Unassignes 613 error
carlosvillarreal
Post by carlosvillarreal »
I'm trying to run a program but apparently I have an error. Rats shows the next message.
## Unassigned 613
The Error Occurred At Location 0838
Line 42 of loop/block
Could you please to explain me how to find the exactly location of my mistake. When I have a loop, does Rats count the blink-lines?
I let you the loop and thanks for your help.
*****MATRIZ LAMNDA
dec rec xsi_11(k,dim_lam) xsi_1(n*g*k,dim_lam)
compute xsi_1 = %const(.0), xsi_11 = %const(.0)
dec vec e_p(nlags)
do ll = 1,nlags
compute e_p(ll) = ll**(-0.5)
display e_p(ll) %rows(e_p) %cols(e_p)
dec vec e_p1(p1)
do ll = 1,p1
compute e_p1(ll) = ll**(-0.5)
display e_p1(ll) %rows(e_p1) %cols(e_p1)
dec vec e_d(d1) e_ng(n*g) e_ngp(n*g*p+d1*p1) xsi11(k) xsi1_1(n*g*k)
compute e_ng = %const(1.), e_d = %const(1.)
display e_ng %rows(e_ng) %cols(e_ng) e_d %rows(e_d) %cols(e_d)
if dim_lam==1
compute xsi11(k) = 1
comp engp = %kroneker(e_ng,e_p)
display engp %rows(engp) %cols(engp)
comp edp = %kroneker(e_d,e_p1)
display edp %rows(edp) %cols(edp)
do j = 1,n*g*p
comp e_ngp(j) = engp(j,1)
display e_ngp(j)
do j = 1,d1*p1
comp e_ngp(n*g*p+j) = edp(j,1)
display e_ngp(n*g*p+j) %rows(e_ngp) %cols(e_ngp)
do j = 1,n*g*p+d1*p1
compute xsi11(j) = e_ngp(j)
display xsi11(j) %rows(xsi11) %cols(xsi11)
comp xsi1_1 = %kroneker(e_ng,xsi11)
display xsi1_1 %rows(xsi1_1) %cols(xsi1_1)
do j = 1,N*g*k
compute xsi_1(j,1) = xsi1_1(j)
display xsi_1(j,1)  %rows(xsi_1) %cols(xsi_1)
***Ahora se configura escenario de Europa VS el resto del mundo
*Es decir, cuando la dimensión de lamnda (componentes comunes-predeterminados) es igual a 2
if dim_lam==2
do j = 1,d1*p1
comp xsi_11(n*g*p+j,1) = xsi_11(n*g*p+j,2) = e_p1(j)
comp xsi_11(k,1) = xsi_11(k,2) = 1.
do j = 1,g
do ll = 1,p
comp xsi_11((j-1)*p+ll,1) = e_p(ll)
do j = 1,g
do ll = 1,p
comp xsi_11(g*p+(j-1)*p+ll,1) = e_p(ll)
do j = 1,g
do ll = 1,p
comp xsi_11(2*g*p+(j-1)*p+ll,2) = e_p(ll)
do j = 1,g
do ll = 1,p
comp xsi_11(3*g*p+(j-1)*p+ll,1) = e_p(ll)
do j = 1,g
do ll = 1,p
comp xsi_11(4*g*p+(j-1)*p+ll,2) = e_p(ll)
do j = 1,g
do ll = 1,p
comp xsi_11(5*g*p+(j-1)*p+ll,2) = e_p(ll)
do j = 1,g
do ll = 1,p
comp xsi_11(6*g*p+(j-1)*p+ll,1) = e_p(ll)
do j = 1,g
do jj = 1,k
comp xsi_1((j-1)*k+jj,1) = xsi_11(jj,1)
do j = 1,g
do jj = 1,k
comp xsi_1(g*k+(j-1)*k+jj,1) = xsi_11(jj,1)
do j = 1,g
do jj = 1,k
comp xsi_1(3*g*k+(j-1)*k+jj,1) = xsi_11(jj,1)
do j = 1,g
do jj = 1,k
comp xsi_1(6*g*k+(j-1)*k+jj,1) = xsi_11(jj,1)
do j = 1,g
do jj = 1,k
comp xsi_1(2*g*k+(j-1)*k+jj,2) = xsi_11(jj,2)
do j = 1,g
do jj = 1,k
comp xsi_1(4*g*k+(j-1)*k+jj,2) = xsi_11(jj,2)
do j = 1,g
do jj = 1,k
comp xsi_1(5*g*k+(j-1)*k+jj,2) = xsi_11(jj,2)
end if
*display xsi_1 %rows(xsi_1) %cols(xsi_1)
Re: Unassignes 613 error
First, you need to see what's up with your error message file. There should be a ratserrs.msg file in the same directory as the executable. 613 is a store into bad address. The 43 count includes blanks, so it's almost certainly the
line. The xsi_11 array and xsi_1 arrays look like their dimensions are reversed.
carlosvillarreal
Thanks for your answer. Now I have a little problem i don't know how to find. i got the file about error you told me, but i can't to find which one is the matrix's problem.
I got a ##MAT15 but I don't know how to find where is the problem.
I let you the code and data.
Thank you so much for your help.
Link for data:
https://www.dropbox.com/s/ba9f56w5v1933 ... o.xls?dl=0
Code
*Se importan los datos
OPEN DATA "Z:\Users\Icaro\Dropbox\Trabajo de Grado Maestría\Datos\Alianza Pac%EDfico\var_ap.xls"
CALENDAR 1951
ALL 2011:01
DATA(FORMAT=XLS,ORG=COLUMNS) 1951:01 2011:01 rgdpo_CHL emp_CHL inf_CHL ck_CHL ctfp_CHL PmgK_CHL rir_CHL $
 rgdpo_COL emp_COL inf_COL ck_COL ctfp_COL PmgK_COL rir_COL rgdpo_MEX emp_MEX inf_MEX ck_MEX ctfp_MEX $
 PmgK_MEX rir_MEX rgdpo_PER emp_PER inf_PER ck_PER ctfp_PER PmgK_PER rir_PER
*Versión con 3 índices, todos variantes en el tiempo. Modelo M1 con factorización exacta
*Los cambios en el parámetro alter0 se necesitan para tener 1, 4 y 8 pasos posteriores
*El parámetro dim_lam debe ser cambiado para tener 1 o 2 factores comunes
*Se plantea el modelo según la página 18, de factorización exacta.
*El modelo se plantea de la siguiente forma:
* Y(t) = X(t-s)*b(t) + e(t),  with e_t ~N(0,sigma(e))
* X(t) contiene los rezagos de Y que son las variables endógenas. También contiene aquellos
*de las variables exógenas.
*Los coeficientes b(t) serán estimados bajo estructura de índices, de la siguiente forma
* b(t) = xsi_1*lambda(t)+xsi_2*rho(t)+xsi_3*alfa(t)+u(t)
*Definimos el vector M_1=[xsi_1 xsi_2 xsi_3] y el vector theta(t)=[lamnda(t) ro(t) alpha(t)]'
*Expresándolo de una forma reducida, entonces tenemos que b(t) es:
*b(t)=M_1*theta(t)+u(t)
*El modelo general se reexpresa como sigue:
*Y(t)= X(t-s)*[M_1*theta(t)+u(t)] + e(t)
*Y(t)= [X(t-s)*M_1]*theta(t) + X(t-s)*u(t) + e(t)
*v(t)= X(t-s)*u(t) + e(t)
*Entonces tenemos que:
*Y(t)= [X(t-s)*M_1]*theta(t)+v(t)
*Asumimos que theta tiene la siguiente estructura: theta(t) = theta(t-1)+eta(t),  with eta(t)~N(0,B2(t))
* B2(t) = arch3* B2(t-1)+ arch4* B2(0)
*Además:
* sigma_t ~ G(zeta,zeta*s_t), donde s_t = (1+sigma^2*X'X)
* Omega= inv(sigma(e)) ~ W(w_0, Q_0);
* V= sigma^2*I_k; sigma^2 estimado desde los datos o [p(sigma^2) \propto (sigma^2)^{-1};]
* B2(0) =diag[phi_1, phi_2, phi_3]; phi_1=scala1; phi_2=scala2*I_g; phi_3=scala3*I_n
* el anterior en phi_1, phi_2 and phi_3 is IG(v_0/2, d_0/2)
* [En la versión base10tv_dif el anterior para phi_2 y phi_3 es difuso, i.e
* p(phi_2) \propto (phi_2)^{-0.5*(g+1)}; p(phi_3) \prop€ropphi_3)^{-0.5*(n+1)} ]
* Aquí arch3; arch4; w_0; scala1; scala2; scala3; zeta son parámetros configurados a priori.
