Both use a threshold value that is a function of the current step of the procedure. The procedure also allows the user to force certain variables to stay in the regression through a second supplementary card. In my example code below, this is used to ensure the constant remains in the regression.
procedure lutkephol dep_var begin_samp end_samp criterion method print
type series dep_var
type integer begin_samp end_samp
option choice criterion 1 aic sbc hq
option choice method 1 basic topdown
option switch print 0
local equation exog_vars
equation exog_vars *
local equation exog_vars_keep
equation exog_vars_keep *
if criterion == 1 {
frml cT = 2.0
else if criterion == 2 {
frml cT = 2.0 * log(t)
else if criterion == 3 {
frml cT = 2.0 * log(log(t))
report(action = define, use = lutreport, hlabels = ||"Iteration", "Regressor", "t-stat", "threshold"||)
compute tbl_keep = %eqntable(exog_vars_keep)
compute rl = %rlfromeqn(exog_vars)
cmoment(noprint) begin_samp end_samp
# dep_var rl
compute min_tstat = %na
compute critical_value = %na
compute iter = 0
until min_tstat > critical_value {
compute iter = iter + 1
linreg(cmom, noprint, define = eq) dep_var begin_samp end_samp
# rl
compute T = %nobs
compute K = %nreg
compute tbl = %eqntable(eq)
* determine which regressors can be dropped
declare vector[integer] free_to_drop(K)
compute idx_free_to_drop = %tablefindmiss(tbl, tbl_keep)
dofor i = idx_free_to_drop
compute free_to_drop(i) = 1
end dofor idx_free_to_drop
if method == 2 {
* topdown
do i = 1, K
* if we've already determined that the variable can't be
* dropped because it was passed in the second card, skip
* to the next variable
if free_to_drop(i) == 0 {
next
compute s = tbl(1, i)
compute lag = tbl(2, i)
compute idx_of_next_lag = %tablefind(tbl, s, lag + 1)
* if the regression contains the next lag of series s,
* then the current lag cannot be dropped
if idx_of_next_lag > 0 {
compute free_to_drop(i) = 0
ewise %tstats(i) = %if(free_to_drop(i) == 0, %na, abs(%tstats(i)))
compute idx_of_min_tstat = %minindex(%tstats)
compute min_tstat = %tstats(idx_of_min_tstat)
compute critical_value = sqrt((exp(cT(T)/T) - 1)*(T-K+iter-1))
if min_tstat < critical_value {
compute var_to_drop = %tableextract(tbl, ||idx_of_min_tstat||)
compute new_tbl = %tableextract(tbl, %tablefindmiss(tbl, var_to_drop))
compute rl = %rlfromtable(new_tbl)
compute regressors = %eqnreglabels(eq)
report(action = modify, use = lutreport, row = new, atcol = 1) iter regressors(idx_of_min_tstat) min_tstat critical_value
report(action = modify, use = lutreport, row = new, atcol = 1) iter "-complete-" min_tstat critical_value
report(action = format, use = lutreport, atcol = 1, tocol = 1, align = center)
report(action = format, use = lutreport, atcol = 2, tocol = 2, align = left)
report(action = format, use = lutreport, atcol = 3, tocol = 4, align = decimal, picture = "##.####")
if print {
report(action = show, use = lutreport)
compute %eq = eq
compute %iterations = iter
calendar(q) 1969 1
source(echo) "lutkephol.src"
compute max_lags = 8
open data "data.xls"
data(format = xls, org = columns) /
close data
@lutkephol(criterion = aic, method = basic, print) lgdpk 1969:1 2006:4
# lgdpk{1 to max_lags} lcdk{1 to max_lags} ffedk{1 to max_lags} $
lresinvk{1 to max_lags} lpotgdpk{1 to max_lags} constant
# constant
linreg(create, equation = %eq, print)
