Helping with code of Primiceri (2005)
NgocAnh
Post by NgocAnh »
Hello!
I'm trying to use the TVP-VAR with Stochastic Volatility used in Primiceri (2005). I changed everything I thought I should (and I could) but after running to the @VARTVPKSC it said that there were not enough data in the training sample to fit prior.
Where should I change the setting? I attached my data file as well as the code. I'm using monthly data of domestic price, export price and exchange rate in 8 industries (1~8).
My RATs version is 9.0
Thank you.
dis %ratsversion()
dis %dateandtime()
comp dropexpl = 0           ;* 0 to not drop explosive draws in MCMC
comp ndraws = 8000          ;* number of draws retained. total draws = burndraws + ndraws*skipinterval
comp burndraws = 5000
comp skipinterval = 2       ;* set this to 1 to not skip any draws in what is retained
comp usemedians = 1         ;* 1 to use posterior medians in most charts, 0 to use posterior means
comp commonscale = 0        ;* 1 to impose common scale in impulse response plots, 0 to not
grparm header 18 subheader 18 keylabeling 16
env nowshowgraphs gsave="repPrimiceri_*.rgf" gformat=rgf
comp nvar = 3               ;* number of variables in VAR
comp fixlags = 2            ;* fixed lag order in model
comp styr = 1980
cal(m) styr:1
comp stsmpl = styr:1
comp endsmpl = 2014:12  ;* "endsmpl" is the last observation period.
all stsmpl endsmpl
smpl stsmpl endsmpl
comp seedval = 44*48
seed seedval
******************************** reading in Koop's data
open data DataSet.2015.07.21.xls
data(for=xls,org=col) /	ipi dp1 dp2 dp3 dp4 dp5 dp6 dp7 dp8 ex1 ex2 ex3 ex4 ex5 ex6 ex7 ex8 neer1 neer2 $
neer3 neer4 neer5 neer6 neer7 neer8
close
take the first diference of logarithm of each variables
set x3 = ex6
set x1 = log(neer6)
set x2 = dp6
set dx1 = x1 - x1{1}
set dx2 = x2 - x2{1}
set dx3 = x3 - x3{1}
** for storing variable names, allocate label vector and order position of real variable
** IT'S A STRUCTRUAL VAR: different order of varibles give different outcome
dec vec[string] varlabels(nvar)
dec vec[ser] y(nvar)
comp k = 0
dofor i = dx1 dx2 dx3
 comp k = k+1
 set y(k) = i{0}
 comp varlabels(k) = %l(i)
******************************** setting data sample, and weighting energy inflation
comp prenobs = 60   ;*Previous number of observation = 5 years
comp stpt = 1985:3
comp endpt = endsmpl
******************************** setting dimensions and prior stuff
******************************** Priors are same as in Primiceri.
sou(noecho) VARTVPKSC.src
** prior on VAR coefs (not used in this example)
dec vec meanfirstlag(nvar)
comp  meanfirstlag = %const(0.)
** prior on time variation in coefficients (mean and IW df)
comp Q_priordf = prenobs
comp  Q_priorscale = .0001
** prior on time variation in each equation's A coefficients (mean and IW df)
**   (equation 1 stuff here not actually used)
dec vec[int] S_priordf(nvar)
do i = 1,nvar
 comp S_priordf(i) = i
comp  S_priorscale = .01
** prior on time variation in log volatilities, which are log st devs (mean and IW df)
comp priordfPhi = nvar+1
dec symm muPhi(nvar,nvar)
comp muPhi = %mscalar(0.0001)
** prior variance of initial value of volatility (mean set by procedure)
dec symm OmegaDelta0(nvar,nvar)
comp OmegaDelta0 = %mscalar(1.)
