DSGE-VAR implementation in RATS
BinhPham
There is another question about DSGE-VAR. To my understanding, DSGE-VAR is that DSGE model has been solved via DSGE instruction (in RATS) to obtain matrix A and F in state-space form. The next step is to use procedure varfromdlm to have the corresponding VAR model. Is it right?
Thanks in advance,
Thanks in advance,
Re: DSGE-VAR implementation in RATS
I've seen the phrase used in at least two ways---either as you describe (which generates the VAR coefficients from the covariance generated by a DSGE solved out to state-space form) or as a VAR estimated from the data with a prior derived from a DSGE.
BinhPham
Thanks for your reply. Could I have an example code for any DSGE-VAR model (an replication work) that you already have ?
Thanks in advance,
Thanks in advance,
To be honest, I don't have any.
