Flipper with MONTESVAR_MH
allister
Hi Tom
I have a quick question regarding the use of flipper with MONTESVAR and MONTESVAR_MH, do the results using flipper for the IRF differ using MONTESVAR and MONTESVAR_MH?
The reason why I am asking is that I am trying to use flipper with MONTESVAR_MH but for some reason it doesn't work. I am not sure if its due to the sample size or the my poor coding.
allister
Re: Flipper with MONTESVAR_MH
HI Tom
let go ahead and post my code, can you look over the code and make sure everything is kosher? I ran the code and everything was okay however can you one more look at it for me please?
- svar brexit4.RPF
- (6.4 KiB) Downloaded 911 times
If the intent is to have the impact of the first shock on the first variable being negative, then that should do that. What does "not work" mean? If you don't get reasonable looking error bands out of one (or both) methods, then you need to play with the tuning parameters.
allister
Thanks for advice for Tom . I will let you know if this works out.