* sigma^2, Q_0 son estimados desde los datos
*** alternativas: 1) Tiende sigma^2 --->0 (descomposición de índices exactos)
*                 2) número de componenetes en lamnda (=1 o = 2)
*                 3) no informativo B2(0)
*                 4) anteriror a v_t difuso (tiende zeta ---> 0 )
seed 11; *Esto es una semilla para que en la simulación, halla un número aleatorio de partida
source(noecho) cndition.src
compute beg=1951:1
compute tempend=2011:1
compute dat=tempend-beg
compute obs=tempend-beg
compute nstep=16
smpl beg tempend
print
******Configuración de parámetros
compute alter1=1; *Si alter1=1 se estima sigma^2 desde los datos. Si alter1=0 se define como sigma^2=0.0001
compute dim_lam=2 ;*Dependiendo de los componentes de lamnda, esta se debe cambiar según sea el caso
compute zeta=0.0
compute exact=1;* si 0 entonces no es exacto. Si es 1 es exacto
******Modelo para Alianza del Pacífico
compute n=4 ;*Número de países
compute g=6 ;*Número de variables endógenas
compute ng=n*g
compute minlag=0 ;*Este es el mínimo rezago
compute medlag=1 ;*Rezago promedio
compute maxlag=1 ;*Máximo rezago de las variables endógenas
compute lag_exo=1 ;*Rezago de las variabes exógenas
compute nlags=p=maxlag-medlag+1 ;*Número de rezagos en las variables endógenas. Sumarle el 1 garantiza que si haya al menos un rezago
compute p1=lag_exo-medlag+1 ;*Número de rezagos de las variables exógenas. Sumarle el 1 garantiza que si haya al menos un rezago
compute nlags1=3 ;*Número de rezagos usados en la estimación preliminar
compute d1=0 ;*Núero (cantidad) de variables exógenas
compute d=d1*p1+1 ;*Rezagos del var en las exogenas, y se tiene en cuenta la constante
compute k1=n*g*p+d ;*Número de variables en cada ecuacion
compute ndraws=2100 ;*Número de sorteos/lanzamientos a realizar en el MCMC
compute ndraws1=30 ;*Número de veces que se va a repetir el MCMC
compute mindraws=2000
compute begdraws=ndraws-mindraws ;*Esto descarta algunos soretos/lanzamientos en la última iteración para calcular momentos de los índices
compute k_1=n+g+dim_lam ;*Esta es la dimensión de la matriz B2(0), lo que viene siendo como la varianza y cova del vector theta.
******Asignamos valores a algunos parámetros
compute scala1=0.000001
compute scala2=0.000001
compute scala3=0.000001 ;*Estos parámetros se usan para los valores iniciales de B(0)
compute arch3=1.0 ;*Esto es solo un parámetro
compute arch4=0.0 ;*Para que no haya varianza heterocedástica se fija arch4=0.0 (es decir que la varianza de los errores no sea variable)
compute w_0=n*g+50 ;*Grados de libertad para la matriz previa de var-cov
compute v_0=1000000., d_0 = 1.0 ;* Forma y escala de los Phi 1,2 y 3
*EL VAR
*Procedemos a estimar sigma^2y Q_0, Este último término es como una varianza necesaria
*para los valores iniciales de la matriz omega.
*Empezamos por plantear un VAR
system(model=var1) 1 to n*g
variables rgdpo_chl emp_chl inf_chl ck_chl ctfp_chl pmgk_chl $
 rgdpo_col emp_col inf_col ck_col ctfp_col pmgk_col $
 rgdpo_mex emp_mex inf_mex ck_mex ctfp_mex pmgk_mex $
 rgdpo_per emp_per inf_per ck_per ctfp_per pmgk_per
lags 1 to 1
estimate(noftest,outsigma=sigma_eps) beg tempend
display sigma_eps
dec symm omega(ng,ng)
compute omega = inv(sigma_eps)
display omega
display %rows(omega) %cols(omega)
compute beta_ols1=%modelgetcoeffs(var1)
display beta_ols1
display %rows(beta_ols1) %cols(beta_ols1)
*Ahora sigma^2
* forma condicional para tener en consideración las dos opciones del valor de alter1= 0 o 1. Si es 1, sigma se
*calcula a partir de los datos, de acuerdo con la fórmula que allí se muesta. Si es 0, entonces
*se le asigna el valor sigma=0.0001. %seesq= error estandar de la estimación al cuadrado.
compute s_e=0.0
if alter1==1
dofor i = rgdpo_chl emp_chl inf_chl ck_chl ctfp_chl pmgk_chl $
linreg(noprint) i
# constant i{1 to nlags1}
compute s_e = s_e+(1./(n*g))*(sqrt(%seesq))
end dofor
if alter1==0
compute s_e = 0.0001
end if
dec symm big_phi(k_1,k_1) big_phiinv(k_1,k_1)
comp big_phi = %const(.0)
*En los siguientes pasos, se adecuan las dimensiones de las matrices, sus composiciones y
*sus respectivas inversas. Esto con el propósito de poder llenar toda la matriz Phi mayúscula.
*Los phi_1, phi_2 y phi_3 formarán la diagonal de la matriz big_phi
dec symm phi_1(dim_lam,dim_lam)
comp phi_1 = %mscalar(scala1)
compu phi_1inv = inv(phi_1)
dec symm phi_2(g,g) phi_2inv(g,g)
dec symm phi_3(n,n) phi_3inv(n,n)
compute phi_2 = %mscalar(scala2)
comp phi_2inv = inv(phi_2)
compute phi_3 = %mscalar(scala3)
comp phi_3inv = inv(phi_3)
do i = 1,dim_lam
comp big_phi(i,i) = phi_1(i,i)
display big_phi
do i = 1,g
comp big_phi(i+dim_lam,i+dim_lam) = phi_2(i,i)
display big_phi
do i = 1,n
comp big_phi(i+g+dim_lam,i+g+dim_lam) = phi_3(i,i)
display big_phi
comp big_phiinv = inv(big_phi)
*Se configuran las matrices para la estimación preliminar de OLS para inicializar los índices
*y para usar en en MCMC
smpl(reglist)
# rgdpo_chl{minlag to maxlag} emp_chl{minlag to maxlag} inf_chl{minlag to maxlag} ck_chl{minlag to maxlag} ctfp_chl{minlag to maxlag} pmgk_chl{minlag to maxlag} $
 rgdpo_col{minlag to maxlag} emp_col{minlag to maxlag} inf_col{minlag to maxlag} ck_col{minlag to maxlag} ctfp_col{minlag to maxlag} pmgk_col{minlag to maxlag} $
 rgdpo_mex{minlag to maxlag} emp_mex{minlag to maxlag} inf_mex{minlag to maxlag} ck_mex{minlag to maxlag} ctfp_mex{minlag to maxlag} pmgk_mex{minlag to maxlag} $
 rgdpo_per{minlag to maxlag} emp_per{minlag to maxlag} inf_per{minlag to maxlag} ck_per{minlag to maxlag} ctfp_per{minlag to maxlag} pmgk_per{minlag to maxlag} $
 constant
make(transpose) Y
# rgdpo_chl emp_chl inf_chl ck_chl ctfp_chl pmgk_chl $
comp ti = %cols(y)
display ti
*El siguiente comando en mayúscula indica la creación de un vector, cuyas entradas,
*a su vez, son matrices rectagulares. Para los siguientes, son las definiciones de los
*vectores y sus dimensiones.
DEC VEC[REC] XX(N+1)
dec vec hetero_old(ti)
dec vec hetero_can(ti)
dec vec hetero(ti)
dec rec hetero_dra(ti,ndraws)
comp hetero = %const(s_e)
*display hetero
dec vec s_t(ti)
dec vec[vec] ss_t(i)
dec rec[series] general1(ti,dim_lam)
dec rect[series] general2(ti,n)
dec rec[series] variables1(ti,g)
dec rec[series] vari_count1(ti,ng)
*Tanto la X mayúscula como la x minúscula son requeridas para correr el modelo. La X small
*está compuesta de vectores y esta a su vez es de dimensión 58x1 (58x25). La X grande(big) está
*compuesta de rectangulares, y también es de dimensión 58x1(58x25)
DEC VECT[vec] SMALLX(ti)
display %rows(smallx) %cols(smallx)
DEC VECT[RECT] BIGX(TI)
***Lo que sigue a continuación se requiere para no generar incompatibilidades de dimensiones
*not interdep/interdep
*Construimos la matriz X con los rezagos de las variables endógenas.
