Forecast with NLLS
yelena
Forecast with NLLS
Unread post by yelena »
I have written the code for the NLLS with the restrictions on the parameters but now need to use it to forecast the dependent variable. But my code does not work? Could you please help me again?
Thank you.
nonlin(parmset=fullset) a0 a1 a2 a3 a3>=0
frml dpndfrml DEPENDENT = a0 + a1 * YOY%_SP500 + a2 * BAA{2} + a3 * YOY%_OIL{2}
compute a0 = 1.0
compute a1 = 1.0
compute a2 = 1.0
compute a3 = 1.0
nlls(frml=dpndfrml, parmset=fullset,cvcrit=0.0001, iterations=1000, method=gauss) DEPENDENT sambeg samend residModXLG8_11 coefModXLG8_11
group dpndfrml_f dpndfrml
forecast(model=dpndfrml_f, from=2015:02, steps=9, print) forecast
Re: Forecast with NLLS
What does "not work" mean? Offhand, looking at this, I'm wondering where the out-of-sample values for the three explanatory variables are supposed to come from.
yelena
The out-of-sample variables come from the Excel file open data "U:\SSSI\Severity_Index_NV_Yelena\DFAST_BHC_2015\Data_Macro_DFAST.xlsx"
I have found another way to program the forecast. Is it correct?
nonlin(parmset=fullset) a0 a1 a2 a3 a4 a5 a6 a7 a8 a9 a10 a3=beta3 a5=beta5 a7=beta7
frml dpndfrml_d DEPENDENT = a0 + a1 * YOY%_SP500+a2 * BAA{2} + a3 * YOY%_OIL{2} + a4 * YOY%_CPI + a5 * TR10Y{1} + a6 * YOY%_HPI{1} + a7 * TR3M + a8 * YOY%_CRE + a9 * UR + a10 * DEPENDENT{1}
compute a0 = 1.0
compute a1 = 1.0
compute a2 = 1.0
compute a3 = 1.0
compute a4 = 1.0
compute a5 = 1.0
compute a6 = 1.0
compute a7 = 1.0
compute a8 = 1.0
compute a9 = 1.0
compute a10 = 1.0
nlls(frml=dpndfrml_d, parmset=fullset,cvcrit=.00001, iterations=1000, method=gauss) DEPENDENT sambeg samend residModXLG9_11 coefModXLG9_11
set DEPENDENT_EST_8 sambeg samend = %beta(1) + %beta(2) * YOY%_SP500{1} + %beta(3) * BAA{2} + %beta(4) * YOY%_OIL{2} $
+ %beta(5) * YOY%_CPI + %beta(6) * TR10Y{1} + %beta(7) * YOY%_HPI{1} + %beta(8)*TR3M + %beta(9)* YOY%_CRE + %beta(10) * UR + %beta(11) * DEPENDENT{1}
compute alpha0_nlls_d = %beta(1)
dis 'alpha0_nlls_d = ' alpha0_nlls_d
compute alpha1_nlls_d = %beta(2)
dis 'alpha1_nlls_d = ' alpha1_nlls_d
compute alpha2_nlls_d = %beta(3)
dis 'alpha2_nlls_d = ' alpha2_nlls_d
compute alpha3_nlls_d = %beta(4)
dis 'alpha3_nlls_d = ' alpha3_nlls_d
compute alpha4_nlls_d = %beta(5)
dis 'alpha4_nlls_d = ' alpha4_nlls_d
compute alpha5_nlls_d = %beta(6)
dis 'alpha5_nlls_d = ' alpha5_nlls_d
compute alpha6_nlls_d = %beta(7)
dis 'alpha6_nlls_d = ' alpha6_nlls_d
compute alpha7_nlls_d = %beta(8)
dis 'alpha7_nlls_d = ' alpha7_nlls_d
compute alpha8_nlls_d = %beta(9)
dis 'alpha8_nlls_d = ' alpha8_nlls_d
compute alpha9_nlls_d = %beta(10)
dis 'alpha9_nlls_d = ' alpha9_nlls_d
compute alpha10_nlls_d = %beta(11)
dis 'alpha10_nlls_d = ' alpha10_nlls_d
equation(coeffs=||alpha0_nlls_d,alpha1_nlls_d,alpha2_nlls_d,alpha3_nlls_d,alpha4_nlls_d,alpha5_nlls_d,alpha6_nlls_d, alpha7_nlls_d, $
alpha8_nlls_d, alpha9_nlls_d, alpha10_nlls_d||) dpndfrmleq_d DEPENDENT
# constant YOY%_SP500{1} BAA{2} YOY%_OIL{2} YOY%_CPI TR10Y{1} YOY%_HPI{1} TR3M YOY%_CRE UR DEPENDENT{1}
uforecast(equation=dpndfrmleq_d, from=2015:02, steps=9, print) forecast_nlls_d
Also, Tom, I need to run rubosterrors with NLLS. How to add this option?
The original idea should work---you never explained what you meant by it not working. Yes, given that it's linear, you can create an EQUATION and use UFORECAST. You could have simplified that considerably by just using EQUATION(COEFFS=%BETA,...) rather than copying the %BETA information into a bunch of separate variables.
Just add the ROBUSTERRORS option to the NLLS.
yelena
Oh, great! Thank you, Tom! It worked!
