Variation explained by the first principal component
RK2509
I performed principal component analysis for a set of 72 food prices. I estimated the first two principal components. But I want to know the percentage of variation explained by the first two principal components. Is there any specific command for that in RATS ?
Many Many Thanks
Many Many Thanks
RK2509
Re: Variation explained by the first principal component
So, if I get something like this using prinfactors
Sample Output:
Principal Components Analysis
Eigenvalue 2.607649 1.071584 0.568616 0.451315 0.300836
Proportion 0.521530 0.214317 0.113723 0.090263 0.060167
Cumulative 0.521530 0.735847 0.849570 0.939833 1.000000
Eigenvector -0.427633 -0.341113 0.837079 0.001756 0.008203
-0.459893 -0.356458 -0.380141 -0.704282 0.144622
-0.451115 -0.385464 -0.389227 0.704231 0.021777
-0.478567 0.469467 -0.045824 -0.052077 -0.738757
-0.416049 0.622573 0.034557 0.073012 0.657861
Does the row 'proportion' explain the percentage of variation corresponding to each eigenvalue? So here this would mean the first principal component explains 52 percent of the variation? what does the row "cumulative" explain?
Thank you so much.
Sample Output:
Thank you so much.
Proportion is the proportion attributable to that component alone. Cumulative is the sum of all components from 1 to that components.
RK2509
Many Many Thanks.