make X
# rgdpo_chl{medlag to maxlag} emp_chl{medlag to maxlag} inf_chl{medlag to maxlag} ck_chl{medlag to maxlag} ctfp_chl{medlag to maxlag} pmgk_chl{medlag to maxlag} $
 rgdpo_col{medlag to maxlag} emp_col{medlag to maxlag} inf_col{medlag to maxlag} ck_col{medlag to maxlag} ctfp_col{medlag to maxlag} pmgk_col{medlag to maxlag} $
 rgdpo_mex{medlag to maxlag} emp_mex{medlag to maxlag} inf_mex{medlag to maxlag} ck_mex{medlag to maxlag} ctfp_mex{medlag to maxlag} pmgk_mex{medlag to maxlag} $
 rgdpo_per{medlag to maxlag} emp_per{medlag to maxlag} inf_per{medlag to maxlag} ck_per{medlag to maxlag} ctfp_per{medlag to maxlag} pmgk_per{medlag to maxlag} $
 constant
display x
**Ahora calculamos el número de observaciones que se pueden usar y el número de variables
*por cada ecuación
compu ti = %rows(x)  ;*Número de observaciones que se pueden usar
comp k = %cols(x) ;*Número de variables para cada ecuación
display ti k
*Lo que sigue indica que para cada una de las observaciones (58), la dimensión de smallx será
*será de 25 (las 24 variables más la constante). Los siguientes dos DO se indican para poder
*aplicar el modelo a cualquier ejercicio, indepentientemente de cuáles sean los n,g y k
DO T = 1,TI
DIM SMALLX(T)(K)
END DO T
DO T = 1,TI
  DO J = 1,K
   COMPUTE SMALLX(T)(J)=x(T,J)
  END DO J
END DO T
display smallx
*Ahora se configura la matriz X(t-s), es decir la matriz de los rezagos,
*lo cual se necesita para la reparametrización del modelo
*El número de rezagos dependerá del valor que se le de a s
do t = 1,ti
compute s_t(t) = 1.+s_e*%dot(smallx(t),smallx(t))
display s_t(t)
DO T = 1,T
DIM BIGX(T)(N*G,N*G*K)
COMPUTE BIGX(T) = %KRONEKER(%IDENTITY(N*G),TR(SMALLX(T)))
*display %rows(bigx(t)) %cols(bigx(t)) bigx(t)
END DO T
*Ahora se configura el vector de las variables endógenas, de acuerdo
*con las dimesiones de ti y k
DEC VECT[VECT] SMALLY(TI)
do t= 1,ti
overlay y(1,t) with SMALLY(t)(N*G)
end do t
*LAMNDA, RHO Y ALPHA*
*Para la configuarión del VAR como un sistema de índices, debemos organizar lamnda, roh y alpha
*Para eso definimos sus dimensiones y componentes, para después poder multiplicarlos por X
*Es importante tener presente que estas tres matrices nos permitirán establecer cómo son
*Los efectos que queremos analizar, pues serán las matrices de ceros y unos que nos permitirán
*tener encuenta o no algunas variables.
*****MATRIZ LAMNDA
compute xsi_11 = %const(.0), xsi_1 = %const(.0)
display xsi_11 xsi_1
dec vec e_p(nlags)
do ll = 1,nlags
dec vec e_p1(p1)
do ll = 1,p1
display e_ng %rows(e_ng) %cols(e_ng); * Esto es 24x1
display e_d %rows(e_d) %cols(e_d); * Esto es 2x1
display %rows(e_ngp) %cols(e_ngp); *Esto es 26x1
if dim_lam==1
compute xsi11(k) = 1;*Esto es para que la última entrada del vector sea 1 de la constante
do j = 1,n*g*p
display e_ngp(j)
do j = 1,d1*p1
do j = 1,N*g*k
*Ahora revisamos
*cuando la dimensión de lamnda
*(componentes comunes-predeterminados) es igual a 2.
*Aquí tenemos que lamnda=1 para los países que no pertenecen a la CAN y lambda=2
*los que sí pertenecen a la CAN
if dim_lam==2
do j = 1,d1*p1
do j = 1,g
do ll = 1,p
do j = 1,g
do ll = 1,p
comp xsi_11(2*g*p+(j-1)*p+ll,1) = e_p(ll)
do j = 1,g
do ll = 1,p
comp xsi_11(g*p+(j-1)*p+ll,2) = e_p(ll)
do j = 1,g
do ll = 1,p
comp xsi_11(3*g*p+(j-1)*p+ll,2) = e_p(ll)
do j = 1,g
do jj = 1,k
do j = 1,g
do jj = 1,k
comp xsi_1(2*g*k+(j-1)*k+jj,1) = xsi_11(jj,1)
do j = 1,g
do jj = 1,k
comp xsi_1(g*k+(j-1)*k+jj,2) = xsi_11(jj,2)
do j = 1,g
do jj = 1,k
comp xsi_1(3*g*k+(j-1)*k+jj,2) = xsi_11(jj,2)
end if
display xsi_1
****MATRIZ RHO
dec rec xsi2(g*k,g) xsi_2(n*g*k,g)
comp xsi2 = %const(.0), xsi_2 = %const(.0)
display %rows(xsi2) %cols(xsi2) %rows(xsi_2) %cols(xsi_2)
dec vec e_p(nlags)
do ll = 1,nlags
*display e_p
dec vec[vec] a_xsi2(g)
do i = 1,g
dim a_xsi2(i)(k)
comp a_xsi2(i) = %const(.0)
do j = 1,d1*p1
comp a_xsi2(i)(n*g*p+j) = e_p1(j)
comp a_xsi2(i)(k) = 1.
*display %rows(a_xsi2(1)) %cols(a_xsi2) a_xsi2
do j = 1,g
do i = 1,n
do ll = 1,p
comp a_xsi2(j)((j-1)*p+(i-1)*g*p+ll) = e_p(ll)
*display %rows(a_xsi2) %cols(a_xsi2) a_xsi
do j = 1,g
do i = 1,k
comp xsi2((j-1)*k+i,j) = a_xsi2(j)(i)
*display %rows(xsi2) %cols(xsi2) xsi2
dec vec e_n(n)
compute e_n = %const(1.)
*display e_n
comp xsi_2 = %kroneker(e_n,xsi2)
*display %rows(xsi_2) %cols(xsi_2)
****MATRIZ ALPHA
dec rec xsi_3(n*g*k,n)
comp xsi_3 = %const(.0)
display %rows(xsi_3) %cols(xsi_3)
dec vec e_p(nlags)
do ll = 1,nlags
dec vec e_g(g) e_pg(p*g)
compute e_g = %const(1.)
*display e_g
comp e_pg = %kroneker(e_g,e_p)
*dislplay %rows(e_pg) %cols(e_pg) e_pg
dec vec[vec] a_xsi3(n)
do i = 1,n
dim a_xsi3(i)(k)
comp a_xsi3(i) = %const(.0)
do j = 1,d1*p1
comp a_xsi3(i)(n*g*p+j) = e_p1(j)
comp a_xsi3(i)(k) = 1.
*dislplay %rows(a_xsi3) %cols(a_xsi3)
do i = 1,n
do j = 1,g*p
comp a_xsi3(i)((i-1)*g*p+j) = e_pg(j)
dislplay %rows(a_xsi3) %cols(a_xsi3) a_xsi3
dec vec[vec] a_a_xsi3(n)
do i = 1,n
dim a_a_xsi3(i)(g*k)
comp a_a_xsi3(i) = %kroneker(e_g,a_xsi3(i))
do i = 1,n
do j = 1,g*k
comp xsi_3((i-1)*g*k+j,i) = a_a_xsi3(i)(j)
display %rows(xsi_3) %cols(xsi_3) xsi_3
*MATRIZ DE REGRESORES
*El siguiente comando nos permite crear la matriz de regresores que se construirá a partir de
*un vector, cuyas entradas serán vectores rectangulares. Creamos tres de estos vectores,
*cada uno de dimensión ti=52, que son el número de observaciones por cada variable
*Luego se calculan los diferentes productos entre la matriz de regresores y los lamnda, rho
* y alpha, los cuales presentarán los efectos que se quieren analizar.
DEC VECT[RECT] BIG_W(TI) BIG_Z(TI) BIG_A(TI)
DO T = 1,ti
DIM BIG_W(T)(N*G,dim_lam) BIG_Z(T)(N*G,G) BIG_A(T)(N*G,N)
comp big_w(t) = bigx(t)*xsi_1
comp big_z(t) = bigx(t)*xsi_2
comp big_a(t) = bigx(t)*xsi_3
*display %rows(bigx(t))  %cols(bigx(t))  %rows(xsi_1) %cols(xsi_1)
****MATRIZ M_1
*Es decir, la reconfiguración del modelo en su versión más reducida
*Recordemos que esta matriz contiene los "coeficientes" que determinan los índices, en realidad
*en un vector compuesto por xsi_1, xsi_2 y xsi_3, para explicar a b(t)
dec rect m_1(n*g*k,n+g+dim_lam)
comp m_1 = %const(.0)
*display %rows(m_1) %cols(m_1) m_1
do i = 1,n*g*k
do lam = 1,dim_lam
compute m_1(i,lam) =xsi_1(i,lam)
end do lam
do i = 1,ng*k
do j = dim_lam+1,g+dim_lam
compute m_1(i,j) = xsi_2(i,j-dim_lam)
do i = 1,ng*k
do ii = g+dim_lam+1,dim_lam+g+n
compute m_1(i,ii) = xsi_3(i,ii-g-dim_lam)
end do ii
dec vect[rect] X_M(ti)
DO T = 1,ti
DIM x_m(T)(N*G,dim_lam+g+n)
comp X_M(t) = %const(.0)
do i = 1,n*g
do lam = 1,dim_lam
compute X_M(t)(i,lam) =big_w(t)(i,lam)
do i = 1,ng
compute X_M(t)(i,j) = big_z(t)(i,j-dim_lam)
do i = 1,ng
compute X_M(t)(i,ii) = big_a(t)(i,ii-g-dim_lam)
end do t
display %rows(x_m) %cols(x_m)
display %rows(x_m(52))
*display x_m(52)
*AQUÍ EMPIEZA LA CONFIGURACIÓN PARA MONTECARLO
*Estimación de los índices usando ols secuenciales. (en prueba de muestras)
*Usa la estimación para inicializar MCMC
*Para calcular esto, basta tomar el modelo en su expresión extensa y despejar cada letra griega
*desde una forma matricial para obtener esta forma funcional.
