VECMCAUSE.RPF—Causality tests in error correction model
VECMCAUSE.RPF is an example of testing for causality in a VECM. This has separate tests for causality and long-run causality.
Detailed description
w-tb3n6ms.txt
Data file
(62.86 KiB) Downloaded 1552 times
upani
Re: VECMCAUSE.RPF—Causality tests in error correction model
Unread post by upani »
I want to know whether this programme is suitable for checking weak exogeneity test.
With regards,
Upani
X being weakly exogenous (for the beta in the cointegration vector) in the (X,Y) relationship is another way of stating that Y doesn't cause X long-run.
upani
Dear All,
I am estimating the VECM with spot and future price. I am using vecmcause.rpf function to estimate this.
*VECM Short-run Causality and Long-run Causality
@johmle(lags=5,det=rc,cv=cv)
# LFP LSP
LINREG DLFP
# Z{1} DLFP{1 to 4} DLSP{1 to 4}
set z = LFP-LSP
linreg dlfp
# z{1} dlfp{1 to 4} dlsp{1 to 4}
exclude(title="Test for Spot Price causing Future Price")
# z{1} dlsp{1 to 4}
exclude(title="Test for Spot Price long-run causing Future Price")
# z{1}
* Futue Price causing Spot Price
linreg dlsp
exclude(title="Test for Future Price causing Spot Price")
# z{1} dlfp{1 to 4}
exclude(title="Test for Future Price long-run causing Spot Price")
# z{1}
After running the code i got the result which is giving the following result.
Dependent Variable DLFP
Weekly Data From 1959:01:16 To 1972:11:17
Usable Observations                       723
Degrees of Freedom                        714
Centered R^2                        0.0183605
R-Bar^2                             0.0073617
Uncentered R^2                      0.0184954
Mean of Dependent Variable       0.0005295308
Std Error of Dependent Variable  0.0451958154
Standard Error of Estimate       0.0450291490
Sum of Squared Residuals         1.4477237217
Log Likelihood                      1220.2576
Durbin-Watson Statistic                1.9975
1.  Z{1}                         -0.137533229  0.213611823     -0.64385  0.51988172
2.  DLFP{1}                       0.055408510  0.196688977      0.28171  0.77825040
3.  DLFP{2}                      -0.045075649  0.176082637     -0.25599  0.79803117
4.  DLFP{3}                      -0.298758427  0.149946042     -1.99244  0.04670317
5.  DLFP{4}                      -0.200389465  0.108827208     -1.84135  0.06598428
6.  DLSP{1}                      -0.011645722  0.195881453     -0.05945  0.95260801
7.  DLSP{2}                       0.073686676  0.175396297      0.42012  0.67452759
8.  DLSP{3}                       0.319689325  0.146596548      2.18074  0.02952816
9.  DLSP{4}                       0.192572149  0.102848127      1.87239  0.06156071
R-Bar^2                             0.0073617
Null Hypothesis : The Following Coefficients Are Zero
Z                Lag(s) 1
DLSP             Lag(s) 1 to 4
F(5,714)=      2.37598 with Significance Level 0.03753272
Z                Lag(s) 1
t(714)=  -0.643847 or F(1,714)=   0.414538 with Significance Level 0.51988172
Dependent Variable DLSP
Centered R^2                        0.1189251
R-Bar^2                             0.1090531
Uncentered R^2                      0.1190266
Mean of Dependent Variable       0.0005046662
Std Error of Dependent Variable  0.0470507803
Standard Error of Estimate       0.0444112244
Sum of Squared Residuals         1.4082627910
Log Likelihood                      1230.2479
Durbin-Watson Statistic                2.0008
1.  Z{1}                          0.661788913  0.210680477      3.14120  0.00175205
2.  DLFP{1}                       0.280735548  0.193989859      1.44717  0.14828930
3.  DLFP{2}                       0.115947684  0.173666296      0.66765  0.50457504
4.  DLFP{3}                      -0.177690602  0.147888368     -1.20152  0.22994854
5.  DLFP{4}                      -0.106650721  0.107333797     -0.99364  0.32073674
6.  DLSP{1}                      -0.202259818  0.193193417     -1.04693  0.29548654
7.  DLSP{2}                      -0.075602209  0.172989374     -0.43703  0.66221896
8.  DLSP{3}                       0.218149954  0.144584837      1.50880  0.13179163
9.  DLSP{4}                       0.125687247  0.101436766      1.23907  0.21572675
Z                Lag(s) 1
DLFP             Lag(s) 1 to 4
F(5,714)=     18.68860 with Significance Level 0.00000000
Z                Lag(s) 1
t(714)=   3.141197 or F(1,714)=   9.867120 with Significance Level 0.00175205
I am bit confused over the interpretation as spot is not having any long-run relationship with future but future is having a long run relationship with spot.
I will grateful if you help me to understand the issue over here. Because Weak exogeneity test suggest the reverse.
Thanks and Regards,
Upananda
crude.xlsx
(26.8 KiB) Downloaded 1161 times
I'm not sure what you mean by "weak exogeneity test suggests the reverse". What you're citing IS the (or at least a) test for weak exogeneity. The interpretation is that the forward price is weakly exogenous in the cointegrating relationship.
upani
Sir,
In the first equation results
Z Lag(s) 1
DLSP Lag(s) 1 to 4
Z Lag(s) 1
As per the above results, there is a short-run causality from spot to future price but there is no long-run causality from spot to future. Am i correct?
With regards,
Upananda
There is fairly weak evidence of causality (.03 isn't all that significant at a data set that size), but yes, you would conclude that there is causality but not long-run causality.
upani
Dear Sir,
Thanks a lot for clarifying my doubt. Similarly in the second equation
R-Bar^2                             0.1090531
Z                Lag(s) 1
DLFP             Lag(s) 1 to 4
Z                Lag(s) 1
Here there is a short-run causality from future to spot and there is a long-run causality from future to spot. In the first equation there is a weak long-run relationship between spot and future. But Here there strong long-run causality between future and spot. Is not it the same inference given that in the long-run equilibrium spot price will be equal to future price or vice versa.
With sincere regards,
Upananda
The equilibrium is Spot=Future. They are never equal, but the process is pushed towards that. Weak exogeneity of the futures price (i.e. if the actual loading on the disequilibrium is zero in the futures equation) means that the long-run adjustment is entirely through the spot price. Which isn't that hard to imagine given that the alternative in the spot market is to take physical delivery, which is expensive.
Last bumped by TomDoan on Mon Dec 30, 2024 9:42 am.
