Multiple IRF's on single graph
umee
Unread post by umee »
How would I go about putting multiple IRFs from different specification on the same graph? Is there a way to tell RATS to store the impulses, and then print them all on the same graph. My code is below, but I assume you only need to alter the last part pertaining to graphs. Again, what I want to do is run several different specifications, but I'm only changing one variable, changing "X" to "Y" then to "Z", so each specification has 6 other variables in common. And I want the responses for the common variables on the same graph. For instance, I want GDP for all three specifications on one graph. How can I do this?
Code:
system(model=varmodel)
variables gdp gdpdef cprindex fedfunds bognonbr totresns X
lags 1 to 2
estimate(noprint)
source uhligfuncs.src
dec vect[strings] vl(8)
compute vl=||"real GDP","GDP price defl","Comm. Price Ind.",$
   "Fed Funds Rate","Nonborr. Reserv.","Total Reserves","X"||
* n1 is the number of draws from the posterior of the VAR
* n2 is the number of draws from the unit sphere for each draw for the VAR
* nvar is the number of variables
* nstep is the number of IRF steps to compute
* KMAX is the "K" value for the number of steps constrained
compute n2=50000
compute nkeep=1000
compute nvar=7
compute nstep=20
compute KMIN=1
compute KMAX=2
* Most draws are going to get rejected. We allow for up to nkeep good
* ones. The variable accept will count the number of accepted draws.
* GOODRESP will be a RECT(nsteps,nvar) at each accepted draw.
declare vect[rect] goodresp(nkeep)
impulse(noprint,model=varmodel,factor=%decomp(%sigma),results=impulses,steps=nstep)
compute accept=0
infobox(action=define,progress,lower=1,upper=n2) $
   "Monte Carlo Integration"
do subdraws=1,n2
   * Do the subdraws over the unit sphere. These give the weights on the
   * orthogonal components.
   compute a=%ransphere(nvar)
   * Check that the responses have the correct signs for steps 1 to
   * KMAX+1 (+1 because in the paper, the steps used 0-based
   * subscripts, rather than the 1 based subscripts used by RATS).
   if UhligAccept(a,KMIN,KMAX+1,||+4,-3,-2,-5,-1||)==0
         goto reject
   * This is an accepted draw. Copy the information out. If we have
   * enough good ones, drop out of the overall loop.
   compute accept=accept+1
   dim goodresp(accept)(nstep,nvar)
   ewise goodresp(accept)(i,j)=ik=%xt(impulses,i)*a,ik(j)
   infobox(current=subdraws)
   if accept>=nkeep
      break
:reject
end do subdraws
infobox(action=remove)
* Compute Fry-Pagan minimizers. This uses the interquartile range of the
* responses at each horizon rather than standard error for rescaling the
* difference between a test response and the median.
dec vect[series] targets(nvar)
dec vect[series] rescale(nvar)
dec vect[series] lower(nvar) upper(nvar)
do i=1,nvar
   set targets(i) 1 nstep = 0.0
   set rescale(i) 1 nstep = 0.0
   set lower(i)   1 nstep = 0.0
   set upper(i)   1 nstep = 0.0
   do k=1,nstep
      set work 1 accept = goodresp(t)(k,i)
      compute frac=%fractiles(work,||.25,.50,.75,.16,.84||)
      compute targets(i)(k)=frac(2)
      compute rescale(i)(k)=1.0/(frac(3)-frac(1))
      compute lower(i)(k)=frac(4)
      compute upper(i)(k)=frac(5)
   end do k
* This does the optimization. It parameterizes the unit circle using the
* stereographic mapping. The function being minimized is the sum of
* squared standardized gaps between the impulse responses given the test
* rotation and median sign-restricted response where the standardization
* is 1/IQR.
dec vect g(nvar-1)
compute g=%fill(nvar-1,1,1.0)
nonlin g
dec real gap
find(trace) min gap
   compute a=%stereo(g)
   compute gap=0.0
   do k=1,nstep
      compute gap=gap+%normsqr(%xt(rescale,k).*(%xt(targets,k)-%xt(impulses,k)*a))
   end do k
end find
* Graph with 16-84% bounds. Note that there is no reason the Fry-Pagan
* minimizing IRF has to be within the bounds at all horizons since it's
* chosen to minimize the sum across (in this case) 360 squared
* deviations from the median responses.
set resp 1 nstep = 0.0
spgraph(vfields=4,hfields=2,$
  hlabel="Impulse Responses")
do i=1,nvar
   set resp 1 nstep = ik=%xt(impulses,t)*a,ik(i)
   graph(ticks,number=0,picture="##.##",header="Impulse Responses for "+vl(i)) 3
   # resp     1 nstep
   # lower(i) 1 nstep 2
   # upper(i) 1 nstep 2
Re: Multiple IRF's on single graph
It sounds like you would want to do a COPY instruction to save them into different files from each program, then do a separate program to pull the responses out of the files and do the graph.
umee
Is there code to illustrate how I might go about doing this?
Not really---that's a rather specialized situation. If you're putting three (e.g.) GDP responses on one graph, I assume the plan is to just do the responses and not the bounds. (Three responses plus bounds would be a tangled mess). This would save the responses into the file withx.txt. You can make three copies of the file and change that to (say) withy.xt and withz.txt.
dec vect[series] saveresponse(nvar)
do i=1,nvar
   # resp     1 nstep
   set saveresponses(i) 1 nstep  = resp
open copy withx.txt
copy(format=free,org=columns) / saveresponses
Then you would do a separate program that reads the three files into three different sets of series and organize your graphs.
umee
You're correct, I only want the responses, not the error bands.
I'll try your code, and see what I can dig up on reading in the files.
umee
Tom,
Do I have to specify a director or folder for the copy of responses? I don't see the file after running the code. Furthermore, the last line of code gives me an 'unassigned' error, which may explain why I don't see the file.
Unless you give a specific directory on the file name on the open copy, they will be written to the current working folder which would typically be the folder where you have the program file that you're running.
umee
Thanks, I figured it out. You can do something like this and avoid having to save/copy and then read in the irfs.
set GDP_spec1 1 nstep = ik=%xt(impulses,t)*a,ik(1)
set GDP_spec2 1 nstep = ik=%xt(impulses,t)*a,ik(1)
set GDP_spec3 1 nstep = ik=%xt(impulses,t)*a,ik(1)
set GDP_spec4 1 nstep = ik=%xt(impulses,t)*a,ik(1)
graph(number=1,klabel=||"Spec 1","Spec 2","Spec 3","Spec 4"||, key=below,hea="Responses of House Price Index") 4 ; # GDP_spec1 ; # GDP_spec2 ; # GDP_spec3 ; # GDP_spec4