dec vect[vect] lambda(ti) rho(ti) alfa_1(ti)
do t = 1,ti
dim lambda(t)(dim_lam) rho(t)(g) alfa_1(t)(n)
compute lambda(t) = inv(tr(big_w(t))*big_w(t))*tr(big_w(t))*smally(t)
compute eps1 = smally(t)-big_w(t)*lambda(t)
compute rho(t) = inv(tr(big_z(t))*big_z(t))*tr(big_z(t))*eps1
compute eps2 = eps1-big_z(t)*rho(t)
compute alfa_1(t) = inv(tr(big_a(t))*big_a(t))*tr(big_a(t))*eps2
end do t
comp t1 = ti
dec vect[vect] theta_ka(t1) theta_mc(t1)
do t = 1,t1
DIM theta_ka(t)(k_1)
dim theta_mc(t)(k_1)
COMPUTE THETA_KA(T) = %const(.0), THETA_MC(T) = %CONST(.0)
do la = 1,dim_lam
compute theta_ka(t)(la) = lambda(t)(la)
compute theta_mc(t)(la) = lambda(t)(la)
do j = 1,g
COMPUTE theta_ka(t)(j+dim_lam) = rho(t)(j)
compute theta_mc(t)(j+dim_lam) = rho(t)(j)
do i = 1,n
COMPUTE theta_ka(t)(g+dim_lam+i) = alfa_1(t)(i)
compute theta_mc(t)(g+dim_lam+i) = alfa_1(t)(i)
end do t
*display %rows(theta_mc)
*Ahora se configuran las matrices necesarias para hacer el muestreo de Gibbs
dec vect[vect] u2(ti)
dec rect part5(n*g,n*g)
dec real part6 part7 part8 part9
compute def1 = t1+w_0
dec symm ss0hatinv(n*g,n*g)
* Se configuran las matrices para los valores futuros de los indicadores
*(opuesto a rezagos)
dec rec[vec] lamdraw(ti,ndraws)
dec rec[vec] rhodraw(ti,ndraws)
dec rec[vec] alfadraw(ti,ndraws)
dec vec phi1dra(ndraws) phi2dra(ndraws) phi3dra(ndraws)
dec vect[symm] omega_ka(t1) omega_mc(t1)
dec vect[rect] emme_mc(t1)
do t = 1,t1
 dim omega_ka(t)(k_1,k_1) omega_mc(t)(k_1,k_1)
 dim emme_mc(t)(k_1,k_1)
 compute omega_ka(t)=%const(0.0), omega_mc(t)=%const(0.0)
 compute emme_mc(t)=%const(0.0)
end do t
dec vec loglike_dr(ndraws)
dec vec[symm] omega_dra(ndraws)
*COMIENZO RUTINA DE MCMC
comp hetero = %const(1.)
do draws = 1,ndraws
disp draws
 do t = 1,ti
 dim lamdraw(t,draws)(dim_lam)
 dim rhodraw(t,draws)(g)
 dim alfadraw(t,draws)(n)
 dim u2(t)(k_1)
 end do t
* do draws1 = 1,ndraws1
*disp draws draws1
** kalman filter
compute omega_ka(1) = %IDENTITY(K_1)
 compute omegaTT_1 = omega_ka(1)+big_phi
 compute emme_mc(1) = omega_ka(1)*inv(omegaTT_1)
 compute omega_mc(1) = omega_ka(1)-%mqform(omegaTT_1,tr(emme_mc(1)))
 comp u2(1) = %ran(1.)
 comp loglike_kf = 0.0
 do t = 2,t1
  compute delta_t = arch4**t+arch3*(1./(1.-arch4))*(1.-arch4**t)
  compute omegaTT_1 = omega_ka(t-1)+delta_t*big_phi
  compute effeTT_1 = X_M(t)*omegaTT_1*tr(X_M(t))+(1./hetero(t))*inv(omega)
  compute kappaTT_1 = omegaTT_1*tr(X_M(t))*inv(effeTT_1)
  compute imenoka = %identity(k_1)-kappaTT_1*X_M(t)
  compute omega_ka(t) = imenoka*omegaTT_1
  compute resi = smally(t)-X_M(t)*theta_ka(t-1)
  compute theta_ka(t) = theta_ka(t-1)+kappaTT_1*resi
  compute delta_t1 = arch4**(t+1)+arch3*(1./(1.-arch4))*(1.-arch4**(t+1))
  compute omegaTT_11 = omega_ka(t)+delta_t1*big_phi
  compute emme_mc(t) = omega_ka(t)*inv(omegaTT_11)
  compute omega_mc(t)= omega_ka(t)-%mqform(omegaTT_11,tr(emme_mc(t)))
  compute resi1 = smally(t)-X_M(t)*theta_ka(t)
  comp loglike_temp = -0.5*n*g*log(2.*%pi)-0.5*log(%det(effeTT_1))-0.5*%qform(inv(effeTT_1),resi1)
  comp loglike_kf = loglike_kf+loglike_temp
  release resi resi1 omegaTT_1 effeTT_1 kappaTT_1 imenoka omegatt_11
  comp u2(t) = %ran(1.)
 end do t
 comp loglike_dr(draws) = loglike_kf
*DISP DRAWS DRAWS1
 comp u2(t1) = %ran(1.)
 compute theta_mc(t1) = theta_ka(t1) ;*+%decomp(omega_ka(t1))*u2(t1)
 do sp = 1,DIM_LAM
 compute lambda(t1)(sp) = theta_mc(t1)(sp)
 end do sp
 do sp = dim_lam+1,g+dim_lam
 compute rho(t1)(sp-dim_lam) = theta_mc(t1)(sp)
 end do sp
 do sp = g+dim_lam+1,k_1
 compute alfa_1(t1)(sp-g-dim_lam) = theta_mc(t1)(sp)
 end do sp
 do t = 2,t1
 comp u2(t1-t+1) = %ran(1.)
  compute themean=theta_ka(t1-t+1)+emme_mc(t1-t+1)* $
	       (theta_mc(t1-t+2)-theta_ka(t1-t+1))
  compute theta_mc(t1-t+1) = themean+%decomp(omega_mc(t1-t+1))*u2(t1-t+1)
  compute themean = %const(.0)
*compute theta_mc(t1-t+1) = theta_ka(t1-t+1) ;*+%decomp(omega_ka(t1))*u2(t1)
 do sp = 1,dim_lam
  compute lambda(t1-t+1)(sp) = theta_mc(t1-t+1)(sp)
  end do sp
  compute rho(t1-t+1)(sp-dim_lam) = theta_mc(t1-t+1)(sp)
  end do sp
  compute alfa_1(t1-t+1)(sp-g-dim_lam) = theta_mc(t1-t+1)(sp)
 end do sp
 end do t
* compute theta_ka(1) = theta_mc(1)
 compute part5 = %const(.0)
 compute part6 = .0
 compute part7 = .0, part8 = .0, part9 = 0.0
 comp sum_sig = 0.0, sum_eome = 0.0
 DO T = 2,t1
  compute eps1 = smally(t)-big_w(t)*lambda(t)-big_z(t)*rho(t)-big_a(t)*alfa_1(t)
  comp eps_eps = eps1*tr(eps1)
  comp part6 = zeta*s_t(t)+%qform(omega,eps1)
*  compute eps1 = %const(.0)
  compute p00 = 2./(part6)
  if exact ==0
  compute hetero(t) = p00*%rangamma(.5*(ng+zeta))
  if exact ==1
  compute hetero(t) = 1.0
  compute part5 = part5+(hetero(t))*eps_eps
  compute sum_sig = sum_sig+log(1./hetero(t))
  comp sum_eome = sum_eome +(hetero(t))*%qform(omega,eps1)
  compute resth = (1./delta_t)*(theta_mc(t)-theta_mc(t-1))
  compute resth1 = (1./delta_t)*(lambda(t)-lambda(t-1))
  compute resth2 = (1./delta_t)*(rho(t)-rho(t-1))
  compute resth3 = (1./delta_t)*(alfa_1(t)-alfa_1(t-1))
  compute part7 = part7+%dot(resth1,resth1)
  compute part8 = part8+%dot(resth2,resth2)
  compute part9 = part9+%dot(resth3,resth3)
end do t
 compute seps1 = part7+d_0
 compute p11= 2./(seps1)
 compute phi1 = p11*%rangamma(.5*(t1+v_0))
 compute phi_1 = %mscalar(1./phi1)
 compute seps2 = part8+d_0
 compute p2= 2./(seps2)
 compute phi2 = p2*%rangamma(.5*(t1*g+v_0))
 compute phi_2 = %mscalar(1./phi2)
 compute seps3 = part9+d_0
 compute p3= 2./(seps3)
 compute phi3 = p3*%rangamma(.5*(t1*n+v_0))
 compute phi_3 = %mscalar(1./phi3)
 do i = 1,dim_lam
 end do lam
 do i = 1,g
 do i = 1,n
 compute werre_0 = w_0*sigma_eps
 compute ss0hatinv = werre_0+part5
 compute Swish = tr(%decomp(inv(ss0hatinv)))
 compute omega = %mqform(%RANWISHART(N*g,def1),Swish)
 end do draws1
 comp omega_dra(draws) = omega
 compute phi1dra(draws) = 1./phi1
 compute phi2dra(draws) = 1./phi2
 compute phi3dra(draws) = 1./phi3
 do t = 2,ti
 compute lamdraw(t,draws) = lambda(t)
 compute rhodraw(t,draws) = rho(t)
 compute alfadraw(t,draws) = alfa_1(t)
 end do t
end do draws
****** FIN DE LA RUTINA MCMC ***************
*Incertudumbre procedente de MCMC
comp nvar = ng
smpl beg tempend
dec vec[vec] theta_all(ndraws) delta_all(ndraws)
do draws = 1,ndraws
