Replicating Hafner and Herwartz (2006) VIRFs
OS27
Unread post by OS27 »
This is my first time using RATS so please excuse what I think is a very simple question. I am currently trying to follow the VIRF manual attached. Everything works up until the point where I enter:
dec vect[series] sept92virf(3)
do i=1,3
set sept92virf(i) 1 nstep=0.0
I keep getting the error message:
## SX22. Expected Type INTEGER, Got REAL Instead
>>>>irf(i) 1 nstep=0.0<<<<
I am following the manual word by word so why may this be happening?
GARCH Sample.pdf
(169.67 KiB) Downloaded 850 times
Re: Replicating Hafner and Herwartz (2006) VIRFs
You're missing the space before the =
https://estima.com/ratshelp/setinstruction.html
OS27
Hello Tom,
Thank you for your prompt response. I have already tried putting a space but I am getting the same error:
do i=1,3
set sept92virf(i) 1 nstep = 0.0
>>>>t92virf(i) 1 nstep <<<<
The above is literally copied and pasted from the document.
do i=1,3
set sept92virf(i) 1 nstep =0.0
OS27
Hi I am still unable to resolve this. Could anyone help please?
First of all, the entire program is in the Paper Replications folder so you don't have to cut and paste out of a PDF (or worse, retype).
It looks like you might have done
compute nstep=400.
rather than
compute nstep=400
The first makes NSTEP a real which can't be used for numbering entries.
