Replication of Smets and Wouters (2007)
Dear RATSers,
I am a beginner in DSGE and find that some RBC DSGE models can be solve with RATS. My question is that can RATS reproduce the results of Smets and Wouters (2007) or similiar papers using Bayesian estimation techniques?
Many thanks,
Many thanks,
Re: Replication of Smets and Wouters (2007)
I am trying to convert Smets and Wouters (2007) Dynare files into RATS form. The problem is some local variables defined as #var_names = ... (prefix with #) cannot be converted by RATS conversion utility.
Of course, we can rewrite the equations without any local model variables but it is worth knowing the natural way in RATS to declare the macro variables like dynare done.
Any ideas? Please share or show me the way to handle this issue.
Thanks in advance,
Thanks in advance,
Attached is a set of programs that come at least close to replicating the model. It seemed a bit too "blackboxy" for my taste---there were more than a few places where things really weren't documented and would have to be hacked out of the Matlab code.
- Smets Wouters RATS.zip
- (87.5 KiB) Downloaded 1556 times
Many thanks for your efforts. But I cannot run your code with trial version 9.1. The messages are:
Model SW US (2007) message is below:
## SX19. This Character is Illegal Here
>>>>compute cstderrqs=?<<<<
Model SW (2003):
## FO15. Model can't be expanded. Includes exogenous series reference.
Taking derivative with respect to YP{0}
Error was in FRML EQN10
Model with data: withdata.rpf generates error at "source smetswouters.src" line. The message is:
## FO17. Mismatch between unstable roots and expectational terms.
I have copied all *.src into both working dir and source dir. I run some RBC example without any problems.
Please advise to correct!
Thanks a lot.
Model SW (2003):
Thanks a lot.
These programs are as I left them when last I tried to work on this. The 2007 paper had some shock sizes that didn't seem to be specified. You might want to look through that paper (reference is that the top) more carefully and see if you can find the missing information.BinhPham wrote:Dear Tom,
And that was the reason I gave up on that. The SW model has a "shadow" set of equations to generate potential output and no one seems to want to actually write down what the equations are for that. (The SW appendix on the AER web site has a blank space where they're supposed to be).BinhPham wrote: Model SW (2003):
Thank for your post. I am trying to correct something ...then upload asap.
I have two questions about DSGE estimation:
(1) When I use the method in "Bayesian Estimation: Hyperinflation Model" in RATS Handbook for State-Space Models to estimate a simple DSGE mode. In the "function EvalModel":
If I use "compute gdlm=%dlmgfroma(adlm)" or "compute gdlm=||1.0,-1.0||~\%identity(%rows(adlm)-2)"
The estimation will be done,but the graph is one horizontal line!
If I use "compute gdlm=||1.0,-1.0||~\%identity(%rows(adlm)-2)"above, RATS tell me:
## MAT3. Matrix with Dimensions 21 x 22 Involved in DLM-G matrix Operation. Need rxN
The Error Occurred At Location 200, Line 3 of EVALMODEL
Called From Location 613, Line 26 of EVALPOSTERIOR
Called From Location 28, Line 1 of loop/block
So:
*1) How to set the matrix of gdlm? Every time we guess it ?
*2) Why are the density graphs horizontal lines? If we use Uniform destribution, we can't get the resoult from bayesian estimation?
(2) In program of "withdata" (replication for Smets Wouters (2007)),
Why shouldn't we set the prior destribution of parameters? Can we set the prior destribution of parameters in program of "withdata"?Can we use the commands below( in "Bayesian Estimation: Hyperinflation Model") to get the density of parameters ?
@mcmcpostproc(ndraws=ndraws,mean=bmean,stderrs=bstderrs,cd=bcd) bgibbs
set alphas 1 ndraws = bgibbs(t)(1)
density(grid=automatic,maxgrid=100,band=.75) $
alphas 1 ndraws xalpha falpha
scatter(style=line,vmin=0.0,footer="Posterior for the_c")
# xalpha falpha
Thank you!
Sincerely,
Junlin Mu
So:
# xalpha falpha
Thank you!
Sincerely,
Junlin Mu
- question for Bayesian Estimation.rar
- (26.17 KiB) Downloaded 1519 times
So far as I can tell, those all work fine if you run the entire program. However, the G option on the DLM is no longer necessary, since PRESAMPLE=ERGODIC to handle it without any (prior) calculations:junlin wrote:Dear Tom,
So:
dlm(a=adlm,f=fdlm,sw=%diag(||sig_eps^2,sig_eta^2||),y=||x,mu||,$
c=cdlm,presample=ergodic,method=solve)
(That's described in the text, but apparently didn't make it into the program). The use of the G option is deprecated in favor of the PRESAMPLE=ERGODIC because it does change from model to model.
They aren't so far as I can tell.junlin wrote: *2) Why are the density graphs horizontal lines? If we use Uniform destribution, we can't get the resoult from bayesian estimation?
As I said in the post where I included those, those aren't finished products, and, in fact, are far from it. If you can find someone who has actually documented the complete model, please post a reference.junlin wrote: (2) In program of "withdata" (replication for Smets Wouters (2007)),
# xalpha falpha
Hi Tom. I'm trying to estimate a DSGE model for the US data. As a first step, I tried to just execute the program that you had provided. I got the following error message
So, the first question is why doesn't the program run?
Secondly, I was reading a paper that used several macro time series to estimate a DSGE model. In your program I don't even see a place where you can read and use the current data for the US. Please advise. Thanks. Best, Bahram
Hi Tom and everyone. I'm trying to estimate a DSGE model for the US data. As a first step, I tried to just execute the program smetswouters.src on the data set smetswouters.prn that is on the forum. I didn't change anything. I got the following error message multiple times.
I can't figure out why this error is showing up. Has anyone on the Forum tried to do the same thing successfully? Any help is much appreciated. Thanks much. Bahram