 dim theta_all(draws)(k_1)
 dim delta_all(draws)(n*g*k)
  do sp = 1,dim_lam
   compute theta_all(draws)(sp) = lamdraw(t1,draws)(sp)
  do sp = dim_lam+1,dim_lam+g
   compute theta_all(draws)(sp) = rhodraw(t1,draws)(sp-dim_lam)
   compute theta_all(draws)(sp) = alfadraw(t1,draws)(sp-g-dim_lam)
 comp delta_all(draws) = m_1*theta_all(draws)
system(model=varmodel1) 1 to nvar
lags 1 to nlags
declare vect[rect] responses(ndraws)
declare rect[series] impulses(nvar,nvar)
dec rec betadraw(k,ng)
infobox(action=define,progress,lower=1,upper=ndraws) 'impulse responses'
do draws = 1,ndraws
 do j = 1,ng
* comp delta_all(draws)((j-1)*(k+nlags)+1) = 0.6
 do i = 1,k
 compute betadraw(i,j) = delta_all(draws)((j-1)*k+i)
compute %modelsetcoeffs(varmodel1,(betadraw))
 ** Cálculo del bloque de Choleski
 comp omega_11 = %xsubmat(inv(omega_dra(draws)),1,g,1,g)
 comp omega_22 = %xsubmat(inv(omega_dra(draws)),1+g,n*g,1+g,n*g)
 comp omega_12 = %xsubmat(inv(omega_dra(draws)),1,g,1+g,n*g)
 comp omega_21 = %xsubmat(inv(omega_dra(draws)),1+g,n*g,1,g)
 comp E_E = omega_22-omega_21*inv(omega_11)*omega_12
 comp eigdec_om = %EIGDECOMP(omega_11)
 comp eigdec_e = %EIGDECOMP(E_E)
 comp lambda_om = %diag(eigdec_om(1))
 comp lambda_e = %diag(eigdec_e(1))
 comp sqrt_om = eigdec_om(2)*%sqrt(lambda_om)*tr(eigdec_om(2))
 comp sqrt_e = eigdec_e(2)*%sqrt(lambda_e)*tr(eigdec_e(2))
 comp fact = omega_21*inv(omega_11)*sqrt_om
 comp chole = %blockglue(|| %BLOCKGLUE(|| sqrt_om , %zeros(g,(n-1)*g) ||) | %blockglue(|| fact, sqrt_e ||) ||)
 ** Finaliza el cálculo del bloque de Choleski
*También se puede calcular choleski de esta forma
 *comp chole= %decomp(inv(omega_dra(draws)))
 comp sigm = inv(omega_dra(draws))
@cndition(decomp=chole) varmodel1 nstep tempend+1 sigm 2 condfore
# rgdpo_col tempend+1 rgdpo_col(tempend)+1.
* # rgdpo_col tempend+2 rgdpo_col(tempend)+.5
* # rgdpo_col tempend+3 rgdpo_col(tempend)+.25
* # rgdpo_col tempend+4 rgdpo_col(tempend)
# emp_col tempend+1 emp_col(tempend)+1.
* # emp_col tempend+2 emp_col(tempend)+.5
forecast(model=varmodel1,results=forecasts) nvar nstep tempend+1
 set prova tempend+1 tempend+nstep = condfore(24)-forecasts(24)
 set prova1 tempend+1 tempend+nstep = condfore(4)-forecasts(4)
 graph(key=below) 2 ;#condfore(24) tempend+1 tempend+nstep ;#forecasts(24) tempend+1 tempend+nstep
 graph(key=below) 2 ;#prova1 tempend+1 tempend+nstep ;#prova tempend+1 tempend+nstep
* Almacenar los impulso respuesta como la diferencia entre el pronóstico condicional
*e incondicional
dim responses(draws)(nvar,nstep)
 do i = 1,nvar
  do j = 1,nstep
   comp responses(draws)(i,j)=condfore(i)(tempend+j)-forecasts(i)(tempend+j)
 infobox(current=draws)
end do draws
infobox(action=remove)
** Calculamos aquí IRF (pronóstico impulso respuesta) y las bandas para cada variable.
** 4 = COL rgdpo; 8 = CHL rgdpo; 12 = MEX rgdpo 16 = PER rgdpo;
dec vect[series] upper(nvar) lower(nvar) resp(nvar)
comp j = 16
do j = 1,nvar
   smpl 1 ndraws
   compute minlower=maxupper=0.0
      clear lower(j) upper(j) resp(j)
      do i=1,nstep
         set work 1 ndraws = responses(t)(j,i)
         compute frac=%fractiles(work,||.05,0.5,.95||)
         compute lower(j)(i)=frac(1)
         compute upper(j)(i)=frac(3)
         compute resp(j)(i)=frac(2)
      compute maxupper=%max(maxupper,%maxvalue(upper(j)))
      compute minlower=%min(minlower,%minvalue(lower(j)))
   smpl 1 nstep
      graph(ticks,min=minlower,max=maxupper,number=0) 3 j i
      # resp(j)
      # upper(j) / 2
      # lower(j) / 2
do j = 4,28,4
print / resp(j) upper(j) lower(j)
*smpl 1 nstep
graph 2
# resp(4)
# resp(8)
# resp(12)
# resp(16)
# resp(20)
# resp(24)
# resp(28)
COMP MINLOWER = -.5, MAXUPPER = 1.
smpl 1 nstep
spgraph(hfields=3,vfields=3,header='Responses of GDP growth to a shock to real US variables ')
      graph(ticks,min=minlower,max=maxupper,number=0,header='US') 3 2 1
      # resp(4)
      # upper(4) / 2
      # lower(4) / 2
      graph(ticks,min=minlower,max=maxupper,number=0,header='Japan') 3 1 2
      # resp(8)
      # upper(8) / 2
      # lower(8) / 2
      graph(ticks,min=minlower,max=maxupper,number=0,header='Germany') 3 1 3
      # resp(12)
      # upper(12) / 2
      # lower(12) / 2
      graph(ticks,min=minlower,max=maxupper,number=0,header='UK') 3 2 2
      # resp(16)
      # upper(16) / 2
      # lower(16) / 2
      graph(ticks,min=minlower,max=maxupper,number=0,header='France') 3 2 3
      # resp(20)
      # upper(20) / 2
      # lower(20) / 2
      graph(ticks,min=minlower,max=maxupper,number=0,header='Canada') 3 3 2
      # resp(28)
      # upper(28) / 2
      # lower(28) / 2
      graph(ticks,min=minlower,max=maxupper,number=0,header='Italy') 3 3 3
      # resp(24)
      # upper(24) / 2
      # lower(24) / 2
DO T = 1,T
END DO T
Is that supposed to be DO T=1,TI? As written, that's definitely wrong. (BTW, I wouldn't recommend using T as a loop index since it's the reserved name for the index in SET's and FRML's).
Do you intend for BIGPHI to be really enormous? It has values on the order to 10^133. You will have all kinds of numerical problems working with values like that. (A number like that to the 3rd power overflows).
Also, why are your VAR data (on most variables at least) not in logs? I can't imagine how those could sensibly be linear in the levels.
carlosvillarreal
I'm so sorry Tom, You're right, I've sent the wrong link. Actually I'm working with the first difference of log in all data, even so, Rats shows the same error message.
I let you the correcto link to see all data.
Thank you for all your help
https://www.dropbox.com/s/26cevct3sn1y3 ... p.xls?dl=0
So far as I can tell, you have a 24 variable VAR but the program is asking for the response of variable 28. There are so many lines commented out, it's not clear what's supposed to be doing what.
carlosvillarreal
Hi Tom, me again.
I think I got a problem with smpl(reglist) code. Could you help me please!
Data are annual, beginning at 1951 and ending at 2011, so I have 61 obs. When I use smpl(reglist) code from {minlag to maxlag}, data change to 1952-2009; is it normal? I hoped a range of 1952-2011, but I don't find where I'm wrong.
I let you the code and you can use the last link for data I sent in previous message.
Thank you.