******************************** OLS estimation, full and pre-sample, just as checks
system(model=varmodel)
variables y
lags 1 to fixlags
************ full sample
estimate(noftests) stpt endpt
comp compcoef = %modelcompanion(varmodel)
eigen(cvalues=cxvals,sort=absval) compcoef
dis 'largest eigen value in full sample = ' %real(%cabs(cxvals(1)))
comp OLSsigma = %sigma  ;* will use this below to set fixed, common size of shocks
************ training sample
estimate(noftests) stpt-prenobs stpt-1
dis 'largest eigen value in training sample = ' %real(%cabs(cxvals(1)))
******************************** estimation, along with reporting of a limited set of posterior statistics
comp meanfirstlag = %const(.0)
comp cbar = .001
@VARTVPKSC(prmean,prinit,inclconst,doRsq,nodropexpl,noinformprior) y stpt endpt prenobs fixlags ndraws burndraws skipinterval meanfirstlag Q_priordf Q_priorscale $
   S_priordf S_priorscale muDelta0 OmegaDelta0 muPhi priordfPhi cbar PiRes ARes Qres PhiRes LambdaRes stdevRes SRes RsqRes
dis %dateandtime()
datafile
(226.5 KiB) Downloaded 1190 times
Re: Helping with code of Primiceri (2005)
Your 1985:3 isn't allowing for the data point lost to differencing. Change STPT to 1985:4 and it will work.
NgocAnh
Post by NgocAnh »
Yes, it works!!! Finally it worked with your help.
Thank you so much, Tom. I wish you and your colleagues all the bests.
Best regard,
ege_man
Post by ege_man »
When I run the following code I get the following error message. I am using rats version 9. I also attached the data for your check.
Thanks for your help
largest eigen value in training sample = 0.52767
NOT ENOUGH DATA IN TRAINING SAMPLE TO FIT PRIOR
09/02/2015 00:09
The Error Occurred At Location 279, Line 15 of loop/block
58158168 Position 5089
************ This program, coupled with the procedure VARTVPKSC.src estimates the
************  VAR with time-varying parameters and stochastic volatility of
************  Giorgio Primiceri, (2005), "Time Varying Structural Vector Autoregressions and Monetary Policy,"
************  Review of Economic Studies, 72, 821-852.
************ The program and procedure were written by Todd Clark, todd.e.clark@kc.frb.org
dis %ratsversion()
dis %dateandtime()
comp commonscale = 1        ;* 1 to impose common scale in impulse response plots, 0 to not
comp nvar = 6               ;* number of variables in VAR
comp fixlags = 1            ;* fixed lag order in model
comp styr = 1985
cal(m) styr:2
comp stsmpl = styr:2
comp endsmpl = 2015:4  ;* "endsmpl" is the last observation period.
all stsmpl endsmpl
smpl stsmpl endsmpl
seed seedval
open data 2015_expass.xlsx
data(for=xlsx,org=col) / loil	lindpro	ler	lm	lwpi	lcpi
close
comp k = 0
dofor i = loil	lindpro	ler	lm	lwpi	lcpi
 comp k = k+1
 set y(k) = i{0}
comp prenobs = 72
comp stpt = 1991:2
do i = 1,nvar
variables y
lags 1 to fixlags
comp cbar = .001
dis %dateandtime()
******************************** extraction of various results of interest for intercepts and VAR slope coefs
********** computing means of each variable implied by model (all draws)
comp ncoef = fixlags*nvar+1  ;* # of coefficients in each equation
dec vec[rec] means_all(nvar)
do i = 1,nvar
  dim means_all(i)(ndraws,endpt)
dec vec pivec(nvar*ncoef) compmeans compinterc
dec rec compcoef idenmatrix
** just to set some dimensions and avoid repetitive calcs
comp idenmatrix = %identity(%rows(compcoef))
comp compinterc = %zeros(%rows(compcoef),1)
do draws = 1,ndraws
 do vtime = stpt,endpt
  ** assigning model coefs, and set up companion form coefs
  do i = 1,nvar*ncoef
   comp pivec(i) = pires(draws,i)(vtime)
  comp %modelsetcoeffs(varmodel,%vectorect(pivec,ncoef))
  ** compute means
  do i = 1,nvar
   comp compinterc(i) = pivec(i*ncoef)
  comp compmeans = inv(idenmatrix - compcoef)*compinterc
