Hi There,
I just moved to RATS 8.20 and I am having the problem that I cannot zoom in or out, i.e. cannot change the size of what I see in the RATS input and output windows. I know it sounds like a minor problem but it a bit annoying because I am used to work by running the code as I write on the paper for which the code is run, so I like to display them both. But without the ability to zoom out I can't see till the end of the line any longer.
Any advice on how to fix this problem would be very much appreciated.
Best wishes,
Valerio
Font size
Re: Font size
RATS has never adjusted the font size on the editor window to adapt to changing window sizes. It does that for graphs, but not text. If it's getting cut off horizontally, have you tried rearranging the RATS windows so they are wide but not tall?
David_Stern
Re: Font size
I just installed RATS 9.1 on Mac OS X (El Capitan 10.11.6). On one of my computers the font size is stuck on Monaco 9 which is a bit of a strain to read. When I try to change the font size in the Preferences, after I click the "Change" button the dialog window closes and doesn't let me click "Make Permanent". I've resorted to reducing the screen resolution while using RATS... Oddly on my laptop it is stuck on Monaco 12, which is fine to read but also can't be changed. Is there any way to fix this?
