System estimation and normality test
I have a autocorrelated time series, which I want to test for normality.
Therefore I want to estimate the following system of equations by GMM, where I correct the errors for autocorrelation:
x_t = a_1 +error1
(x_t)^2 - 1 = a_2 + error2
(x_t)^3 = a_3 + error3
(x_t)^4 -3 = a_4 +error4
To test normality I want to test the joint hypothesis: a_1=a_2=a_3=a_4 and the four single hypothesis a_i = 0 for i = 1,...,4
My two questions are:
1) Within this framework GMM would correspond to OLS right? Is it therefore possible to estimate the system by SUR?
2) how would I test the joint hypothesis a_1=a_2=a_3=a_4=0?
Thank you
Best Jules
x_t = a_1 +error1
Thank you
Best Jules
Re: System estimation and normality test
Doesn't that work only if the variance is 1?
Yes, you could use SUR, but it's probably simpler to use NLSYSTEM to do the GMM estimates. See the westcho_summary.rpf program in the West and Cho JOE 1995 replication for an example.
You can just use TEST for that.
Yes you are right, I test for Standard normality.
Since i am Not Using any Instruments isnt gmm simply Öls? And wouldnt a simple sur estimate those linear equations simpler?
Best
Jules
Best
Jules
It's even simpler than OLS---you can do all of those by just taking means. However, you're doing a joint test and you need a joint covariance matrix of the parameters in order to do that. NLSYSTEM is the simplest way to do that---the whole thing takes about five lines.
Thanks a lot. When I do the joint wald Test, do you think I Run into problems regarding the autocorrelation in the series? Or does the newey-west corrected estimator Account for that?
Best
Jules
Best
Jules
That's the whole point of doing the robusterrors. The point estimates don't change, but the covariance matrix does.
One further question regarding the use of the instruments instruction. In the WESTCHO_SUMMARY.RPF the following code is given
In the formulas f1,...,f4 there is also just an "intercept" estimated, which is mu1,...,m4.
When GMM is applied I am not sure whether I understand the following codeline correctly:
instruments constant
As far as I understand the constants of the four equations are m1,...,m4.
When I apply GMM shouldn't "instruments mu1 mu2 mu3 mu4" be the right code, or does RATS notice that m1,...,m4 are the constants and thats why " instruments constant " is used?
Jules
nonlin(parmset=meanparms) m1 m2 m3 m4
frml f1 = s{0}-m1
frml f2 = (s{0}-m1)^2-m2
frml f3 = (s{0}-m1)^3-m3
frml f4 = (s{0}-m1)^4-m4
compute m1=0.0
compute m2=1.0
compute m3=0.0
compute m4=0.5
nlsystem(robust,lags=4,lwindow=newey,parmset=meanparms,inst) 2 * f1 f2 f3 f4
summarize(title="Mean",parmset=meanparms) m1
summarize(title="Standard Deviation",parmset=meanparms) sqrt(m2)
summarize(title="Skewness",parmset=meanparms) m3/m2^1.5
summarize(title="Excess Kurtosis",parmset=meanparms) m4/m2^2.0-3.0
Jules
INSTRUMENTS CONSTANT
gives you "method of moments" (which existed long before Hansen's work), that is, it solves
sum (condition) x 1 (i.e. CONSTANT) = 0
The "generalized" in GMM is for the use of the weight matrices which have no effect in this case.
AS far as I understand the MM, we have something Like
E(Xu)=0 which is Made feasible by Using Sum(Xu)=0
What do you meaning by" x 1 (i.e. CONSTANT) "?
Thanks jules
Thanks jules
You're overthinking this. Isn't sum(X)=sum(X x 1)? CONSTANT = all ones. That's how you tell it you want to do method of moments, use only CONSTANT as an instrument.
in the post earlier you said that the test instruction can be used to test the joint hypothesis mu_1=...=mu_4=0.
Given some data series, z1m, which I want to test for normality (and which I cannot post here) my code is:
Is the test isntruction used correctly to perfom the Wald test with newey west corrected standard errors?
Moreover I get the following result:
Chi-Squared(4)= 8.914077 or F(4,*)= 2.97852 with Significance Level 0.12974656
Is the P-value at the end for the Chi-Squared(4) or the F(4,*) test?
Thank you
Best Jules
set mom11 = z1m
set mom12 = (z1m^2) - 1
set mom13 = z1m^3
set mom14 = (z1m^4) - 3
compute start = some date
compute end = some date
nonlin(parmset=moments1) m11 m12 m13 m14
frml f11 = mom11 - m11
frml f12 = mom12 - m12
frml f13 = mom13 - m13
frml f14 = mom14 - m14
compute m11 = 0
compute m12 = 0
compute m13 = 0
compute m14 = 0
nlsystem(robust,lags=6,lwindow=newey,parmset=moments1,instr) start end f11 f12 f13 f14
test(form=CHISQUARED)
# 1 2 3 4
# 0 0 0 0
Thank you
Best Jules
They have exactly the same p-value.
And the
# 1 2 3 4
# 0 0 0 0
is the right command to perform the wald test for mu_1=...=mu_4=0 with the above chosen newey west corrected standard errors?
# 1 2 3 4
# 0 0 0 0
In this case, you could shorten it to just
test(zeros,all)
but what you have will work. The form=chisquared isn't necessary, since that's the form that is provided by NLSYSTEM anyway. However, wouldn't a test for Normality only involve the third and fourth moments? Isn't what you sending to this mean 0 variance 1 pretty much by construction? Adding those two to the joint test would reduce the power to detect deviations from Gaussianity.
test(zeros,all)