  ** storage of computed means
  do i = 1,nvar
    comp means_all(i)(draws,vtime)  = compmeans(i)
 end do vtime
end do draws
********** forming sums of AR coefs (all draws)
dec rec[rec] sar(nvar,nvar) ;* rows:  equations; columns: variables
do i = 1,nvar
 do j = 1,nvar
  dim sar(i,j)(ndraws,endpt)
comp xpi = %zeros(fixlags,1) ;* for pulling coefs for variable i in equation j
comp [vec] pikeep = %zeros(ncoef*nvar,1)
do i = 1,ndraws
 do j = stpt,endpt
  do ii = 1,ncoef*nvar
   comp pikeep(ii) = pires(i,ii)(j)
  end do ii
  do ii = 1,nvar
   do jj = 1,nvar
     comp xpi = %xsubvec(pikeep,(ii-1)*ncoef+(jj-1)*fixlags+1,(ii-1)*ncoef+jj*fixlags)
     comp sar(ii,jj)(i,j) = %sum(xpi)
   end do jj
  end do ii
********** forming posterior means and 70% intervals for sums of AR coefs
smpl stpt endpt
dec rec[ser] sarmean(nvar,nvar) sar15(nvar,nvar) sar85(nvar,nvar)
clear sarmean sar15 sar85
smpl 1 ndraws
  do i = 1,nvar
   do j = 1,nvar
    set(scratch) statser = sar(i,j)(t,vtime)
    stats(noprint,fractiles) statser
    comp [vec] frac = %fractiles(statser,||.15,.5,.85||)
    comp sarmean(i,j)(vtime) = %if(usemedians==1,%median,%mean)
    comp sar15(i,j)(vtime) = frac(1)
    comp sar85(i,j)(vtime) = frac(3)
end do vtime
********** forming posterior means and 70% interval for intercepts of each equation, and implied means
smpl stpt endpt
dec vec[ser] intercept_mean(nvar) intercept_15(nvar) intercept_85(nvar)
dec vec[ser] means_mean(nvar) means_15(nvar) means_85(nvar)
clear intercept_mean intercept_15 intercept_85 means_mean means_15 means_85
smpl 1 ndraws
  do i = 1,nvar
   set(scratch) statser = PiRes(t,i*ncoef)(vtime)
   comp intercept_mean(i)(vtime) = %if(usemedians==1,%median,%mean)
   comp intercept_15(i)(vtime) = frac(1)
   comp intercept_85(i)(vtime) = frac(3)
   set(scratch) statser = means_all(i)(t,vtime)
   comp means_mean(i)(vtime) = %if(usemedians==1,%median,%mean)
   comp means_15(i)(vtime) = frac(1)
   comp means_85(i)(vtime) = frac(3)
end do vtime
******************************** extraction of various results of interest relating to stochastic volatility
********** forming posterior means and 70% intervals for elements of A
smpl stpt endpt
dec vec[ser] Amean A15 A85
if nvar>1
  dim Amean(nvar*(nvar-1)/2) A15(nvar*(nvar-1)/2) A85(nvar*(nvar-1)/2)
  clear Amean A15 A85
endif
if nvar>1
smpl 1 ndraws
  do i = 1,nvar*(nvar-1)/2
    set(scratch) statser = ARes(t,i)(vtime)
    comp Amean(i)(vtime) = %if(usemedians==1,%median,%mean)
    comp A15(i)(vtime) = frac(1)
    comp A85(i)(vtime) = frac(3)
end do vtime
endif
********** forming posterior means and 70% intervals for structural and reduced form shock st devs
smpl stpt endpt
dec vec[ser] Deltamean Delta15 Delta85 stdevmean stdev15 stdev85
dim Deltamean(nvar) Delta15(nvar) Delta85(nvar) stdevmean(nvar) stdev15(nvar) stdev85(nvar)
clear Deltamean Delta15 Delta85 stdevmean stdev15 stdev85
smpl 1 ndraws
  do i = 1,nvar
    set(scratch) statser = sqrt(LambdaRes(t,i)(vtime))
    comp Deltamean(i)(vtime) = %if(usemedians==1,%median,%mean)
    comp Delta15(i)(vtime) = frac(1)
    comp Delta85(i)(vtime) = frac(3)
    set(scratch) statser = stdevRes(t,i)(vtime)
    comp stdevmean(i)(vtime) = %mean   ;* just force mean, to because that is what Koop reports, even though he reports medians of imp resp
    *comp stdevmean(i)(vtime) = %if(usemedians==1,%median,%mean)
    comp stdev15(i)(vtime) = frac(1)
    comp stdev85(i)(vtime) = frac(3)
end do vtime
********** forming posterior means and 70% intervals for R2
smpl stpt endpt
dec vec[ser] r2mean(nvar) r215(nvar) r285(nvar)
clear r2mean r215 r285
smpl 1 ndraws
  do i = 1,nvar
    set(scratch) statser = RsqRes(t,i)(vtime)
    comp r2mean(i)(vtime) = %if(usemedians==1,%median,%mean)
    comp r215(i)(vtime) = frac(1)
    comp r285(i)(vtime) = frac(3)
