Hey Tom,
sorry to bother you again with stupid questions. Your help is highly appreciated!
I need to bootstrap some M-tests for unit roots using "wild bootstrapping" as it is done, for instance, in the paper "BOOTSTRAP UNIT ROOT TESTS
FOR TIME SERIES WITH NONSTATIONARY VOLATILITY" by Cavaliere and Taylor, Econometric Theory, 2008.
Before I am starting to write my own programs, I was wondering whether there is already some code available for the M-tests or the wild bootstrapping method? I couldn't find anything alike but I guess there are some parts I could "recycle". So, if some program comes immediately to your mind where I find parts of that code, please be so kind as to point out to me which one this is.
Thanks a lot!
Best wishes
Anna
Wild Bootstrapping
Re: Wild Bootstrapping
The wild bootstrap is a fairly simple modification on the standard bootstrap. There are several variations on this, but the idea is that you multiply the resampled residuals by an independent mean zero, variance 1 process: a +/-1 coin flip being one possibility.
open data tablef9-2[1].txt
data(format=prn,org=columns) 1 25 valueadd capital labor nfirm
set logy = log(valueadd)
set logk = log(capital)
set logl = log(labor)
linreg logy / resols
# constant logk logl
linreg(smpl=t<>4.and.t<>10) logy
rreg logy / reslad
compute betalad=%beta
prj fitted
compute [vector] bboot=%zeros(%nreg,1)
compute [symm] bsq =%zeros(%nreg,%nreg)
* for wild bootstrap with +/-1 with equal probabilities
compute pwild=.5,[vector] vwild=||-1.0,1.0||
* for skewed bootstrap
*compute pwild=(sqrt(5)+1)/sqrt(20),[vector] vwild=||(1-sqrt(5))/2,(1+sqrt(5))/2||
do i=1,5000
boot entries
* Standard residual bootstrap
* set yx = fitted+reslad(entries(t))
* Wild bootstrap.
set yx = fitted+reslad(entries(t))*vwild(%ranbranch(||pwild,1-pwild||))
rreg(noprint) yx
compute bsq =bsq +%outerxx(%beta-betalad)
disp "Bootstrapped standard errors" %sqrt(%xdiag(bsq*(1.0/5000)))