CALENDAR 1951
ALL 2011:01
DATA(FORMAT=XLS,ORG=COLUMNS) 1951:01 2011:01 year rgdpo_CHL emp_CHL inf_CHL ck_CHL ctfp_CHL PmgK_CHL rgdpo_COL $
 emp_COL inf_COL ck_COL ctfp_COL PmgK_COL rgdpo_MEX emp_MEX inf_MEX ck_MEX ctfp_MEX PmgK_MEX rgdpo_PER $
print
disp 2011:1
* b(t) = xsi_1*lambda(t)+xsi_2*rho(t)+xsi_3*alfa(t)+u(t) , u(t)~N(0,%kroneker(sigma(e),V)
*Además:
compute beg=1951:1
compute nstep=16  ;*Número de etapas de respuesta
disp beg tempend dat obs nstep
smpl beg tempend
print
compute dim_lam=1 ;*Dependiendo de los componentes comunes de lamnda, esta se debe cambiar según sea el caso
compute zeta=0.0
compute exact=1;* si 0 entonces no es exacto. Si es 1 es exacto la factorización de la reparametrización
compute ng=n*g
compute v_0=1000000 , d_0 = 1.0 ;* Forma y escala de los Phi 1,2 y 3
open data var_ap.xls
data(org=obs,for=xls)
close data
print
*Antes de realizar la estimación del VAR, en el program original se realizan unas modificaciones a las
*variables, para quitar unos outliers presentes. En este caso, inicialmente no se encuentra esta situación,
*Por lo que se decide trabajar con la primera diferencia de los logaritmos de todas las variables.
*EL VAR
*Procedemos a estimar sigma^2 y Q_0, Este último término Q_0 representa la varianza
*de la matriz omega.
lags 1 to 1
display sigma_eps
disp %rows(sigma_eps) %cols(sigma_eps)
display omega
display beta_ols1
*Ahora sigma^2
compute s_e=0.0
if alter1==1
linreg i
disp s_e
end dofor
if alter1==0
end if
*disp s_e
******Ahora, configuramos B2(0). B2 inicial
compute k_1=n+g+dim_lam  ;*Esta será la dimensión de B2(0).
disp %rows(big_phi) %cols(big_phi)
disp big_phi
disp phi_1 phi_1inv
disp phi_2 phi_2inv
disp phi_3 phi_3inv
do i = 1,dim_lam
display big_phi
do i = 1,g
display big_phi
do i = 1,n
display big_phi
disp big_phiinv
smpl(reglist)
 constant
 print
table
SMPL(REGLIST) is designed to figure out the range for which ALL of the series (allowing for the lags and leads you specify) have data. Assuming this is the instruction of interest:
    smpl(reglist)
     constant
you're going to lose two off the high end if MINLAG is -2 (i.e. you're allowing for two leads) or if any one of those series only runs through 2009.
carlosvillarreal
Hello Tom,
I think I've managed to run the code completely. However, I have a problem with the last point where the impulse response is configured, I can not generate the multiple graph, which is the last code.
I suspect that my problem is with "LOWER", but I can not identify what this is.
I give you the code and sample data I'm working with. This works properly and runs in its entirety.
I also leave you, again, my code and my data. Please help me to know the error, I think I'm very close to being able to complete this exercise.
Greetings and thank you very much.
example data
https://www.dropbox.com/s/l7ba7j6zx2qaq ... a.xls?dl=0
example code
OPEN DATA "Z:\Users\Icaro\Dropbox\Trabajo de Grado Maestría\replication_IER\indexsa.xls"
CALENDAR 1980 1 4
ALL 2000:04
DATA(FORMAT=XLS,ORG=COLUMNS) 1980:01 2000:04 USINF JPINF GEINF UKINF FRINF ITINF CAINF CAINFR GEINFR FRINFR $
 ITINFR JPINFR UKINFR USINFR CAINFW GEINFW FRINFW ITINFW JPINFW UKINFW USINFW CAEG GEEG FREG ITEG JPEG $
 UKEG USEG CAMG GEMG FRMG ITMG JPMG UKMG USMG CAREE GEREE FRREE ITREE JPREE UKREE USREE CAGDPG GEGDPG $
 FRGDPG ITGDPG JPGDPG UKGDPG USGDPG CASLOPE GESLOPE FRSLOPE ITSLOPE JPSLOPE UKSLOPE USSLOPE CAGAP GEGAP $
 FRGAP ITGAP JPGAP USGAP UKGAP UKSTG CPG USINFR1 esree esinf esinfr eseg eseg1 esgdpg nlree nlinf nlinfr $
 nlgdpg nleg EA_gdpg EA_hicpg EA_pcdg EA_eg EA_stn
* Se hacen los ajustes de la muestra de los datos
seed 11
cal 1980 1 4
all 2002:4
*Inicialmente este comando ALL estaba de la forma all 14 2002:4, lo cual me desconfiguraba la selección de la muestra. Por tanto se modificó eliminando el número 14 que seguía el comando ALL
compute beg=1980:1
compute tempend=2000:4
compute nstep=16
smpl beg tempend
*Se definen los parámetros a utlizar en el modelo. Inicia con el parámetro alter1, el cual hace referencia a una dummy asociada con la varianza. si alter1=1 se estima el sigma^2 desde los datos. Si alter1=0 se fija el sigma^2=0.0001
*Se define dim_lam igual a 2 y se cambia a 1/1 si lamda tiene la mitad 1/2 de componentes comunes. Es decir, exógenas que afectan a las unidades (países)
*Se define zeta=.00 para definir el escenario no informativo en sigma(t)
*Se define exact como una dummy, que será 1 si la factorización es exacta y será igual a 0 si no lo es.
compute alter1=1
compute dim_lam=2
compute zeta=.00
compute exact=1
*Ahora lo que hacemos establecer las condiciones geneales del modelo,
*países=7, variables=4 y dimensiones=variables*países. También se definen los min, med y max de los
*rezagos, tanto en las variables endógenas como en las exógenas.
compute n=7
compute g=4
compute ng=n*g
compute minlag=0
compute medlag=1
compute maxlag=1
compute lag_exo=1
compute nlags1=3
compute d1=0
compute d=d1*p1+1
compute k1=n*g*p+d
compute ndraws=2100
compute ndraws1=30
display k_1
*Se definen los valores de algunos parámetros
compute arch3=1.0
compute arch4=0.0
compute w_0=n*g+50
compute v_0=1000000, d_0=1.0
*Datos
open data indexsa.xls
close data
*Reorganizamos algunas series para reducir afectaciones al ejercicio
*La tasa de crecimiento de Alemania presenta un pico muy fuerte
*entre los años 1990 y 1993, por tanto se procede a "fraccionarla"
statistics gegdpg beg tempend
statistics gegdpg beg 1990:4
compute a1=%mean
statistics gegdpg 1992:1 2000:4
compute a2=%mean
statistics geeg beg 1990:4
compute a3=%mean
statistics geeg 1992:1 2000:4
compute a4=%mean
set gegdpg 1991:1 1991:2 =a1
set gegdpg 1991:3 1991:4 =a2
set geeg 1991:1 1991:2 =a3
set geeg 1991:3 1991:4 =a4
*Se fija una inflación promedio de los siete países igual a cero?
*Todo el siguiente segmento está en comentario, así que por ahora no se tendrá
*en consideración
set inf_averg7=0.0
do i=1,n
set inf_averg7=inf_averg7+(1/n)*([series] i)
*Estandarización de las variables
dofor i = usinf usinfr useg usgdpg jpinf jpinfr jpeg jpgdpg $
  geinf geinfr geeg gegdpg ukinf ukinfr ukeg ukgdpg $
  frinf frinfr freg frgdpg itinf itinfr iteg itgdpg $
  cainf cainfr caeg cagdpg cpg inf_averg7
stat(noprint) ([series] i)
set ([series] i) = (([series] i)-%mean)/sqrt(%variance)
*set ([series] i) = ([series] i)/sqrt(%variance)
end dofor
*Estimamos ahora sigma^2 y Q_0
* Q_0 es sigma_eps y omega también se incia como Q_0
**** Ahora se estima un var que va desde 1 hasta n*g=7*4=28.
*se usan las 28 variables, un rezago para cada una de ellas y se incluye además la constante.
*Posterioemente se realiza una estimación para toda la muestra, y de esta se extrae la matriz
*de varianzas y covarianzas sigma_eps. Luego decalramos una matriz omega, de simensión (ng,ng)
*y se designa como la inversa de sigma_eps, es decir, la inversa de la matriz se var y covar
*Luego sacamos una matriz (29,28) con los coeficientes obtenidos para todas las regresoras
*del VAR
variables  usinf usinfr useg usgdpg jpinf jpinfr jpeg jpgdpg $
lags 1 to 1
estimate(noprint,noftest,outsigma=sigma_eps) beg tempend
display sigma_eps
display omega
display beta_ols1
*Ahora sigma^2
*No sé de dónde es alter. Se supone que yo lo fijo, cómo lo reconoce
*el programa a partir de lo que ya hemos calculado.
