MSVARSetup - Markov Switching VAR (obsolete)
This is a set of procedures and functions for estimating Markov switching VAR's. There's a short example which demonstrates its uses below the main procedure file (which is called msvarsetup.src).
(A newer version of this was posted on 16 July 2008 under a different thread).
* Procedure file for Markov switching VAR's. This includes several functions, as described below.
* @MSVARSetup( options )
* # list of dependent variables
* Options:
*   LAGS=# of VAR lags [1]
*   STATES=# of states [2]
*   SWITCH=[MEANS]/INTERCEPTS
*     SWITCH=MEANS is the Hamilton type model where the mean of the series is state-dependent.
*     SWITCH=INTERCEPTS has the intercept term in each VAR equation being state dependent.
*  This creates the following variables which will generally need to be put into a parmset and
*  estimated:
*   P   = nstates-1 x nstates Markov transition matrix
*   MU  = VECTOR[VECTOR] of means/intercepts. MU(j) is the mean/intercept vector at state j
*   PHI = VECTOR[RECT] of lag coefficients. PHI(j) is the N x N vector of lag coefficients for
*         lag j
*   SIGMA = SYMMETRIC (covariance matrix)
*  It also sets up the following:
*    Y = VECT[SERIES] of dependent variables
*    PT_T,PT_T1 and PSMOOTH are SERIES[VECT] used for computing and saving the state probabilities
*    LAGSTATE,TRANSIT,TP,VARINTERCEPT and PSTAR are working matrices
* @MSVARInitial
*   computes initial guess values for a model already set up
* @MSVARProb(time)
*   computes the (not logged) likelihood of the model at "time" for the current set of
*   parameters
* @MSVARInit()
*   does the calculations needed at the start of each function evaluation
* Revision Schedule:
*   05/07 Written by Tom Doan, Estima
procedure MSVARSetup
option integer lags	 1
option integer states 2
option choice  switch 1 means intercepts
dec rect[integer] lagstate
dec rect p
dec rect[integer] transit
dec vect tp
dec vect pstar
dec vect[vect] mu
dec vect[rect] phi
dec vect[symm] sigmav
dec symm sigma
dec vect pstar
dec series[vect] pt_t pt_t1 psmooth
dec vect[series] y
dec vect[vect] varintercept
local vect[int] yvec
local integer i j
enter(varying) yvec
compute nvar   =%rows(yvec)
compute nstates=states
compute nlags  =lags
dim y(nvar)
do i=1,nvar
   set y(i) = yvec(i){0}
* If the means of the series are switching, the number of states for the mean of
* the data is nstates**(nlags+1), since we have to cover every possible
* combination. If we're only switching coefficients in the VAR directly, there
* will only be nstates distinct possibilities.
if switch==1
   compute nexpand=nstates**(nlags+1)
else
* lagstate(i,j) is a lookup table for the state of expanded state "i" at lag j-1.
dim lagstate(nexpand,nlags+1)
ewise lagstate(i,j)=1+%mod((i-1)/nstates**(nlags+1-j),nstates)
* We also create a mapping from state to state which will pick out the transition
* probability. transit will be a number from 1 to nstates**2+1. 1 is the most
* common value, which represents a zero transition probability. For instance, in a
* two state setting with current + four lags, if we're in (1,1,2,2,1), the only
* states which can be obtained are {1,1,1,2,2} and {2,1,1,2,2}. The transition
* probability to the first of these would be p(1,1), and for the second it would be
* 1-p(1,1). Given our coding, it's easy to tell whether a state can be obtained from
* another, since the final nlags spots of the new state have to be the same as the
* lead nlags spots of the old state.
dim transit(nexpand,nexpand) tp(1+nstates**2)
if switch==1
   ewise transit(i,j)=fix(%if(%mod(i-1,nstates**nlags)==(j-1)/nstates,nstates*(lagstate(i,1)-1)+lagstate(j,1)+1,1))
else
   ewise transit(i,j)=(i-1)*nstates+j+1
* The transition probabilities are parameterized as an nstates-1 x nstates matrix.
* Each column gives the transition probabilities out of a particular state to the
* first nstates-1 states.
