An error using maximize function
Re: An error using maximize function
This is covered in Section 4.15 of the User's Guide. You can't start in 1975:1 because there are no lags for u and h. (You also have to make sure that your guess values allow the function to be computed).
Is there any significant "GARCH" effect in that data? There usually is at best a weak GARCH effect in quarterly data, and if there is no GARCH, there is no "M" effect.
