a model like that. That's actually saying that Y is an AR(4) which means that there are four different identically fitting ways to write it as an AR(1) with AR(3) errors.
How about using MA(k) errors? Same problem?
Potentially different problem with cancellation if the error process isn't anywhere near that complicated. Is there a reason that you're not just fitting a minimal ARMA model?