*Lo anterior ya no es importante, puesto que se plantea el modelo de forma condicional
*para tener en consideración las dos opciones del valor de alter= 0 o 1. Si es 1, sigma se
*se e asigna el valor sigma=0.0001. %seesq= error estandar de la estimación al cuadrado.
compute s_e=0.0
if alter1==1
linreg(noprint) i
end dofor
if alter1==0
end if
do i = 1,dim_lam
display big_phi
do i = 1,g
display big_phi
do i = 1,n
display big_phi
smpl(reglist)
# usinf{minlag to maxlag} usinfr{minlag to maxlag} useg{minlag to maxlag} usgdpg{minlag to maxlag} $
  jpinf{minlag to maxlag} jpinfr{minlag to maxlag} jpeg{minlag to maxlag} jpgdpg{minlag to maxlag}$
  geinf{minlag to maxlag} geinfr{minlag to maxlag} geeg{minlag to maxlag} gegdpg{minlag to maxlag}  $
  ukinf{minlag to maxlag} ukinfr{minlag to maxlag} ukeg{minlag to maxlag} ukgdpg{minlag to maxlag}   $
  frinf{minlag to maxlag} frinfr{minlag to maxlag} freg{minlag to maxlag} frgdpg{minlag to maxlag}   $
  itinf{minlag to maxlag} itinfr{minlag to maxlag} iteg{minlag to maxlag} itgdpg{minlag to maxlag}    $
  cainf{minlag to maxlag} cainfr{minlag to maxlag} caeg{minlag to maxlag} cagdpg{minlag to maxlag}     $
  constant
MAKE(transpose) Y
# usinf usinfr useg usgdpg $
  jpinf jpinfr jpeg jpgdpg geinf geinfr geeg gegdpg $
  ukinf ukinfr ukeg ukgdpg frinf frinfr freg frgdpg $
  itinf itinfr iteg itgdpg cainf cainfr caeg cagdpg
comp ti = %cols(y)
dec vec hetero(ti)
*display hetero
dec vec s_t(ti)
*está compuesta de vectores y esta a su vez es de dimensión 83x1. La X grande(big) está
*compuesta de rectangulares, y también es de dimensión 83x1
make X
# usinf{medlag to maxlag} usinfr{medlag to maxlag} useg{medlag to maxlag} usgdpg{medlag to maxlag} $
  jpinf{medlag to maxlag} jpinfr{medlag to maxlag} jpeg{medlag to maxlag} jpgdpg{medlag to maxlag}$
  geinf{medlag to maxlag} geinfr{medlag to maxlag} geeg{medlag to maxlag} gegdpg{medlag to maxlag}  $
  ukinf{medlag to maxlag} ukinfr{medlag to maxlag} ukeg{medlag to maxlag} ukgdpg{medlag to maxlag}   $
  frinf{medlag to maxlag} frinfr{medlag to maxlag} freg{medlag to maxlag} frgdpg{medlag to maxlag}   $
  itinf{medlag to maxlag} itinfr{medlag to maxlag} iteg{medlag to maxlag} itgdpg{medlag to maxlag}    $
  cainf{medlag to maxlag} cainfr{medlag to maxlag} caeg{medlag to maxlag} cagdpg{medlag to maxlag}     $
  constant
*display x
*por cada ecuación
compu ti = %rows(x)
comp k = %cols(x)
display %rows(x) %cols(x)
*Lo que sigue indica que para cada uno de las observaciones (83), la dimensión de smallx será
*será de 29 (las 28 variables más la constante). Los siguientes dos DO se indican para poder
DO T = 1,TI
DIM SMALLX(T)(K)
END DO T
DO T = 1,TI
  DO J = 1,K
  END DO J
END DO T
display smallx
do t = 1,ti
display s_t(t)
DO T = 1,T
END DO T
do t= 1,ti
end do t
*Es importante tener presente que estas tres matrices nos permitirán como establecer
*****MATRIZ LAMNDA
dec vec e_p(nlags)
do ll = 1,nlags
dec vec e_p1(p1)
do ll = 1,p1
if dim_lam==1
compute xsi11(k) = 1.
do j = 1,n*g*p
display e_ngp(j)
do j = 1,d1*p1
do j = 1,N*g*k
if dim_lam==2
do j = 1,d1*p1
do j = 1,g
do ll = 1,p
do j = 1,g
do ll = 1,p
do j = 1,g
do ll = 1,p
do j = 1,g
do ll = 1,p
do j = 1,g
do ll = 1,p
do j = 1,g
do ll = 1,p
do j = 1,g
do ll = 1,p
do j = 1,g
do jj = 1,k
do j = 1,g
do jj = 1,k
do j = 1,g
do jj = 1,k
do j = 1,g
do jj = 1,k
do j = 1,g
do jj = 1,k
do j = 1,g
do jj = 1,k
do j = 1,g
do jj = 1,k
end if
****MATRIZ RHO
*display %rows(xsi2) %cols(xsi2) xsi2 %rows(xsi_2) %cols(xsi_2) xsi_2
dec vec e_p(nlags)
do ll = 1,nlags
*display e_p
do i = 1,g
dim a_xsi2(i)(k)
do j = 1,d1*p1
do j = 1,g
do i = 1,n
do ll = 1,p
do j = 1,g
do i = 1,k
dec vec e_n(n)
*display e_n
****MATRIZ ALPHA
dec vec e_p(nlags)
do ll = 1,nlags
*display e_g
do i = 1,n
dim a_xsi3(i)(k)
do j = 1,d1*p1
do i = 1,n
do j = 1,g*p
do i = 1,n
do i = 1,n
do j = 1,g*k
*display %rows(xsi_3) %cols(xsi_3) xsi_3
*cada uno de dimensión ti=83, que son el número de observaciones por cada variable
DO T = 1,ti
****MATRIZ M_1
do i = 1,n*g*k
do lam = 1,dim_lam
end do lam
do i = 1,ng*k
do i = 1,ng*k
end do ii
DO T = 1,ti
do i = 1,n*g
do lam = 1,dim_lam
do i = 1,ng
do i = 1,ng
end do t
display %rows(x_m(83))
*display x_m(83)
do t = 1,ti
end do t
comp t1 = ti
do t = 1,t1
do la = 1,dim_lam
do j = 1,g
do i = 1,n
end do t
do t = 1,t1
end do t
do draws = 1,ndraws
disp draws
 do t = 1,ti
 dim u2(t)(k_1)
 end do t
*disp draws draws1
** kalman filter
 do t = 2,t1
 end do t
*DISP DRAWS DRAWS1
 do sp = 1,DIM_LAM
 end do sp
 end do sp
 end do sp
 do t = 2,t1
 do sp = 1,dim_lam
  end do sp
  end do sp
 end do sp
 end do t
 compute part6 = .0
 DO T = 2,t1
  if exact ==0
  if exact ==1
end do t
 do i = 1,dim_lam
 end do lam
 do i = 1,g
 do i = 1,n
 end do draws1
 do t = 2,ti
 end do t
end do draws
comp nvar = ng
smpl beg tempend
do draws = 1,ndraws
  do sp = 1,dim_lam
lags 1 to nlags
do draws = 1,ndraws
 do j = 1,ng
 do i = 1,k
display sigm
*display responses
source condition.src
# usgdpg tempend+1 usgdpg(tempend)+1.
* # usgdpg tempend+2 usgdpg(tempend)+.5
* # usgdpg tempend+3 usgdpg(tempend)+.25
* # usgdpg tempend+4 usgdpg(tempend)
# useg tempend+1 useg(tempend)+1.
* # useg tempend+2 usgdpg(tempend)+.5
*e incondicional
 do i = 1,nvar
  do j = 1,nstep
end do draws
** compute here IRF and bands for each variable
** 4 = US gdp; 8 = JP gdp; 12 = DE gdp ; 16 = UK; 20 = FR gdp; 24 = IT gdp; 28 = CA gdp
comp j = 16
do j = 1,nvar
   smpl 1 ndraws
      do i=1,nstep
   smpl 1 nstep
      # resp(j)
      # upper(j) / 2
      # lower(j) / 2
do j = 4,28,4
*smpl 1 nstep
graph 2
# resp(4)
# resp(8)
# resp(12)
# resp(16)
# resp(20)
# resp(24)
# resp(28)
smpl 1 nstep
      # resp(4)
      # upper(4) / 2
      # lower(4) / 2
      # resp(8)
      # upper(8) / 2
      # lower(8) / 2
      # resp(12)
      # upper(12) / 2
      # lower(12) / 2
      # resp(16)
      # upper(16) / 2
      # lower(16) / 2
      # resp(20)
      # upper(20) / 2
      # lower(20) / 2
      # resp(28)
      # upper(28) / 2
      # lower(28) / 2
      # resp(24)
      # upper(24) / 2
      # lower(24) / 2
carlosvillarreal
My data and my code
CALENDAR 1951
ALL 2011:01
print
disp 2011:1
*Además:
compute beg=1951:1
compute nstep=8  ;*Número de etapas de respuesta
smpl beg tempend
print
compute dim_lam=2 ;*Dependiendo de los componentes comunes de lamnda, esta se debe cambiar según sea el caso
compute zeta=0.0
compute ng=n*g
close data
print
*EL VAR
*Procedemos a estimar sigma^2 que es sigma_eps  Q_0, Este último término Q_0 representa la varianza
lags 1 to 1
display sigma_eps
display omega
display beta_ols1
*Ahora sigma^2
compute s_e=0.0
if alter1==1
linreg i
disp s_e
end dofor
if alter1==0
end if
*disp s_e
disp big_phi
disp phi_1 phi_1inv
disp phi_2 phi_2inv
disp phi_3 phi_3inv
do i = 1,dim_lam
display big_phi
do i = 1,g
display big_phi
do i = 1,n
display big_phi
disp big_phiinv
smpl(reglist)
 constant
 print
table
make(transpose) Y
disp y
comp ti = %cols(y)
display ti
dec vec hetero(ti)
*display hetero
dec vec s_t(ti)
*está compuesta de vectores y esta a su vez es de dimensión 60x1 (60x25). La X grande(big) está
*compuesta de rectangulares, y también es de dimensión 60x1(60x25)
*not interdep/interdep, es decir para que no tengamos problemas de muchos parámetros a estimar
*y no suficientes observaciones para hacerlo.