end do vtime
******************************** dimensioning stuff used below in impulse responses, etc.
comp nstep = 16        ;* number of impulse response steps
dec vec shocksize(nvar) scalefact(nvar)
comp shocksize = %sqrt(%xdiag(OLSsigma)) ;* fixed shock size considered in IR's, based on full sample shock sizes
comp [vec[int]] impdates = ||1994:1,2001:4,2015:1||
comp nimp = %rows(impdates)         ;* number of periods for which I compare impulse responses
dec vec[str] datestring(nimp)
do i = 1,nimp
 comp datestring(i) = %datelabel(impdates(i))
dec rec[rec] responses(nimp,ndraws)     ;* matrix for storing draws of impulse responses based on recursive
comp [symm] Lambdamat = %zeros(nvar,nvar)
dec symm Sigma
comp Amat = %identity(nvar)
******************************** computing impulse responses, using draws of VAR coefs and A (fixed shock size)
do count = 1,nimp
 comp vtime = impdates(count)
 do draws = 1,ndraws
  dim responses(count,draws)(nvar*nvar,nstep)
  ** setting A and Sigma matrices
  comp pos = 0
  do i = 2,nvar
   do j = 1,i-1
    comp pos = pos + 1
    comp Amat(i,j) = ARes(draws,pos)(vtime)
  comp invAmat = inv(Amat)
  do i = 1,nvar
   comp Lambdamat(i,i) = LambdaRes(draws,i)(vtime)
  comp Sigma = %mqform(Lambdamat,tr(invAmat))
  comp swish = %decomp(Sigma)
  ** assigning model coefs, and computing impulse responses
  do i = 1,nvar*ncoef
  impulse(model=varmodel,decomp=swish,steps=nstep,results=impulses,noprint)
  ** storage in "impulses":  series i,j is the response of variable i to a shock to j
  ** storing CHOLESKI-BASED responses. RESPONSES, cols 1-nvar:  response of each variable to shock 1; cols 2-nvar:  resp of each var to shock 2; etc
  ewise responses(count,draws)(i,j)=impulses(%clock(i,nvar),(i-1)/nvar+1)(j)
 end do draws
 ************ now normalize the responses for this period to make the average shock sizes the same across time (= full sample OLS size)
 ** compute scaling factors from median shock sizes, Choleski
 do i = 1,nvar
  set statser 1 ndraws = responses(count,t)((i-1)*nvar+i,1)
  stats(fractiles,noprint) statser 1 ndraws
  comp scalefact(i) = shocksize(i)/%median
 ** now do the rescaling
 do draws = 1,ndraws
  do k = 1,nstep
   do i = 1,nvar
    do j = 1,nvar
     comp responses(count,draws)((i-1)*nvar+j,k) = responses(count,draws)((i-1)*nvar+j,k)*scalefact(i)
  end do k
 end do draws
end do count
******************************** charts
********** global settings for charts
smpl stpt endpt
if usemedians==1
  comp [vec[string]] mykey_full = ||'median','15%ile','85%ile'||
  comp [vec[string]] mykey_short = ||'median'||
else
  comp [vec[string]] mykey_full = ||'mean','15%ile','85%ile'||
  comp [vec[string]] mykey_short = ||'mean'||
endif
if nvar==5.or.nvar==6
  comp vf = 2
  comp hf = 3
else if nvar==3.or.nvar==4
  comp vf = 2
  comp hf = 2
endif
if nvar==7.or.nvar==6
  comp vf_a = 2
  comp hf_a = 3
else if nvar==5.or.nvar==4
  comp vf_a = 2
  comp hf_a = 2
else
  comp vf_a = 2
  comp hf_a = 1
endif
********** charts:  sums of coefs -- means and percentiles
do i = 1,nvar
 comp subheader = 'equation for ' + varlabels(i)
 spgraph(vfields=vf,hfields=hf,header='TVP-VAR:  sums of coefficients',subheader=subheader)
 do j = 1,nvar
  comp header = 'lags of variable: ' + varlabels(j)
  graph(dates,header=header,key=below,klab=mykey_full) 3
  # sarmean(i,j) / 1
  # sar15(i,j) / 2
  # sar85(i,j) / 2
********** charts:  intercepts -- means and percentiles, and then just equation means
list meancard = 1 to nvar
spgraph(vfields=vf,hfields=hf,header='TVP-VAR:  intercepts for each equation')
do i = 1,nvar
