Loading/Compiling Procedures
alexecon
MacRATS won't let me use a procedure and churns out the dreaded "## CP18. MYPROC is not the Name of a PROCEDURE. (Did you forget to SOURCE?)". MYPROC is in the procedures folder, has a .src file extension. I have SOURCE'd it manually, too. Any ideas?
Re: Loading/Compiling Procedures
Can you post a copy of that?
alexecon
I have replaced the (three) linreg commands in BaiPerron.src with linreg(robusterrors,lags=4,lwindow=quadratic,...). Saved it with another name ("baiperronrobust.src").
I'm calling the procedure with the following to get the Bai-Perron test results for a model with just a constant.
The code works fine up to and including @lsunit. But it does not like @baiperronrobust...OPEN DATA "/[...]/Monthly.xls"
CALENDAR(M) 2001:1
DATA(FORMAT=XLS,ORG=COLUMNS,LEFT=1) 2001:01 2014:12 sers1
SOURCE "c:/Applications/RATS 9.0/Procedures/baiperron.src"
@LSUNIT(LAGS=8,MODEL=CRASH,BREAKS=2,METHOD=GTOS) SERS1
@baiperronrobust(maxbreaks=3,minspan=24,tests,noprint) SERS1
# constant
source path\baiperron.src won't get a procedure that's on baiperronrobust.src.
alexecon
No, of course it won't!
But this does not appear to be the problem, as RATS generates the same error message for even the correctly sourced procedures. Anyway, I will insist until I find the problem.
- The name of the file must be exactnameofprocedure.src (case insensitive)
- It needs to be on a directory on the procedure search path
- You need to make sure you rename the actual procedure the way you want.
alexecon
OK, the problem was that I'd forgotten to change the name of the procedure IN BaiPerron.src. So, RATS was correctly informing me that I was calling a procedure that did not exist.
EDIT: just seen your response: it was number 3 in this case!