*Construimos la matriz X y  la matriz X(t-s) con los rezagos de las variables endógenas (un período)
make X
 constant
display x
disp %rows(x) %cols(x)
*por cada ecuación
display ti k
*Lo que sigue indica que para cada una de las observaciones (60), la dimensión de smallx será
DO T = 1,TI
DIM SMALLX(T)(K)
END DO T
DO T = 1,TI
  DO J = 1,K
  END DO J
END DO T
*display smallx
*disp %rows(smallx(60)) %cols(smallx(60))
*El número de rezagos dependerá del valor que se le de a s, que para este caso será de 1.
*En lo que sigue, calculamos el sigma_t(25x1), que multiplica a X'X(25x60:60x25)
do t = 1,ti
display s_t(t)
DO T = 1,TI
display %rows(bigx(T)) %cols(bigx(T))
END DO T
do t= 1,TI
disp smally(t)
end do t
disp %rows(smally(t)) %cols(smally(t))
disp %rows(smally)
disp smally
*****MATRIZ LAMNDA
dec vec e_p(nlags)
do ll = 1,nlags
dec vec e_p1(p1)
do ll = 1,p1
dec vec e_ng(n*g) e_d(d1)  e_ngp(n*g*p+d1*p1) xsi11(k) xsi1_1(n*g*k)
display e_d %rows(e_d) %cols(e_d); * Esto es 1x1
display %rows(e_ngp) %cols(e_ngp); *Esto es 24x1
if dim_lam==1
do j = 1,n*g*p
display e_ngp(j)
do j = 1,d1*p1
do j = 1,N*g*k
*Ahora revisamos cuando la dimensión de lamnda es 1, quiere decir que todos los países forman
*parte de un mismo grupo.
*Cuando lmanda es igual a 2, entonces tenemos dos sub grupos. En este caso, por el orden de las
*variables, estaríamos hablando de los países CAN (Colombia y Perú) y NoCAN (Chile y México)
if dim_lam==2
do j = 1,d1*p1
do j = 1,g
do ll = 1,p
do j = 1,g
do ll = 1,p
do j = 1,g
do ll = 1,p
do j = 1,g
do ll = 1,p
do j = 1,g
do jj = 1,k
do j = 1,g
do jj = 1,k
do j = 1,g
do jj = 1,k
do j = 1,g
do jj = 1,k
end if
display xsi_1
****MATRIZ RHO
dec vec e_p(nlags)
do ll = 1,nlags
display e_p
do i = 1,g
dim a_xsi2(i)(k)
do j = 1,d1*p1
do j = 1,g
do i = 1,n
do ll = 1,p
do j = 1,g
do i = 1,k
dec vec e_n(n)
*display e_n
disp xsi_2
****MATRIZ ALPHA
dec vec e_p(nlags)
do ll = 1,nlags
*display e_pg
do i = 1,n
dim a_xsi3(i)(k)
do j = 1,d1*p1
do i = 1,n
do j = 1,g*p
do i = 1,n
do i = 1,n
do j = 1,g*k
disp xsi_3 %rows(xsi_3) %cols(xsi_3)
*cada uno de dimensión ti=60, que son el número de observaciones por cada variable
* y alpha, los cuales presentarán los efectos que se quieren analizar (esto para la reparametrización)
DO T = 1,ti
****MATRIZ M_1
*M_1=[xsi_1. xsi_2, xsi_3]
display m_1 %rows(m_1) %cols(m_1)
do i = 1,n*g*k
do lam = 1,dim_lam
end do lam
do i = 1,ng*k
do i = 1,ng*k
end do ii
DO T = 1,ti
do i = 1,n*g
do lam = 1,dim_lam
do i = 1,ng
do i = 1,ng
end do t
display %rows(x_m(60))
display %rows(x_m) ;* Esto en realidad sería 1440x12
do t = 1,ti
end do t
disp %rows(lambda(ti)) %cols(lambda(ti))
disp %rows(lambda(2)) %cols(lambda(2))
comp t1 = ti
do t = 1,t1
do la = 1,dim_lam
do j = 1,g
do i = 1,n
end do t
display %rows(x_m(60)) %cols(x_m(ti))
* Se configuran las matrices para los valores futuros (adelantos) de los indicadores
do t = 1,t1
end do t
disp hetero
do draws = 1,ndraws
disp draws
 do t = 1,ti
 dim u2(t)(k_1)
 end do t
*disp draws draws1
** kalman filter
 * Este comando %mqform(omegaTT_1,tr(emme_mc(1)), toma la traspuesta de emme_mc(1),
 *la multiplica por omegaTT_1 y la multiplica finalmente por emme_mc(1)
 comp u2(1) = %ran(1.) ;*Este %ran(1) crea un número aleatorio aleatorio de una distribución normal de media cero y varianza x^2
 do t = 2,t1
 end do t
*DISP DRAWS DRAWS1
 do sp = 1,DIM_LAM
 end do sp
 end do sp
 end do sp
 do t = 2,t1
 do sp = 1,dim_lam
  end do sp
  end do sp
 end do sp
 end do t
 compute part6 = .0
 DO T = 2,t1
  if exact ==0
  if exact ==1
end do t
 do i = 1,dim_lam
 end do lam
 do i = 1,g
 do i = 1,n
 end do draws1
 do t = 2,ti
 end do t
end do draws
comp nvar = ng
smpl beg tempend
do draws = 1,ndraws
  do sp = 1,dim_lam
lags 1 to nlags
infobox(action=define,progress,lower=1,upper=ndraws) 'impulso respuesta'
do draws = 1,ndraws
 do j = 1,ng
 do i = 1,k
*e incondicional
do i = 1,nvar
  do j = 1,nstep
end do draws
** 6 = COL rgdpo; 12 = CHL rgdpo; 18 = MEX rgdpo 24 = PER rgdpo;
comp j = 8
do j = 1,nvar
   smpl 1 ndraws
      do i=1,nstep
   smpl 1 nstep
      # resp(j)
      # upper(j) / 2
      # lower(j) / 2
do j = 4,28,4
*smpl 1 nstep
graph 2
# resp(6)
# resp(12)
# resp(18)
# resp(24)
COMP MINLOWER = -0.5, MAXUPPER = 1.
smpl 1 nstep
spgraph(hfields=2,vfields=2,header='Respuestas al choque de las variables reales de Colombia')
      graph(ticks,min=minlower,max=maxupper,number=0,header='CHL') 2 1 1
      # resp(6)
      # upper(6) / 2
      # lower(6) / 2
      graph(ticks,min=minlower,max=maxupper,number=0,header='COL') 2 2 1
      # resp(12)
      # upper(12) / 2
      # lower(12) / 2
      graph(ticks,min=minlower,max=maxupper,number=0,header='MEX') 2 1 2
      # resp(18)
      # upper(18) / 2
      # lower(18) / 2
      graph(ticks,min=minlower,max=maxupper,number=0,header='PER') 2 2 2
      # resp(24)
      # upper(24) / 2
      # lower(24) / 2
x_m is dimensioned TI and TI is only 58. That seems to be a debugging statement that can be safely deleted anyway.
carlosvillarreal
Hi Tom.
I have reviewed one by one the configurations of the X_m array and I do not find where it reports a dimension of 58. Could you please be more specific in telling me which line you identify the error in?
Additionally I wanted to consult if you can print and graph the variables upper, lower and resp. Could you please help me.
Thank you very much. regards
It would help if you would let me know how you came to be running this. I'm guessing that you didn't write it. Did you make changes to what was supposed to be a running program? If so, what were they?
This is how X_M is dimensioned. TI is 58, hence X_M(60) doesn't exist. Again, the display of XM(60) looks like it was a debugging statement which can be simply deleted.
On looking a bit more closely, the whole problem seems to be that INF_CHL is missing the last two data points:
YEAR                  61  1980.9836066    17.7815371  1950.0000000  2011.0000000
RGDPO_CHL             61     0.0176111     0.0277445    -0.0727014     0.0965022
EMP_CHL               61     0.0103380     0.0137222    -0.0347595     0.0500508
INF_CHL               59    -0.0170503     0.2639737    -0.7692661     0.6565553
CK_CHL                61     0.0248119     0.0144659    -0.0200248     0.0518856
CTFP_CHL              61    -0.0035807     0.0241809    -0.0732374     0.0704754
Fix that, and you'll be back up to 60 working data points.
carlosvillarreal
Hello Tom,
You are right, I am replicating a code prepared by Ciccarelli and Canova, of the ECB. Here I leave the original program and the data of them.
Original Data
Original CODE:
https://www.dropbox.com/s/g6j2k48mergvk ... a.rpf?dl=0
My data:
My adapted code:
https://www.dropbox.com/s/kroon1hs9vzac ... am.v1?dl=0
Thank you so much
Regarding the two data from INF_CHL, I think I've already made the correction since when you explained the smpl (reglist) code to me. I send again my verified data and the program adapted to my exercise.
I tried running the program once I deleted dec vect [rect] X_M (ti) and it did not work, since it does not allow me to size an array that has not been declared.
It's not the DECLARE statement that's the problem. (As you can see, you can't delete that). It's the DISPLAY instruction that's specifically requesting X_M(60).