  comp header = 'equation for ' + varlabels(i)
  # intercept_mean(i) / 1
  # intercept_15(i) / 2
  # intercept_85(i) / 2
spgraph(vfields=vf,hfields=hf,header='TVP-VAR:  means or medians for each variable')
do i = 1,nvar
  comp header = varlabels(i)
  # means_mean(i) / 1
  # means_15(i) / 2
  # means_85(i) / 2
graph(dates,header='TVP-VAR:  means or medians for all variables together',key=below) nvar
cards means_mean(meancard)
********** charts:  A coefs and percentiles
if nvar>1
comp pos = 0
do i = 2,nvar
 comp header = 'TVP-VAR:  A coefficients, equation for ' + varlabels(i)
 spgraph(vfields=vf_a,hfields=hf_a,header=header)
 do j = 1,i-1
  comp pos = pos + 1
  comp header = 'coef on ' + varlabels(j)
  # Amean(pos) / 1
  # A15(pos) / 2
  # A85(pos) / 2
endif
********** charts:  residual standard deviations, structural vs reduced form
spgraph(vfields=vf,hfields=hf,header='TVP-VAR:  residual standard deviations')
do i = 1,nvar
  set reducedform = stdevmean(i){0}
  set structural = Deltamean(i){0}
  graph(dates,header=header,key=below,klab=||'reduced form','structural'||) 2
  # reducedform
  # structural
  dis '****************** reduced form and structural residual standard deviations of ' varlabels(i)
  print / reducedform structural
********** charts:  residual standard deviations, reduced form with 70 pct bands
spgraph(vfields=vf,hfields=hf,header='TVP-VAR:  reduced form st devs and 70pct interval')
do i = 1,nvar
  # stdevmean(i)
  # stdev15(i) / 2
  # stdev85(i) / 2
********** impulse responses based on Choleski ID:  displaying estimates and creating one chart comparing all inflation responses over time
dec vec[series] upper(nvar) lower(nvar) resp(nvar)
smpl 1 nstep
clear upper lower resp
*** change some graph settings to make things more readable in the impulse response charts (therefore, we want response charts to come last)
grparm(bold) hlabel 16 matrixlabels 14 header 18
grparm  axislabel 36
do count = 1,nimp
 dis ''
 dis '************************************************'
 dis '************************************************ impulse responses for' %datelabel(vtime)
 comp header = 'Impulse responses: ' + %datelabel(vtime)
 do i = 1,nvar
  comp subheader = 'shock to ' + varlabels(i)
  do j=1,nvar
   comp [string] chartheader = 'response of ' + varlabels(j)
   smpl 1 ndraws
   do k=1,nstep
      set(scratch) work   1 ndraws = responses(count,t)((i-1)*nvar+j,k)
      stats(noprint,fractiles) work 1 ndraws
      compute frac=%fractiles(work,||.15,.85||)
      compute lower(j)(k)=frac(1)
      compute upper(j)(k)=frac(2)
      compute resp(j)(k)=%if(usemedians==1,%median,%mean)
   end do k
  dis '*********** posterior means/medians of responses to shock in ' varlabels(i)
  print(nodates) 1 nstep resp
  dis '*********** 15th percentile of responses to shock in ' varlabels(i)
  print(nodates) 1 nstep lower
  dis '*********** 85th percentile of responses to shock in ' varlabels(i)
  print(nodates) 1 nstep upper
end do count
** now do plot comparing responses over time to inflation shock
smpl 1 nstep
if usemedians==1
 comp subheader = '(posterior medians)'
else
 comp subheader = '(posterior means)'
endif
********** charts:  impulse responses, all for a given time period on a single page
do count = 1,nimp
 spgraph(header=header,subheader='(point estimates with 70% bands)',xpos=both,xlab=varlabels, $
        ylab=varlabels,vlab="Responses of",hlab="Shocks to",vfields=nvar,hfields=nvar)
 * Because we want a common scale for all responses of a single variable, we need
 * to do all the calculations for a full row of graphs first.
