BVAR Minnesota Prior IRF
Re: BVAR Minnesota Prior IRF
VWEIGHTS would just be V1 (not V1~other shock descriptors)
Jules89
Here is the adjusted code I wrote to save the shocks:
when I want to graph one of the saved shocks I get the following error message: "## SR14. Empty Range on Series SHOCK(2)."
Can you help?
Best
Jules
open data uhligdata.xls
calendar(m) 1965:1
data(format=xls,org=columns) 1965:1 2003:12 $
gdpc1 gdpdef cprindex totresns bognonbr fedfunds
set gdpc1 = log(gdpc1)*100.0
set gdpdef = log(gdpdef)*100.0
source uhligfuncs.src
*** VAR Setup and Storage Matrices
compute lags=12 ;*Number of lags
compute nstep=60 ;*Number of response steps
compute n1= 10000 ;*Number of draws for Gibbs-Loop
compute n2= 50000 ;*Number of draws from the unit sphere for each VAR draw
compute nburn = 9000 ;*Number of burn-in-draws
compute keep = n1 - nburn ;*Number of kept draws
compute nvari = 6 ;*Number of variables
compute kmin = 1 ;*Number of Steps constrained (Lower Bouund)
compute kmax = 5 ;*Number of Steps constrained (Upper Bouund)
compute ncoef = nvari*lags ;*Number of coefficients per equation
compute nkeep = 10000 ;*Number of excepted draws that we actually want
compute tight=.1
compute other=.5
system(model=varmodel)
lags 1 to 12
estimate(noprint,ols,sigma) ;*initial set of estimations
impulse(noprint,model=varmodel,steps=nstep,results=impulses) ;*initial set of of impulse responses
dec vect[strings] vl(6)
compute vl=||"real GDP","GDP price defl","Comm. Price Ind.",$
"Fed Funds Rate","Nonborr. Reserv.","Total Reserves"||
compute nvar=%nvar ;* Number of equations estimated
dec vect olssee(nvar) ;* vector of variances
ewise olssee(i)=sqrt(%sigma(i,i)) ;* standard deviations for rescaling
declare series[rect] bgibbs ;* Storage Series of Rectangulars to save the VAR Coefficient Draws
gset bgibbs 1 keep = %zeros(ncoef,nvari) ;* To dimension the storage matrix inside the series
compute hstart=%regstart(),hend=%regend() ;* Save the estimation range for computing residuals
declare vect[series] shock(nkeep)
********* Minnesota Prior *********
source BVARBuildPriorMN.src
@BVARBuildPriorMN(model=varmodel,tight=tight,other=other) HBPRIORS HPRIORS
@BVARFinishPrior hbpriors hpriors bprior hprior
compute sigmad=%sigma
cmom(noprint,model=varmodel)
********* Gibbs Sampler *********
declare vect[rect] goodresp(nkeep) goodfevd(nkeep)
compute ones=%const(1.0) ;* Fills matrix with a constant value
compute accept = 0
infobox(action=define,progress,lower=1,upper=n1) "Gibbs Sampler"
do draw= 1,n1
infobox(current=draw)
* Draw b given sigma
compute bdraw =%ranmvkroncmom(%cmom,inv(sigmad),hprior,bprior)
compute rssmat=%sigmacmom(%cmom,bdraw)
* Draw sigma given b
compute sigmad = %ranwisharti(%decomp(inv(rssmat)),%nobs)
compute swish = %decomp(sigmad)
if draw<=nburn
next
compute %modelsetcoeffs(varmodel,bdraw)
forecast(model=varmodel,from=hstart,to=hend,errors=resids,static)
impulse(noprint,model=varmodel,results=impulses,steps=nstep,decomp=swish)
gset irfsquared 1 1 = %xt(impulses,t).^2
do subdraws=1,n2
compute a=%ransphere(nvar)
* Check that the responses have the correct signs for steps
* 1 to KMAX+1 (+1 because in the paper, the steps used 0-based
* subscripts, rather than the 1 based subscripts used by RATS).
if UhligAccept(a,KMIN,KMAX+1,||+4,-3,-2,-5||)==0
goto reject
* This is an accepted draw. Copy the information out. If we
* have enough good ones, drop out of the overall loop.
compute accept=accept+1
dim goodresp(accept)(nstep,nvari)
dim goodfevd(accept)(nstep,nvari)
ewise goodresp(accept)(i,j)=ik=%xt(impulses,i)*a,ik(j) ;*%xt(impulses,k) pulls the [nvar x nvar] matrix of responses to the Cholesky shocks at step k.
ewise goodfevd(accept)(i,j)=ik=(irfsquared(i)*(a.^2))./(irfsquared(i)*ones),ik(j)
if accept>=nkeep
break
:reject
end do subdraws
dim shock(accept)
set shock(accept) = %dot(a,inv(sigmad)*%xt(resids,t))
if accept>=nkeep
break
* Bookkeeping of VAR coefficients:
compute bgibbs(draw-nburn) = bdraw ;* Saves the Draws of the VAR Coefficients
end do draw
infobox(action=remove)
graph 1
#shock(2)
Can you help?
Best
Jules
You made major (and incorrect) changes to this rather than just reducing nshocks to 1 and fixing VWEIGHTS. Go back to the original and keep the basic structure.
dim shocks(accept)(nshocks)
compute vweights=v1~v2~v3r~v3e
do j=1,nshocks
set shocks(accept)(j) = %dot(%xcol(vweights,j),inv(sigmap)*%xt(resids,t))
if accept>=nkeep
break-
Jules89
You are right! Here is a corrected code:
That should be correct right?
Just one more question. Is it possible to delete a series after it is loaded/generated?
Something like
delte shocks(10000)(1)
or so?
Because I saved the 100000 shock series and after I did some analysis to them, I need some space for further analysis, thats why I want to delte them.
Best Jules
calendar(m) 1965:1
compute tight=.1
compute other=.5
lags 1 to 12
declare vect[vect[series]] shocks(nkeep)
compute nshocks=1 ;* Number of shocks
dec vect[vect[series]] shocks(nkeep) ;* Storage vector for the series of shocks
compute accept = 0
do draw= 1,n1
if draw<=nburn
next
do subdraws=1,n2
goto reject
compute vweights=a
do j=1,nshocks
set shocks(accept)(j) = %dot(%xcol(vweights,j),inv(swish)*%xt(resids,t))
if accept>=nkeep
break
:reject
end do subdraws
if accept>=nkeep
break
end do draw
graph 3
# shocks(2)(1)
# shocks(1)(1)
# shocks(10000)(1)
Something like
or so?
Best Jules
dim shocks(0)
should do it.
should do it.