dim p(nstates-1,nstates) pstar(nexpand)
dim mu(nstates) phi(nlags) sigmav(nstates) varintercept(nexpand)
ewise mu(i) =%zeros(nvar,1)
ewise phi(i)=%zeros(nvar,nvar)
ewise varintercept(i)=%zeros(nvar,1)
procedure MSVARInitial
local integer i j l
local model olsmodel
local rect crect
do i=1,nvar
   stats(noprint,fractiles) y(i)
   if nstates==2 {
      compute mu(1)(i)=%fract90
      compute mu(2)(i)=%fract10
   else
   if nstates==3 {
      compute mu(2)(i)=%median
      compute mu(3)(i)=%fract10
system(model=olsmodel)
variables y
lags 1 to nlags
estimate(noprint)
compute crect=%modelgetcoeffs(olsmodel)
do i=1,nvar
   do l=1,nlags
      do j=1,nvar
         ewise phi(l)(i,j)=crect((j-1)*nlags+l,i)
   end do l
if nexpand==nstates
   ewise mu(i)=%modellagsums(olsmodel)*mu(i)
ewise sigmav(i)=%sigma
compute sigma=%sigma
ewise p(i,j)=%if(i==j,.8,.1/(nstates-1))
function MSVARProb time
type real MSVARProb
type integer time
local integer i j
local vect u p f fp
local real sp fpt
dim f(nexpand) p(nexpand)
compute u=%xt(y,time)
do j=1,nlags
   compute u=u-phi(j)*%xt(y,time-j)
do i=1,nexpand
   compute f(i)=exp(%logdensity(sigmav(lagstate(i,1)),u-varintercept(i)))
do i=1,nexpand
   compute sp=0.0
   do j=1,nexpand
      compute sp=sp+tp(transit(i,j))*pstar(j)
   compute p(i)=sp
compute pt_t1(time)=p
compute fp=f.*p
compute fpt=%sum(fp)
compute pstar=fp*(1.0/fpt)
compute pt_t(time)=pstar
compute MSVARProb=fpt
function MSVARProbEM time
type real MSVARProbEM
type integer time
local integer i j
local vect u f
local real fpt
dim f(nexpand)
do j=1,nlags
do i=1,nexpand
compute fp=f.*psmooth(time)
compute MSVARProbEM=%sum(fp)
function MSVARInit
type vector MSVARInit
local rect a
local integer i j row col
ewise tp(i)=row=(i-2)/nstates+1,col=%clock(i-1,nstates),$
  %if(i==1,0.0,%if(row==nstates,1-%sum(%xcol(p,col)),p(row,col)))
if nexpand==nstates
   ewise varintercept(i)=mu(i)
else {
   do i=1,nexpand
      compute varintercept(i)=mu(lagstate(i,1))
      do j=1,nlags
         compute varintercept(i)=varintercept(i)-phi(j)*mu(lagstate(i,j+1))
ewise sigmav(i)=sigma
dim a(nexpand+1,nexpand)
ewise a(i,j)=%if(i>nexpand,1.0,(i==j)-tp(transit(i,j)))
compute MSVARInit=%xcol(inv(tr(a)*a)*tr(a),nexpand+1)
Example
source msvarsetup.src
frml msvarf = log(MSVARProb(t))
open data wbc.xls
calendar(q) 1960
data(format=xls,org=columns) 1960:01 1991:04 usa can uk frg jap aus d73q3
set dusa = usa-usa{1}
set djap = jap-jap{1}
set dfrg = frg-frg{1}
set duk  = uk-uk{1}
set dcan = can-can{1}
set daus = aus-aus{1}
@msvarsetup(lags=1)
# dusa djap dfrg duk dcan daus
* With the mu's and phi's, you have to list the elements explicitly when defining
* the parmset. (NONLIN won't accept a VECT[VECT] or VECT[RECT]).
nonlin(parmset=msparms) p
nonlin(parmset=varparms) mu(1) mu(2) phi(1) sigma
@msvarinitial
compute gstart=1962:1,gend=1991:4
gset pt_t  gstart gend = %zeros(nexpand,1)
gset pt_t1 gstart gend = %zeros(nexpand,1)
compute t1=%cputime()
maximize(parmset=varparms+msparms,start=(pstar=MSVARInit()),reject=%minvalue(tp)<0.0,method=bfgs,iters=400) msvarf gstart gend
disp %cputime()-t1
syaznie
Post by syaznie »
What version of RATS can be used to execute the procedure?
6.3 has the REJECT option on MAXIMIZE, which probably is unnecessary in most cases with two states. (It makes the function value NA if any of the transition probabilities goes out of range). Besides that, it needs 6.20.
Roddy Dog
Post by Roddy Dog »
How can I edit this procedure so I can incorporate a lagged error correction term and estimate a Markov-switching vector error correction model?
What's "switching" in the VECM?
Roddy Dog
MS-VECM
Post by Roddy Dog »
The switching occurs with respect to the coefficients on the lagged dependent variables as well as the lagged error correction term.
See. for example, Kanas, A., and Tsiotas, G. 2005. Real Interest Rates Linkages between the USA and the UK in the Postwar Period. International Journal of Finance and Economics 10 (3), 251-262 and in particular, pages 254-5.
FilipinoEconomist
Post by FilipinoEconomist »
How about MS-SVAR a la Rubio-Ramirez, Waggoner, Zha (2005)?
