Balke(2000) Threshold VAR
Re: Balke(2000) Threshold VAR
No. The evidence in favor of a threshold isn't very strong given the number of additional parameters required in the non-linear model.
Thanks Tom, appreciate the quick turnaround. It is clear.
Another question if I may. I am trying to create the IRF for my 3 variable VAR ( GDP, Spending and Tax) using as a threshold an external variable ( output gap).
For some reasons, when I run the program I get this error message " ## SR10. Missing Values And/Or SMPL Options Leave No Usable Data Points
The Error Occurred At Location 316, Line 9 of loop/block "
Do you see any issue there ( I haven't changed the code much) and I am using 1st difference for all variables for my 3-variable-VAR to achieve stationarity.
Appreciate your help ( IRF program and Excel are attached)
Best
Best
- Bach_TVAR_IRF.RPF
- (9.15 KiB) Downloaded 1141 times
- FISCAL_3var_Final.xls
- (32 KiB) Downloaded 805 times
This is using the old threshold variable on the second lineBach wrote:Thanks Tom, appreciate the quick turnaround. It is clear.
Best
equation(identity,coeffs=macoeffs) threqn GAPthr
# gdp{0 to malength-1}
HI Tom ,
Thanks again for your response.
I have couple of quick questions , if I may.
(a) I am looking at Balke's paper and see that graphs of the tight regime are generated using the command upper =1. I am not clear about the reason since my understanding is that under the tight regime, the credit ( threshold variable) is expected to be below the threshold and thus the lower regime should be the one selected (i.e. upper =0), Am I missing something in my reasoning ?
(b) I am assuming that IRF program uses a recursive SVAR model ( in the ordering of the variables below), rather than a standard VAR correct ?
Thanks in advance
compute depvars =||d1y,d1p,money,credit||Re: Balke(2000) Threshold VAR
That depends upon what the credit measure is. In the example, it's the spread between commercial paper and the t-bill rate, where tight would mean higher values.Bach wrote:HI Tom ,
Correct.Bach wrote: (b) I am assuming that IRF program uses a recursive SVAR model ( in the ordering of the variables below), rather than a standard VAR correct ?
Thanks Tom for the quick response.
I have a follow up question .Is it normal to have Balke and Tsay approaches producing two different threshold results?
And, is there a way to replicate the result of the Balke threshold value using the TSay approach ?
It depends. The Tsay usrates example uses var=homogeneous, and Balke uses var=heterogeneous. That will give you different results. Tsay uses an equally spaced grid search, Balke uses the empirical values of the threshold series. That will give you different results. The use of the grid makes more sense in the Tsay example where he has over 400 entries and is looking for double breaks, while Balke has about 140 and is looking for a single break (though both of these were done 20 or so years ago, so what might have seemed infeasible then wouldn't be now). Both are picking the likelihood maximizing break value so if you use the same likelihood (variance option on the SWEEP) and test for the same possible break points, you'll get the same results.
kinogutschein
Dear Mr. Doan,
I am working on a TVAR with 2 regimes and 4 variables: GDP, Consumer Prices, interest rates and uncertainty.
I didnt change the code much. For the lower regime (upper=0) I receive reasonable results. However, once I switch to the upper regime (upper=1), I receive the following error message:
## FO19. Forecast for LGER_GDP solves to NA at 1997:06, on iteration 1.
The Error Occurred At Location 784, Line 40 of loop/block
I get this message for every variable in my TVAR. I am not sure what causes this error. I have added both code and data to this post.
Thank you for your concern.
- Daten.xlsx
- Data
- (106.81 KiB) Downloaded 777 times
- TVAR.RPF
- (12.12 KiB) Downloaded 1175 times
I get a problem right away with this when you do the diagnostics:
dofor i = 1 2 3 4 5
dofor lag = 1 2 3 4 5 6
@regcorrs(noprint,dfc=%narma,number=lag,qstats,nograph, method=burg,title="AR(4) model diagnostics;RGDP") resids(i)
disp "Gleichung" i "Lag" lag #.### %Qsignif
end dofor
end dofor
since you have only 4 series. You might want to pull the definition of NVAR up higher (right after the ESTIMATE) and run those dofor i's over 1 to NVAR so it will adapt to the number of series in the model.
You also have a problem here, where you didn't adapt to the 4 variable system:
* This is application specific. A different number of variables requires
* a different list of the tvarf's.
group tvar tvarf(1) tvarf(2) tvarf(3) tvarf(4) tvar(5) thrfrml
I suspect that you sent me something other than the one that's giving you the posted difficulty since what you sent doesn't run at all.
dofor i = 1 2 3 4 5
end dofor
end dofor
kinogutschein
Thank you for your advice. This was actually the Code that I intended to send. I wasn't aware of the first issue you mentioned. Regarding the second issue I thought I corrected it already, thank you. I reviewed the Code that I attached to this post and now it should be correct. As I mentioned before, for upper=0 it gives reasonable results. If changed to upper=1, the beforementioned Errors happen. Am I missing something? Thanks for your concern.
- Daten.xlsx
- (106.81 KiB) Downloaded 811 times
- TVAR.RPF
- (12.06 KiB) Downloaded 1163 times
Your GER_GDP data ends before the end of your intended sample. When you bootstrap, that can pull the NA's into the initial range---it probably only affects the upper branch because those are *in* only the upper branch.
Is that possible to estimate a VAR with inclusion of exogenous variable and let this variable be the threshold indicator?
e.g.
e.g.
system(model=varmodel)
variables d1y d1p money
lags 1 to maxlag
det constant credit
end(system)Re: Balke(2000) Threshold VAR
Partially yes. The estimation would be effectively the same. However, the IRF's are completely different because with an exogenous variable governing the switch, you can compute only the regime-specific IRF's (which is a simpler calculation).
Hi
Is there any reference on how to generate regime-specific IRF with RATS?
There's nothing special about it. It's just a standard IRF (done with IMPULSE). With an exogenous threshold variable, you get two separate linear models rather than one non-linear one.