 * dec vect[series] upper(nvar) lower(nvar) resp(nvar)
 do i=1,nvar
    compute minlower=maxupper=0.0
    smpl 1 ndraws
    do j=1,nvar
       clear lower(j) upper(j) resp(j)
       do k=1,nstep
          set(scratch) work   1 ndraws = responses(count,t)((j-1)*nvar+i,k)
       end do k
       compute maxupper=%max(maxupper,%maxvalue(upper(j)))
       compute minlower=%min(minlower,%minvalue(lower(j)))
    smpl 1 nstep
    do j=1,nvar
       if commonscale==1
         graph(ticks,min=minlower,max=maxupper,number=0) 3 j i
         # resp(j)
         # upper(j) / 2
         # lower(j) / 2
       else
         graph(ticks,number=0) 3 j i
         # resp(j)
         # upper(j) / 2
         # lower(j) / 2
end do count
dis %dateandtime()
In setting this:
comp stpt = 1991:2
you're either not allowing for the data point lost to using a lag or not allowing for the fact that you data start in :2 not :1. It needs to be 1991:3 (or later). (Note that the preliminary VAR over the training range shows one missing observation).
ege_man
Post by ege_man »
I am plannig to estimate the same model based on quarterly data. I get the following error this time. Is it because of limited number of observations? N=131
mean of S (var-cov of innovations to A, one matrix per equation) for equation  2
st dev of S (var-cov of innovations to A, one matrix per equation) for equation  2
mean of S (var-cov of innovations to A, one matrix per equation) for equation  3
st dev of S (var-cov of innovations to A, one matrix per equation) for equation  3
mean of S (var-cov of innovations to A, one matrix per equation) for equation  4
st dev of S (var-cov of innovations to A, one matrix per equation) for equation  4
mean of S (var-cov of innovations to A, one matrix per equation) for equation  5
st dev of S (var-cov of innovations to A, one matrix per equation) for equation  5
mean of S (var-cov of innovations to A, one matrix per equation) for equation  6
st dev of S (var-cov of innovations to A, one matrix per equation) for equation  6
Q mean, simplified to a matrix of variances, one column for each equation =
## MAT17. Can't Use Row Range of 1 to 0 in %XDIAG operation
The Error Occurred At Location 11337, Line 662 of VARTVPKSC
dis %ratsversion()
dis %dateandtime()
comp dropexpl = 1         ;* 0 to not drop explosive draws in MCMC
comp skipinterval = 0       ;* set this to 1 to not skip any draws in what is retained
comp styr = 1982
cal(q) styr:2
comp endsmpl = 2014:4  ;* "endsmpl" is the last observation period.
