choosing k from real values
Moderator: TomDoan
vtsa
Dear Tom Doan,
I have a question about how to choose k from the real values. I have a rpf in which the code is written as follows:
dec vector[series] mean(26)
com lmax = 36
set trend = t
dec vector[integer] reglist
compute reglist = || constant| trend ||
dec vector[series] sine(10) dsine(10)
dec vector[series] cosine(10) dcosine(10)
com header$ = || 'Series' | 'k' | 'Tau' | 'F-value' | 'DF' | 'Lags'| 'T'||
report(action=define,hlab=header$)
com i = 23
sta(noprint) [series]i ; com cap_T = %nobs , start = 1961:2+612-%nobs
do k = 1,3
set sine(k) = sin(2.*%pi*k*t/%nobs) ; dif sine(k) / dsine(k)
set cosine(k) = cos(2.*%pi*k*t/%nobs) ; dif cosine(k) / dcosine(k)
end do k
I want to choose k from the range [0.1,0.2,0.3,...,2.8,2.9,3.0]. But do loop selects k from integer values. How can I change the code in order to select k from the real values such as [0.1,0.2,0.3,...,2.8,2.9,3.0].
I willl appreciate your response,
Kind Regards,
com lmax = 36
set trend = t
com i = 23
do k = 1,3
end do k
Kind Regards,
Re: choosing k from real values
DOFOR with %SEQA looks like it is what you need. For instance, one of the examples on that page uses a doubly nested grid using this:
dec real lower upper
dofor lower = %seqa(-.2,.1,5)
dofor upper = %seqa(1.6,.1,5)
sweep(group=(thresh>=lower)+(thresh>upper))
# spread
# constant spread{1 2}
compute rss=%scalar(%sigma)
if rss<rssbest
compute lowerbest=lower,upperbest=upper,rssbest=rss
end dofor upper
end dofor lower
vtsa
Dear Tom Doan,
When I changed the code and run the program, I got the following message:
Subscripting Error. Had Array Reference with (). Needed (INTEGER)
>>>> set sine(k) <<<<
I couldn’t solve this problem. Could You advise me how to change the code to run the program.
I will appreciate your response,
Thank You in advance.
calendar(q) 1987:01
allocate 2015:04
open data cad.rat
data(format=rat,org=columns) / cad
set y = cad
graph
# y
table
Series Obs Mean Std Error Minimum Maximum
CAD 116 -2.5887029528 3.2252496038 -9.8292520000 4.8927893830
Y 116 -2.5887029528 3.2252496038 -9.8292520000 4.8927893830
*dec vector[series] mean(26)
*com lmax = 36
set trend = t
dec real k
com i = 2
sta(noprint) [series]i ; com cap_T = %nobs , start = 1987:2+116-%nobs
dofor k = %seqa(0.1,.1,50)
end dofor k
>>>> set sine(k) <<<<
This will adapt the number of elements of the VECT[SERIES] to the number of elements in the sequence.
compute kf=%seqa(0.1,.1,50)
dec vect[series] sine(%sizef(kf)) dsine(%size(kf)) cosine(%size(kf)) dcosine(%size(kf))
do k = 1,%size(kf)
set sine(k) = sin(2.*%pi*kf(k)*t/%nobs) ; dif sine(k) / dsine(k)
set cosine(k) = cos(2.*%pi*kf(k)*t/%nobs) ; dif cosine(k) / dcosine(k)
end do k-
vtsa
fractional single k frequency
I set up a fourier program that chooses fractional (not integer) value of k from the interval 0.1<k<2.0 where I select k=0.1 as increments of the selected frecuencies. I just want to be sure that I set up the program correctly. if there is anything wrong, please can you correct my mistakes.
The file is attached.
Kind regards!
Kind regards!
That looks like it would work fine---you can check fairly easily by just displaying the kf(k) value and %rss in the loop and verifying that it's finding the minimizer.
There's actually an easier to way to do that now with FIND with the METHOD=GRID.
compute kf=%seqa(0.05,.2,20)
nonlin kk
find(trace,method=grid,grid=||kf||) min %rss
set sin1 = sin((2*%pi/nobs)*kk*t)
set cos1 = cos((2*%pi/nobs)*kk*t)
linreg(noprint) y ; # constant sin1 cos1
end find
prj fit
graph 2
# fit
# y-
vtsa
Great!
Thank You very much.
