@MONTEVAR computes and graphs error bands for impulse response functions for a VAR using Monte Carlo simulation. This assumes the model is a symmetric VAR estimated using the ESTIMATE instruction. By default, @MONTEVAR does a Cholesky factorization, though it can easily be adapted to other situations by using the FFUNCTION option to provide a function to compute an alternative factorization.
This combines the functions of @MCVARDODRAWS and @MCGRAPHIRF for simple models. If you need more options (for instance, more flexibility on the graphs), use those.
Detailed Description
MONTEVAR—Monte Carlo integration for standard VAR
Last bumped by TomDoan on Fri Aug 02, 2024 11:22 am.
