The series needs to be defined over some range of observations before you can dimension the array stored at a particular entry.
The best way to do this is usually to use the GSET instruction. Depending on what you want to achieve, you can probably take care of dimensioning all the arrays with the GSET as well. Here's a simple example that dimensions the vectors to have 10 elements, and initializes them to zero:
