GARCHVIRFDIAG.RPF shows how to compute VIRF's as defined in Hafner and Herwartz(2006) for models that use CC or DCC. The VIRF's as defined in HH require a GARCH model which can be put in "VECH" form (such as BEKK). However, you can extrapolate the variances alone (not the covariances) using the same theory if the variances admit a recursion involving only lagged variances and lagged squared residuals (own and possibly cross terms). This requires use of the @MVGARCHVarMats procedure to pull the recursion matrices out of the GARCH output.
mvgarchvarmats.src
The data set is one used in GARCHMV.RPF and other examples.
Detailed Description
GARCHVIRFDiag—VIRF's for GARCH with CC/DCC
Last bumped by TomDoan on Tue Aug 13, 2024 9:38 am.
