I am graphing impulse response functions. On the lines, I want to use markers (for example a cross or something) to indicate if the responses are significant at a particular horizon.
Anybody has any idea how can I do that?
Sincerely,
Sajjadur Rahman
Marker on the line
Re: Marker on the line
One way I've seen something like this done is using a stacked bar graph with only one color active at each point. For instance, this will be black for the larger values and blue for the smaller ones:
compute nobs=50
set test 1 nobs = sin(.3*t)
set testblack 1 nobs = %if(abs(test)>0.7,test,%na)
set testblue 1 nobs = %if(abs(test)<=0.7,test,%na)
graph(style=stacked) 2
# testblack
# testblue
I've also seen background shading used for the significant segments.
STYLE=SYMBOLS isn't designed to mark specific locations (it's a line with occasional symbols to identify it). The only style that would work for marking specific locations is STYLE=DOTS. However, the dots are too small to be laid on top of a line---they're designed to be the one and only indicator of the series. You can see how something like:=
compute nobs=50
set testdot 1 nobs = %if(abs(test)>0.7,test,%na)
graph(style=line,overlay=dots,ovsamescale) 2
# test
# testdot / 5
works if you play with the styles a bit.
compute nobs=50
# testblack
# testblue
compute nobs=50
# test
# testdot / 5