all stsmpl endsmpl
smpl stsmpl endsmpl
seed seedval
open data 2015_expass_q_sept_2.xlsx
data(for=xlsx,org=col) / OIL	GAP	ER	M	WPI	CPI
close
comp k = 0
dofor i = OIL	GAP	ER	M 	WPI	CPI
 comp k = k+1
 set y(k) = i{0}
comp prenobs = 32
comp stpt = 1991:1
do i = 1,nvar
variables y
lags 1 to fixlags
comp cbar = .001
dis %dateandtime()
do i = 1,nvar
do draws = 1,ndraws
  do i = 1,nvar*ncoef
  ** compute means
  do i = 1,nvar
  do i = 1,nvar
 end do vtime
end do draws
do i = 1,nvar
 do j = 1,nvar
do i = 1,ndraws
 do j = stpt,endpt
  end do ii
  do ii = 1,nvar
   do jj = 1,nvar
   end do jj
  end do ii
smpl stpt endpt
smpl 1 ndraws
  do i = 1,nvar
   do j = 1,nvar
end do vtime
smpl stpt endpt
smpl 1 ndraws
  do i = 1,nvar
end do vtime
smpl stpt endpt
if nvar>1
  clear Amean A15 A85
endif
if nvar>1
smpl 1 ndraws
end do vtime
endif
smpl stpt endpt
smpl 1 ndraws
  do i = 1,nvar
end do vtime
smpl stpt endpt
smpl 1 ndraws
  do i = 1,nvar
end do vtime
comp [vec[int]] impdates = ||1995:1,2001:2,2008:1||
do i = 1,nimp
dec symm Sigma
do count = 1,nimp
 do draws = 1,ndraws
  comp pos = 0
  do i = 2,nvar
   do j = 1,i-1
    comp pos = pos + 1
  do i = 1,nvar
  do i = 1,nvar*ncoef
 end do draws
 do i = 1,nvar
 do draws = 1,ndraws
  do k = 1,nstep
   do i = 1,nvar
    do j = 1,nvar
  end do k
 end do draws
end do count
smpl stpt endpt
if usemedians==1
else
endif
  comp vf = 2
  comp hf = 3
  comp vf = 2
  comp hf = 2
endif
  comp vf_a = 2
  comp hf_a = 3
  comp vf_a = 2
  comp hf_a = 2
else
  comp vf_a = 2
  comp hf_a = 1
endif
do i = 1,nvar
 do j = 1,nvar
  # sarmean(i,j) / 1
  # sar15(i,j) / 2
  # sar85(i,j) / 2
do i = 1,nvar
do i = 1,nvar
  # means_mean(i) / 1
  # means_15(i) / 2
  # means_85(i) / 2
if nvar>1
comp pos = 0
do i = 2,nvar
 do j = 1,i-1
  comp pos = pos + 1
  # Amean(pos) / 1
  # A15(pos) / 2
  # A85(pos) / 2
endif
do i = 1,nvar
  # reducedform
  # structural
do i = 1,nvar
  # stdevmean(i)
  # stdev15(i) / 2
  # stdev85(i) / 2
smpl 1 nstep
grparm  axislabel 36
do count = 1,nimp
 dis ''
 do i = 1,nvar
  do j=1,nvar
   smpl 1 ndraws
   do k=1,nstep
   end do k
end do count
smpl 1 nstep
if usemedians==1
else
endif
do count = 1,nimp
 do i=1,nvar
    smpl 1 ndraws
    do j=1,nvar
       do k=1,nstep
       end do k
    smpl 1 nstep
    do j=1,nvar
       if commonscale==1
         # resp(j)
         # upper(j) / 2
         # lower(j) / 2
       else
         # resp(j)
         # upper(j) / 2
         # lower(j) / 2
end do count
dis %dateandtime()
(19.03 KiB) Downloaded 1154 times
ege_man
Post by ege_man »
I would like to also produce the responses like "FIGURE 7 Interest rate response to a 1% permanent increase of unemployment" in the original paper of primiceri (2005) on page 839. Could you please tell me which matrix or vector includes the responses at different horizons over time? If I obtain those responses, I can also plot 3d surface graphs instead of 2d like in the other TVP-VAR papers.
ege_man wrote:Dear Tom,
This can't be 0
ege_man
Post by ege_man »
Thanks for your quick reply what about my second question? is it possible to save the responses over time at different horizons?
Regards
Isn't that all done as part of Todd Clark's original program?
ege_man
Post by ege_man »
As I understand there are some figures about the sum of coefficients and standard deviations of the variables, but Figures 4, 5,6 and 7 related to visualization of the time-varying responses over time with error bands are not included in the original code. I would like also retain only the responses of the last three variable in the attached graph but I don't know how to do it.
Regards
impulse_2001.RGF
(22.01 KiB) Downloaded 1239 times
I see impulse responses with error bands at three different dates.
ege_man
Post by ege_man »
Instead of only three dates, I would like to produce responses for each time period like the figures I mentioned in the original paper.
Regards
That shouldn't be that hard. Just adapt the calculation of the IRF's that's there and save the desired horizon responses into series.
Zied_bct
Post by Zied_bct »
dear tom
How to choice the optimal lag in TVP-VAR model ? is the same method in Standar VAR ?
